Distance traveled by train using forces and kinetic friction
The discussion revolves around a physics problem involving a train's stopping distance when a panic stop is initiated. The train's mass, speed, and the coefficient of kinetic friction are provided, prompting participants to analyze the forces at play and the equations of motion involved.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants explore the calculation of net force and its relation to friction and weight. There are questions about the correct application of equations and whether to use gravitational acceleration or net force in calculations. Some participants suggest using work-energy principles to find the stopping distance.
The discussion is ongoing, with participants providing guidance on understanding the forces involved. There is a recognition of confusion regarding the net force calculation and its implications for determining the stopping distance. Multiple interpretations of the problem are being explored, particularly regarding the application of kinetic friction and energy concepts.
Participants note uncertainty about the correct approach to calculating the stopping distance and the potential for misunderstanding the relationship between vertical and horizontal forces. There is also mention of a lack of an answer key for verification.
Mg53
A train has a mass of 5 million kilograms and is traveling south at 22 m/s. If the train driver has to initiate a panic stop, how far will the train go before it comes to a halt. Use 0.08 as the coefficient of kinetic friction.
m=5*106 kg
v=-22 m/s
μ-kinetic friction=0.08
g= 9.8 m/s2
Horizontal surface: F(normal)=F(weight)
F-weight=mg
F-kinetic = (F-normal)*(μ-kinetic friction)
v= sqrt(2*(F-net/m)*x) x= v2/2*(F-net/m) I'm not sure if it's F(net)/m or g that's supposed to used. My book has both written in it.
F(net)=F(normal)-F(kinetic)
** where F(net)/m comes from the equation F(net)=ma
F(weight): (5*106)(9.8) = 4.9*107 N
F(kinetic): (4.9*107)(0.08)= 3.9*106 N
F(net): (4.9*107)-(3.9*106)= 4.5*107 N
F(net)/m: (4.5*107)/(5*106) = a = 9 m/s2
x=(-22^2)/(2*9)
= 54 m
I've tried this problem multiple times but I keep getting the wrong answer. 54 meters doesn't make sense but none of my other answers have either. I think the problem is somewhere in the F(net)/m step though. Is it suppose to be a instead where a=9.8? Any help would be appreciated!
Welcome to PF!
Hi Mg53! Welcome to PF! :smile:
(try using the X2 button just above the Reply box :wink:)
Mg53 said:
F(net): (4.9*10^7)-(3.9*10^6)= 4.5*10^7 N
i don't understand this …
you seem to be subtracting the horiztonal friction from the vertical weight
i] you can't do that
ii] why did you want to? :confused:
just do work done = change in kinetic energy :smile:
(and don't waste space writing in the m, it makes no difference!)
Hi, thanks for the help :)
The reason I did that was because I thought the net force was equal to the normal force minus the force of kinetic friction. Like I said though, I had a feeling that's where I was messing up in the problem but I didn't really know what else to do.
Okay, I'm still a little confused by one part of that.
Work done=change in kinetic energy
=(1/2)(5*106)(222)
= 1.21*109
I can use that to find the distance using W=Fx but what F do I use? The force of kinetic friction?
I did that and got x=310 m which I guess might make sense but I'm still not sure if that's right because I don't have an answer key :/
Hi Mg53! :smile:
you're completely confused :confused:
the net vertical force is zero (because the vertical acceleration is zero)
the net horizontal force is the friction (because it's the only horizontal force)​
… I can use that to find the distance using W=Fx but what F do I use? The force of kinetic friction?
yes of course
(i'm going to bed … goodnight! :zzz:)
