Distinguishing classical physics vs. quantum physics
The discussion revolves around how to effectively distinguish between classical physics and quantum physics in a manner that is both simple and concise. Participants explore various statements and analogies that could encapsulate the differences, while considering the understanding level of a college freshman.
  • One participant suggests that quantum theory (QT) is consistent with the stability of matter, while classical physics is not, though they question if this is understandable for a freshman.
  • Another participant proposes that quantum physics is contextual, leading to a generalization of classical probability theory.
  • A different viewpoint emphasizes the mathematical distinction, highlighting the non-commutativity of position and momentum in quantum mechanics.
  • Some participants discuss the implications of indistinguishable particles and their non-classical consequences.
  • One participant critiques the Alice and Bob analogy, suggesting it may not effectively distinguish classical from quantum physics and proposes focusing on violations of Bell inequalities instead.
  • Another participant emphasizes the importance of maintaining a classical causal structure when discussing influences in quantum mechanics.
Participants express a range of viewpoints without reaching a consensus on a singular, effective statement to distinguish classical and quantum physics. The discussion remains unresolved, with multiple competing ideas presented.
Participants note the challenge of formulating a statement that is both simple and comprehensible to those with limited physics background, highlighting the variability in educational standards and exposure to physics concepts.
  • #91
PeterDonis said:
If you can give a specific reference I will take a look at it.
For CHSH try page 114 of Quantum Computation and Quantum Information by Nielsen and Chuang (favorite of mine and Demystifier).
I looked on the internet for GHZ and was appalled at how long and clumsy all the presentations were. I posted a presentation during a dialogue with rubi. It was simple and very short, but I can't recall the thread. Do you know of a way I can go about finding it?
  • #92
I rewrote it for your viewing pleasure (or not).
Physical set up for GHZ:
Alice, Bob, Carol, and Eve are all mutually one light minute apart. At noon Eve simultaneously sends a light signal to each of A, B, and C. When A receives her signal she flips a fair coin. If it comes up heads she selects (via some objective process) a value of either 1 or -1 and calls that Ah. If she flips tails she selects 1 or -1 and calls it At. This takes her less than ½ minute. Each of B and C do the same, calling their selections Bh, Bt, and Ch, Ct.
If we assume that no influence or information can go faster than the speed of light (called locality) then none of the three know what the others flipped, nor can one's selection influence another's.
GHZ Theorem: Let's assume that if only one of A, B, or C flipped a head then the product of their selections equals -1.
I.e., we assume -1 = Ah•Bt•Ct = At•Bh•Ct = At•Bt•Ch.
Then we may conclude if all three flipped heads their product would be -1. I.e., -1 = Ah•Bh•Ch.
Proof: -1 = (Ah•Bt•Ct)•(At•Bh•Ct)•(At•Bt•Ch) = At²•Bt²•Ct²•Ah•Bh•Ch which implies that -1 = Ah•Bh•Ch. QED
If Eve sent each of A, B, C one photon from the entangled triple state |ψ⟩ = √½(|000⟩ + |111⟩) and if flipping a head selects the value obtained by measuring a photon with Pauli X and flipping a tail means measuring with Pauli Y, then X⊗Y⊗Y and Y⊗X⊗Y and Y⊗Y⊗X each operating on |ψ⟩ yield -1, so the hypothesis of the Theorem is satisfied. However, X⊗X⊗X operating on |ψ⟩ gives 1, contradicting the conclusion.
Lab tests show the QM predictions are correct. So what's wrong?
Why other sites take pages of gobbledygook is beyond me. Maybe you see a reason.
  • #93
Your notation is somewhat confusing; earlier you gave the eigenvalues of the measurements as 1 and -1, but in this expression it looks like they are 0 and 1. Also, which basis (X or Y, or something else) is this expression written in?
  • #94
The eigenvalues are 1 and -1. I am using the standard q-computing notation, see Nielsen and Chuang.
|ψ⟩ = √½(|000⟩ + |111⟩) = √½[1,0,0,0,0,0,0,1] in the 8D tensor product space is an eigenvector of X⊗Y⊗Y with eigenvalue -1 and is an eigenvector of X⊗X⊗X with eigenvalue 1.
  • #95
In which basis on that space?
  • #96
|0⟩ = [1,0], |1⟩ = [0,1] are the basic qubits, |000⟩ = |0⟩⊗|0⟩⊗|0⟩ = [1,0,0,0,0,0,0,0], |001⟩ = |0⟩⊗|0⟩⊗|1⟩ = [0,1,0,0,0,0,0,0], etc. If you don't have access to N & C any reference to q-computing should do. It is the slickest QM notation.
If the QM is a bit obscure it doesn't matter. The point is that QM satisfies the hypothesis but negates the conclusion of the Theorem. So how is that resolved?
  • #97
In which basis? Do you understand what that question means? There are an infinite number of possible pairs of basis qubits. Which of them are you using?
  • #98
Here is Zeilingers version in chapter 16.2 (not very long either): https://vcq.quantum.at/fileadmin/Publications/2002-12.pdf
  • #99
The basis in 2D is [1,0] and [0,1], the higher dimensions are built up of tensor products. If you find this inadequate check out N&C.
But your questions are side stepping the crucial question as I said above.
As we pursue this line, I must admit I am nervous that you may use your god like powers to cut out my posts. We are a bit off topic and perhaps we should leave it with I am convinced that Bell used CFD in his argument and you are convinced he didn't.
Or we could start a separate thread on this topic, or whatever you wish.
  • #100
Zeilinger's version and mine are the same. Where he has |H⟩1 |H⟩2 |H⟩3 I have |0⟩|0⟩|0⟩ = |0⟩⊗|0⟩⊗|0⟩ = |000⟩ as per Nielsen & Chaung.
  • #101
Still doesn't answer the question. I need actual directions in space that describe the orientation of the basis vectors.
Which means that your "0" means "horizontal" and your "1" means "vertical", as in polarization directions for photons. That answers the question. (Actually, you also used "X" and "Y" to describe measurements, so I assume that "X" also means horizontal and "Y" also means vertical.)
  • #102
X is diagonal basis H'/V' (H'=-1, V'=+1)
##|H'\rangle=\frac{1}{\sqrt 2}(|H\rangle+|V\rangle)## and ##|V'\rangle=\frac{1}{\sqrt 2}(|H\rangle-|V\rangle)##
and Y is circular polarization basis L/R
##|R\rangle=\frac{1}{\sqrt 2}(|H\rangle+i|V\rangle)## and ##|L\rangle=\frac{1}{\sqrt 2}(|H\rangle-i|V\rangle)##
it's in the link I gave in post #98
There is a heuristic principle how to make sense of this GHZ state. All phases between H and V modes have to sum up to ##0##.
H' state gives phase ##0##, V' gives phase ##\pi##, R state gives phase ##\pi/2## and L state gives phase ##3\pi/2##.
With this we get allowed combinations:
H'LR gives ##0+3\pi/2+\pi/2=2\pi##
H'RL gives ##0+\pi/2+3\pi/2=2\pi##
V'LL gives ##\pi+3\pi/2+3\pi/2=4\pi##
V'RR gives ##\pi+\pi/2+\pi/2=2\pi##
  • #103
X = Pauli X = σx = ##\begin{pmatrix}0&1\\1&0 \end{pmatrix}##
Y = Pauli Y = σy = ##\begin{pmatrix}0&-i\\i&0\end{pmatrix}##
And for completeness Z = σz = ##\begin{pmatrix}1&0\\0&-1\end{pmatrix}## has eigenvector |0⟩ = [1,0] = ##\begin{pmatrix}1\\0\end{pmatrix}## with eigenvalue 1, and eigenvector |1⟩ = {0,1] with eigenvalue -1.
These are the most common 2D measurement operators
  • #104
The vector [1,0] in the xy plane appears to be pointing horizontally off to the right, while [0,1] appears to be pointing vertically upward. That's why Zeilinger used the notation |H⟩ for {1,0}, where as I used the standard q-computing notation of |0⟩
No, that isn't the case. The 0 in |0⟩ is an atavistic homage to the classic bit 0, while the 1 in |1⟩ refers to the bit 1. The X and Y I defined in post #103
If you are really interested in the quantum computing notation you should take a look at Nielsen & Chuang, it's quite nice and far easier to read than say Ballentine, for example.
I suspect you have lost interest in our original CFD question.
  • #105
No, I just wasn't familiar with your notation or the references you gave. I am looking at the Pan & Zeilinger paper you linked to (which gives a much better brief and explicit description of its notation) and will probably have further comments once I have digested it.
  • #106
Zafa Pi said:
Would you say that the usual CHSH or GHZ uses CFD?
Having looked at the Pan & Zeilinger paper you linked to, I would say that CFD is not necessary to prove the GHZ theorem, although that is not always made clear in statements of the theorem. The GHZ theorem can be stated, just like Bell's Theorem, entirely in terms of properties of actual measurements. In the GHZ case, the "inequality" is simpler, because it's a flat contradiction, not requiring statistics: prepare a large ensemble of sets of three photons in the GHZ state. Randomly choose which of four measurements to make on each set: xyy, yxy, yyx, or xxx. Compute the "result product" for each measurement. Quantum mechanics predicts that the "result product" will be -1 for the first three measurements and +1 for the fourth. Any "local realistic" model (by the GHZ definition) predicts that, if the result product is -1 for the first three measurements, it must also be -1 for the fourth.
  • #107
zonde said:
Seems I have ended up in someones ignore list
Oops, sorry, I lost track of who linked to what. You're right, the link to that paper was yours, not Zafa Pi's.
  • #108
OK, now I have two questions:
1) What does your x represent?
2) What is your proof of your last sentence? I gave one in post #92 with totally different notation defined there.
  • #109
I don't understand the confusion. You have a 2D Hilbert space and build Kronecker products of those. Physically realizable are these as polarization states of photons (corresponding to the two helicity states (circular polarized em. waves) or H/V states (linear polarized em. waves); it's just a change of bases between the two) or of spin 1/2 states (corresponding to two states of ##\sigma_z = \pm 1/2##).
  • #110
I'm using the definitions in the paper zonde linked to. In that paper, H and V are the horizontal and vertical linear polarized states, x is a measurement of linear polarization in the 45 degree direction, and y is a measurement of circular polarization. So treating the polarization state space as a qubit, the eigenvectors of x are H + V and H - V, and the eigenvectors of y are H + iV and H - iV. That means the measurement operators, in the "z" basis (i.e., the H/V basis), are just the Pauli x and y spin matrices (and the measurement operator of horizontal/vertical linear polarization is the Pauli z spin matrix), which is the same as what you were using.
It's just building a generic "local realistic" model that predicts -1 for the first three measurements, and then computing what it predicts for the fourth. The model requires assigning hidden variables to each photon in a particular way, so I would call it a "local hidden variable" model rather than a "local realistic" model. But the key aspect of the model is similar to Bell's model, that for each photon there is a function that is used to predict the results of measurements on it, and that function is a function only of the hidden variables assigned to that photon and the setting of the measurement device for that photon. It does not depend on any hidden variables or measurement device settings for other photons. That is the mathematical definition of "locality" in this model.
Some people would say that any model that includes hidden variables (i.e., variables that aren't measured) requires CFD (counterfactual definiteness), but that's a matter of words and definitions. The reasoning involved in constructing the predictions and testing them does not require any results to be assumed for measurements that are not actually made, so to me it does not require CFD. But we can always just eliminate the term "CFD" entirely and substitute whatever definition of it we are using, if there is any issue with definitions or clarity. The same is true of "locality", "realism", or any other such term. The point is to explore what kinds of properties can or cannot be possessed by models that are capable of reproducing the predictions of QM (and therefore of matching actual experiments).
  • #111
A measurement by either X or Y on a photon from |ψ⟩ (post #92) yields 1 or -1 with = probability. And I'm sure you know that different trials will not necessarily yield the same value.
Well you didn't offer a classical proof that if Alice, Bob, and Carol all chose to measure with X the product of the results would be -1. For three different runs/trials not requiring CFD give, for example,
XA•YB1•YC1 = -1, YA1•XB•YC2 = -1 and YA2•YB2•XC = -1. Where YA2, for example, is the 2nd time Alice measures with Y
Now what? I also notice you didn't answer my question at the end of post #92.
  • #112
I don't see the point of rehashing the entire model described in the paper. The predictions of that model are clear.
I'm not sure what the question is. You ask "now what?" as if there's some problem I'm supposed to solve, but I don't see what it is. I have never denied that QM gives the correct predictions. I personally don't care what ordinary language terms you use, or whether you think "CFD" is "required" or not. The mathematical requirements for any theory that matches the QM predictions are clear; what ordinary language labels you want to paste on them is irrelevant.
  • #113
PeterDonis said:
This is not correct. P(a, b) and P(a, c) in the formula at the top of p. 406 refer to probability distributions obtained from two sets of runs--one set with settings a, b for the two measuring devices, the other with settings a, c for the two measuring devices.
If they are obtained from two sets of runs Why does is A(a,λ) the same in two different runs. It's the same difficulty you have with GHZ.
  • #114
Because that's what the model says. The model is just math; it's a mathematical engine for making predictions. You can take some property of the math, such as the fact that the same function A(a,λ) is used in the model to generate predictions for different runs, and label it with a name like "CFD" or "hidden variables" or whatever. But that has nothing to do with the math or the predictions or comparing the predictions with the results. So I have no interest in arguing about it. Sure, call that property "CFD" if you want, I don't care. It makes no difference to the physics.
  • #115
Just like when you said that P(a,b) was a probability distribution and it wasn't, you are now saying A(a,λ) is a function. It is not, A(a,λ) is a fixed number either 1 or -1 and it's not necessarily the same number in two different runs. How does one get away with using the same value, CFD = "element of reality" is the answer.
Similarly for Zeilinger: On page 228:
"Calling these elements of reality, of photon i, Xi with values +1(−1) for H′(V ′) polarizations and Yi with values +1(−1) for R(L) polarizations we obtain the relations Y1Y2X3 = −1, Y1X2Y3 = −1 and X1Y2Y3 in order to be able to reproduce the quantum predictions of (16.4) and its permutations [12]."
Notice that the same symbol for a number, Y1, appears in two different equations.
I will honor your statement: "So I have no interest in arguing about it. Sure, call that property "CFD" if you want, I don't care. It makes no difference to the physics."
And I thank you once again for getting me to read Bell's paper, it was long over due.
  • #116
In other words, A(a,λ) is a function that gets evaluated for each run; when it is evaluated it can give either 1 or -1. That's the underlying model, which is what I was talking about.
No, the answer is that in the underlying model there is a mathematical function. "CFD = element of reality" is just some ordinary language verbiage you choose to use to label that function. It has nothing to do with the physics.
  • · Replies 26 ·
  • · Replies 16 ·
  • · Replies 41 ·
  • · Replies 65 ·
10K
