Distance between point and a line
  • Thread starter Thread starter TheAntithesis
    Line Point
The discussion focuses on calculating the minimum distance between a point (i, j, k) and a line defined by the parametric equations x(t) = a + pt, y(t) = b + qt, z(t) = c + rt. Participants emphasize that the shortest distance is along the perpendicular to the line. The solution involves expressing the distance as a function of t, differentiating it, and substituting back to find the minimum distance. An example with specific coordinates demonstrates the method, confirming that the final distance is a function of the parameters a, b, c, p, q, r, i, j, k.
  • Understanding of parametric equations in three dimensions
  • Knowledge of vector operations and differentiation
  • Familiarity with distance formulas in Euclidean space
  • Ability to manipulate equations to find critical points
  • Study the derivation of distance formulas between points and lines in 3D space
  • Learn about vector projections and their applications in geometry
  • Explore optimization techniques in calculus, particularly in multivariable functions
  • Practice solving similar problems involving distance calculations in three dimensions
Mathematicians, physics students, engineers, and anyone involved in computational geometry or optimization problems will benefit from this discussion.
TheAntithesis
I want to find the minimum distance between a point (i,j,k) and the line given by parametric equations x(t)=a+pt , y(t)=b+qt , z(t)=c+rt.
I know how to find the distance between a point and a normal line (non parametric), but I have no idea how to go about finding the distance here.
How should I go about doing this question? An example would be very helpful.
why not try and re-write the line non-parametrically then?
otherwise its the same idea, the shortest vector joining the line and the plane will be perpindicular to the line (why?)
Re-write the line as in the form (a+pt,b+qt,c+rt) ? I still don't know what to do with the t.
try a little rearranging
(x-a)/p = (y-b)/q = (z-c)/r = t
now try and find a single equation relating x,y,z... if that will help you solve the problem, as you said you knew how to use it then
otherwise I would
- find the direction of the line
- find the vector, say u, from the point, to any point on the line
- then the component of u, that is perpindicular to the line will give you the distance
Ok cool, thanks. I'm guessing my answer will be a function of t?
[STRIKE]Must be.[/STRIKE]
Actually once you have (a+pt,b+qt,c+rt) and (i,j,k) looks to me like it is just a matter of expressing the distance between the points as a function of t...
Edit: I am an idiot, final answer will be a function of a,b,c,p,q,r,i,j,k, not t.
No, it's simple. Compute the distance (or distnace^{2} will do) from your point to a general point on your line. To minimise this, differentiate w.r.t. t and then substitute the t you found from differentiating back into your equation to find the minimum distance.
yep that's easier
Oh god..
Ok say the point is (-5,10,13) with its position vector v and the line is given by equation r(t) = (-57,75,0) + t(-4,5,-1).
A point on the line is P(-4,5,-1) so that's the position vector u.
Then the line between the two points would be would be v - u = w = (-5,10,3) - (-4,5,-1) = (-9,5,14)
So I'm guessing all I need to do is find for which t the w.r(t) = 0 then put it back into the r(t) and find the distance between the two points?
I solved for t and got 35.52
Subbed it back into the line equation and got point coordinates Q(85.08,252.6,-35.52)
Then the distance between the two points is |PQ| = sqrt(90.08^2 + 242.6^2 + (-48.52)^2) = 263.293.
Does this method and answer seem reasonable?
It does, check it using the method I proposed and see if you getthe same answer, if they match then you've done it.
Mat
The crucial fact is that the shortest distance from a point to a line is measured along the perpendicular to the line.
Given a line in 3 dimensions, you can construct the vector in the direction of the line.
Given a point, p, in 3 dimensions, you can write the equation of the plane containing that point and having the vector, above, as normal vector.
You can then determine the point, q, where the given line crosses the plane. The shortest distance from point to line is the distance from point p to point q.
