Distance, Time, and Temperature question
  • Thread starter Thread starter Nathan J
    Temperature Time
The problem involves a rock being thrown down a well, with the discussion focusing on calculating the depth of the well, the time it takes for the rock to reach the bottom, and the temperature of the air in the well. The subject area pertains to kinematics and the effects of gravity on motion.
  • Participants discuss the practicality of the question, particularly regarding the influence of drag on the accuracy of temperature calculations. There are suggestions to reconsider the value of gravitational acceleration used in calculations. Some participants propose using direct relationships between variables rather than relying on intermediate results.
The discussion is ongoing, with participants providing feedback on the original poster's attempts and questioning certain assumptions. There is no explicit consensus, but some guidance on calculation methods and values has been offered.
Participants note that the problem may be sensitive to the values used for gravitational acceleration and that the context of the well's location could affect the results. The original poster's work is presented in an image, which may limit the ability to fully assess the calculations.
Nathan J
A person throws a rock down a well with an initial velocity of 2.10 m/s. The sound of the rock striking the bottom of the well is heard 4.22 seconds after the rock is thrown down. If the velocity of the rock just before it hits the bottom of the well is 41.0 m/s.
What is:
a) The depth of the well
b) The time it takes for the rock to hit the bottom of the well
c) The temperature of the air in the well
DID I DO THIS RIGHT? CHECK MY WORK ON IMAGE.
g = 9.8 m/s ^2
V1 = 2.10 m/s
V2 ^2 = V1^2 + 2gd
d=vt
On picture![/B]
First, the question is impractical. Drag would likely overwhelm the accuracy of it as a way of finding the temperature.
Are you told to use 9.8 for g? The arithmetic might be a bit sensitive to the values. I would use 9.81.
Either way, I would certainly keep an extra digit through the calculations.
For part b, it would be better to work more directly with the given data than with intermediate results, i.e. use v=u+at. It also avoids quadratics.
Not sure what happened towards the end of part b. You found the time of the fall, then appear to have used that as if it were the time for the sound to come up. But you got a reasonable answer for sound speed, so this was probably an error in copying out your working.
Other than that, all looks fine.
I would say that depends on the location of the well...
It is just a basic grade 11 question, it isn’t supposed to be too complicated
