Distance between two electrons where electrostatic force cancels gravity
11 replies · 3K views · last reply
xswtxoj
An electron is released a short distance above Earth's surface. A 2ndelectron directly below it excerts an electrostatic force on the 1st electron just great enough to cancel the gravitational force on it How far below the 1st electron is the 2nd?
F= Ke (q1)(q2)/r^2
Since the two forces are acting in opposite directions and you want them to add to zero you can set your gravity force equation equal to the electric force equation. Then you should be able to solve for the distance "r".
Can you write it out for me? I don't quite understand what you mean!
Well the force of gravity on the 1st electron is can be found using [itex]F=ma[/itex] where "a" = g = acceleration due to gravity 9.8 [itex]\frac{m}{s^2}[/itex]. You already have the equation for the force between the two electrons due to their charge. Since you want the forces to be equal(because they are opposing and cancel each other out) you can set both of these equations equal to each other. Then the only variable you won't know in this combined equation should be r which is the distance between the paritcles' centers. Your equation should look something like
[tex] mg = \frac{q_1 q_2}{4 \pi \epsilon_0 r^2}[/tex]
how would u solve this problem if no numbers are given? i really don't get this?
what u said so i set up the equation and to cancel is like Keqq= Frsq then qq=mg4 pi Eo rsq, then cancel all like terms, to have Ke=F=mg4 pi Eo?
considering that its an electron as 1.6 x 10^-19, and ur finding the distances, how would u apply that to the 2 equations above?
DukeLuke gave you the equation. So look up the mass.
Solve for R.
can the equation be used as q1q2/ 4 pi (8.85x 10 ^-12 ) r sq,,,, the 8.85 be used for E0?
Yes. Of course.
is i use the [tex]mg = \frac{q_1 q_2}{4 \pi \epsilon_0 r^2}[/tex] then would it be: 9.8= 1.6 E -19 sq/ 4 (3.14)(8.85 E -12) r2, then cross multiply to get 9.8 x 4 x 3.14 x 8.85xE-12 (r sq) = 1.6x10-19 sq then get 1.089E -9 (r sq) = 2.56x -38 then divide to isolate r sq, then solve for r to get 4.84E -15
