Volume of solid from revolving y=1/sqrt(x) about y=-1
  • Thread starter Thread starter Justabeginner
    Disk Method
14 replies · 3K views
Justabeginner
Find the volume of the solid generated by revolving the region bounded by y=1/sqrt(x) and y=0 for 1≤x≤2 about the line y=-1
Disk Method? ∏ * ∫[f(x)]^2 dx
A and B (lower and upper limits will be 1 and 2)?
∏ * ∫(1/sqrt(x)^2 dx
∏ * ∫1/x dx
∏ * ln x
Since limits are 2 and 1, my final answer is: ∏ * ln 2
Is this right? Thanks.
This formula is applicable only if the rotation is around the x-axis.
The formula would be better written as ∏ * ∫[radius]2dx
∏ * ∫1/x dx
∏ * ln x
No. Your integrand doesn't reflect the fact that the region is being rotated around the line y = -1. You can't use a disk in this case - you need to use a washer if you use vertical strips, or you could use shells if you go with horizontal strips.
Would the correct way to set it up then be
∏ * ∫([1/sqrt(x)] + 1)^2) ?
And follow up with:
∏* ∫[1/x + 2/sqrt(x) + 1]
∏ * ([ln x] + 4sqrt(x) + x) ?
Thank you so much for all your help.
No, this isn't set up correctly. You're using disks when you should be using washers.
For a washer, the volume is ##\pi [(R_{outer})^2 - (R_{inner})^2]Δx##.
Justabeginner said:
And follow up with:
But I just don't understand, even after drawing this diagram, how there's an inner AND an outer radius? If you could explain that to me, I'd appreciate it.
The region to be rotated is roughly trapezoidal in shape. Its bottom edge is the x-axis, the left and right edges are the lines x = 1 and x = 2, and the top edge is the curve y = 1/√x.
When the region is rotated around the line y = -1, you get a kind of ring-shaped solid that is hollow. The inner radius is 1, and the outer radius extends from the line y = -1 to the curve.
Thank you! I am horrible at visualizing things in 3D and your description made it so much clearer.
But how would I determine the length of the outer radius? I know that the points on the curve are (1, 1) and (2, sqrt(2)/2)- how would that help me in this problem, or would it not be of any use?
Points on the curve are of the form (x, 1/√x). The upper end of the outer radius is at this point, and the lower end is at (x, -1). How far apart are these points?
So what I get now is:
∏ *∫{[(1/sqrt(x) + 1)^2] - (1^2)} * Δx (Isn't delta x = 1 since x=1 and x=2 are bounding the region?)
∏ * ∫(1/x) + 2/sqrt(x) + 1 - (1)
∏ * (ln x + 4sqrt(x))
And since x=1 and x=2 are the left and right bounds, I'd plug that into solve for the final volume?
∏* [(ln 2 + 4*sqrt(2) - (ln 1 + 4 sqrt(1)]
∏ * [ln 2 + 4sqrt(2) - 4]
Is this correct?
No, that's not what Δx means. It corresponds loosely with dx in the integral.
I don't have time to look at this, right now, but will later on if nobody else jumps in.
Is this correct?
Okay thank you so much! (Yes I just realized, delta x can also be used for dx- I don't know why I even said that -_-)
Is this correct?
Yes, that's what I get, too.
