Distance traveled by a particle using Potential energy function
16 replies · 4K views
MissBisson
A 1kg particle is in a potential given in joules by U(x)=3x2+4x-5, where x is in metres. The particle is initially at position x=1m and moving with velocity v=4m/s in the +x direction.
Find the position when the particle first comes to rest.
dKe = Kf-Ki , Kf=0
Ke=-1/2mvi^2
F=ma
w=F x d
U'(x) = 6x+4
Force at 1m = 10N
Ke=-1/2(1kg)(4)^2 = -8J
-8=10xd
d=-0.8m
d=xf-xi
-0.8=xf-1
xf=0.2m
However this was wrong. i also tried using several different methods but they were all wrong ..
Help would be appreciated !
I see no need to consider forces - just work with ... work.
What are the initial and final PEs and KEs?
Alright so,
Ui = 2J (at x=1) Uf=0J (at rest) dU=-2J
Ki = 8J (from 1/2mv^2) Kf=0J (at rest) dK=-8J
W= dK+dU = -2 + -8 = -10J
-dU/dx = F = -6x-4, therefore at x=1 F=-10N
W= F x d
-10J = -10N x d d=1?
MissBisson said:
Uf=0J (at rest)
No. If it finshes at position xf, what is U there? Remember, in this question U represents only the potential energy.
MissBisson said:
-dU/dx = F
As I said, you don't need to work with forces at all.
if i don't use forces, how do i find my distance ? I am confused...
The force varies. You cannot here simply multiply force by distance to get energy. It requires an integration. So you might just as well work only with energy.
You correctly calculated the initial potential energy. Suppose the final position is xf. Using the same method, calculate the final potential energy in terms of xf.
Ahhh i see! So i solved the quadratic function and it gave me a positive and negative number.. i entered the positive number however that was wrong..? is it possible for the particle to have a negative final position?
That should have worked. Please post your working.
Okay, my procedure was;
U(xf) = 3(xf)^2 +4(xf) -5
xf = (-4 +/- sqrt(4^2-(4*3*-5)))/2*3
xf = (-4 +/- sqrt(16-(-0)))/6
xf = (-4 + sqrt(76))/6 = 0.786m
xf = (-4 - sqrt(76))/6 = -2.119m
You appear to have solved the equation U(xf) = 0. That is the wrong equation. What equation do you have for U(xf) ?
The is the equation i have:
U(xf) = 3(xf)^2 +4(xf) -5 , do i have to set it equal to the initial potential energy which was 2 ? or do i have to somehow include the kinetic energy in the equatin also?
MissBisson said:
Thank you so much! it finally worked :)
So, do you now understand that to solve it you needed to apply conservation of work, initial (PE+KE) = final (PE+KE)?
omar moured said:
is the answer ( 5/3 m ) = 1.7 approximately ?
Yes it was 1.67m
