Distance between two objects dropped at different times
  • Thread starter Thread starter 3005
The discussion revolves around calculating the distance between two objects dropped from a height at different times, with the first object dropped initially and the second 1.5 seconds later. The key equations involve the displacement of each object, factoring in their respective times and accelerations due to gravity. The correct approach requires treating each object's motion separately and relating their times to find the distance apart when the second object reaches a speed of 12.0 m/s. The final calculated distance between the two objects is confirmed to be 29.0 meters. Understanding the time difference and applying the equations correctly is essential for solving the problem.
3005
An object is dropped from the roof. A second object is dropped 1.50 s later. How far apart are the objects when the second one has reached a speed of 12.0 m/s.
GIVEN
Obj 1 - vi=0 m/s , a=-9.8 m/s/s
Obj 2 - vi=0 m/s, vf=12.0 m/s, a=-9.8 m/s/s
d=vf*t+1/2*a*t2
d=12.0*1.50+1/2*-9.8*2.25
d=18-11.025
d=6.975
I'm not sure exactly how to do this when there's two objects :S.
The answer is 29.0 m, but I want to understand how to get it.
Write the equations for the displacements of both objects. The usual equation is the distance traveled during the time since the object has been dropped: If you start a stopwatch when the first object is dropped, and the second one when the other one is dropped, the second watch will 1.5 s behind the first one.
ehild
So would it be:
d=vf*t-1/2*a*tt
d=12*1.5-1/2*-9.8*2.25
d=18-(-11.025)
d=29
Oh I think I just messed up the sign on the equation.
I think its right now.(?)
You need to treat each object separately; i.e. you need an equation for the displacement of each object. (Technically these should be functions of time.)
There is a time difference between the two objects; if you know the difference, how can you relate the times of the two objects? This relation will allow you to solve the first two equations.
3005 said:
So would it be:
d=vf*t-1/2*a*tt
d=18-(-11.025)
d=29
I do not know how you arrived to the equation, but it is correct.
When the second object is dropped the first one has the velocity of 1.5 g and traveled 1/2 g 1.5^2 meters. After that, the distance traveled by it is
s1=1/2 g 2.25+1.5gt + g/2 t^2, and that of the second object is s2=1/2gt. The distance between the objects is
D=s1-s2 =1/2 g 2.25+1.5 gt.
The second object reaches 12 m/s velocity in t=12/g time. Plugging back for t you get D=29.0 m.
ehild
