Distillation Lab Recipe for Beginner Chemistry Students
  • Thread starter Thread starter sakinam
    Distillation Lab
The discussion focuses on effective distillation lab recipes for beginner chemistry students. A recommended mixture includes wood chips, iron bits, benzoic acid, salt, and sand, which allows for a hands-on separation experience. Participants can utilize a magnet to extract iron, float wood chips in water, and subsequently isolate sand and salt through heating and cooling processes. This approach not only provides a clear visual separation but also engages students in practical chemistry applications.
  • Basic understanding of distillation principles
  • Familiarity with separation techniques in chemistry
  • Knowledge of physical properties of materials (e.g., density, solubility)
  • Experience with laboratory safety protocols
  • Research the properties and applications of benzoic acid in laboratory settings
  • Explore advanced distillation techniques and equipment
  • Learn about the separation of dyes using chromatography
  • Investigate the chemistry behind salt solutions and their uses in experiments
This discussion is beneficial for chemistry educators, laboratory instructors, and students seeking engaging and practical distillation experiments for introductory chemistry courses.
sakinam
I am looking for a recipe for a good mixture for beginning chemistry students to separate by distillation. I have tried water/ethanol mixtures, but there is not a clear definition between the two. Also, I would like something more visual. I have heard rumors of a separation of dyes, but I have been unable to locate it. That sounds like an excellent lab, I just don't know what to use or where to get it. I have also heard of using cherry coke, but I am unsure of what if anything I should mix with it. Suggestions? Ideas? Recipes?
Thank you for your help!
Chemistry news on Phys.org
Try a salt solution. It is cheap, easy and you can taste the results!
We had this awesome mixture lab which he gave to us the first day of my first year of chemistry in HS. It was a solid mixture of wood chips, iron bits, benzoic acid, salt, and sand. He said, Separate this.It was loads of fun.
Of course, you use a magnet to remove the iron.
Put it in water and the wood chips float.
Heat & Stir, and all is left is sand and water, and you just get the sand out.
Let it cool and the benzoic acid reforms.
Then boil away the water and you get your salt.
It's great fun though!
  • · Replies 26 ·
22K
