Discrete Mathematics - Void Sets being Subsets of other Void Sets
The discussion revolves around the relationship between the empty set (∅), the set containing the empty set ({∅}), and the set containing that set ({{∅}}) in the context of order relations. The confusion arises from the distinction between subsets and members; specifically, {∅} is not a subset of {{∅}} because its only element, ∅, is not an element of {{∅}}. The empty set (∅) is universally a subset of all sets, including {{∅}}, but {∅} does not share this property. Clarification was provided that while ∅ is a subset of every set, {∅} is not a member of {{∅}}, which resolves the misunderstanding. This highlights the importance of distinguishing between membership and subset relationships in set theory.
johnstobbart
Hello.
Here is the question:
Determine whether or not R is some sort of order relation on the given set X.
X = {∅, {∅}, {{∅}} } and R ε ⊆.
I can't seem to figure out why the ordered pairs given are what they are.
None.
What I first wrote out was:
R = { (∅, {∅}), ({∅}, {{∅}}), (∅, {{∅}}) }
Which is missing some ordered pairs. Also, my book says ({∅}, {{∅}}) is not an element of ⊆.
I tried to use my limited logic to understand the answer given, and this is what I got:
(∅, ∅) is an ordered pair because all the elements of ∅ are in ∅.
(∅, {∅}) is an ordered pair because ∅ is a member of {∅}.
(∅, {{∅}}) This causes some confusion. My book says the only member of {{∅}} is {∅}, but the first coordinate has to be a subset of the second coordinate. If ∅ is not an element of {{∅}}, how can it be a subset?
({∅}, {∅}) is an ordered pair because they are equal and subsets of each other.
({{∅}}, {{∅}}) same as above.
I don't understand why {∅} is not a subset of {{∅}}. {∅} is an element of {{∅}}, and should be a subset of it to my understanding because all the elements of {∅} are also within {{∅}}.
I think you are not distingishing between being a subset and being a member of a set.
{∅} is not a subset of {{∅}} because {∅} contains the empty set as a member and {{∅}} does NOT. "All the elements of {∅} are also within {{∅}}" is not true. The only member of {∅} is the empty set and that is NOT a member of {{∅}} because it only member is {∅}, not the empty set. The empty set is a subset of every set but not necessarily a member.
Thanks for the reply HallsofIvy. That explains why ∅ is a subset of {{∅}}, while {∅} is not. ∅ is a subset of every set, while {∅} is not because that it is the set that contains only ∅. Is that correct?
  • · Replies 35 ·
