Distributing N balls in B baskets with equal probability.
  • Thread starter Thread starter AntiElephant
    Balls Probability
The discussion focuses on the problem of distributing N balls into B baskets with equal probability, specifically when N < B. The key conclusion is that if N ≥ B, setting P_i = 1/B for all baskets ensures equal distribution. However, when N < B, the probability P_i must be adjusted based on the remaining balls and the basket index, leading to the formula P_i = 1/(B - (i - 1)). The challenge lies in generalizing this approach for any N, as the complexity increases with multiple balls and baskets.
  • Understanding of probability theory and random variables.
  • Familiarity with combinatorial mathematics.
  • Knowledge of induction methods in mathematical proofs.
  • Basic concepts of sequential decision-making processes.
  • Research "probability distribution in combinatorial problems" for deeper insights.
  • Study "induction proofs in probability theory" to strengthen understanding of the proof techniques used.
  • Explore "randomized algorithms" to see practical applications of similar concepts.
  • Investigate "Markov chains" for understanding state transitions in sequential decision-making.
Mathematicians, computer scientists, and students studying probability theory or combinatorial optimization will benefit from this discussion, particularly those interested in random processes and decision-making strategies.
AntiElephant
I have N balls and B baskets. I look at each basket i in turn and decide with some probability P_i whether to insert one ball. After N balls are inserted, I stop. If I look through all the baskets B, I stop; I do not make a second run-through, even if all the balls haven't been inserted. Can I write P_i in such a way that, overall, each basket has an equal probability (which I'll call E_i) of obtaining a ball?
This isn't a homework question so I don't know how difficult this could get. I'm finding it hard to generalise P_i for all N and B. If N \geq B, then P_i can just be a constant number and all baskets have the same probability, because there are enough balls to supply for each basket and the chance isn't affected by whether balls have been inserted in previous baskets. So the assumption is that N &lt; B
P_i seems like it depends on three variables:
N: The number of balls at the start.
B: The number of baskets.
R: The number of balls remaining when we reach i.
Obviously all P_i = 0 when R = 0. The problem would be easier if I could reason that maybe P_i doesn't depend on R when R&gt;0, but I haven't been able to convince myself whether that's true.
The case where N = 1 is simple since I don't have to worry about the variable R:
E_1 = P_1
E_2 = (1-P_1)P_2
E_i = (1-P_1)(1-P_2)...(1-P_{i-1})P_i
E_B = (1-P_1)(1-P_2)...(1-P_{B-1})P_B
One can use this to notice:
(1): (1-P_i) = P_i/P_{i+1}
Our assumption:
E_1 = E_2 = ... = E_i = ... = E_B = 1/B
Therefore
P_1 = 1/B
P_2 = 1/(B-1)
P_3 = 1/(B-2)
Then use induction:
Assume
P_i = 1/(B-(i-1))
Show
P_{i+1} = 1/(B-i)
Which is easily shown with point (1) above. Leading me to the answer:
P_i=(1/(B−(i−1)))
The case for generalising this to any N seems very hard though, especially since the formula for each E_i isn't just one large multiplication like it was with N=1, and is instead an addition of probability of all the permutations in which i obtains a ball, and those permutations don't even have the same probability of occurring. For instance with N =2 for E_3 and P_i(R) I'm looking at:
E_3 = (1-P_1(2))(1-P_2(2))P_3(2) + P_1(2)(1-P_2(1))P_3(1) + (1-P_1(2))P_2(2)P_3(1)
It just becomes a mess to generalise. Is this possible? Can anyone provide some pointers for approaching this? Is there a name for this type of problem?
AntiElephant said:
Can I write P_i in such a way that, overall, each basket has an equal probability (I'll call E_i) of obtaining a ball?
Do you mean "exactly one ball" or "at least one ball" ?
E_1 = P_1
E_2 = (1-P_1)P_2
You haven't defined the variables ##E_i##. It looks like you intend to go through the baskes in order. If no basket gets a ball, do you go through them again in the same order? It looks like ##E_1## is the probability that basket 1 gets a ball on the first attempt to put a ball in it. Is it possible that you'd make a second attempt ?
Thanks for the reply. I mean exactly one ball. You're right, I wasn't clear enough about E_i. I want to adjust P_i so that, if an observer didn't see how the experiment took place, but repeated the experiment a number of times (and tabulated which baskets received a ball), he would conclude that the balls had been distributed randomly amongst the baskets (while making sure not to put more than one in a basket). So I'm aiming for each basket to have a N/B chance of receiving a ball, i.e. E_i = N/B.
I do intend to go through the baskets in order, from 1 to B and once having gone through all of them I stop. I do not make a second attempt. I'll edit my OP to be clearer.
E_1 = P_1
E_2 = (1-P_1)P_2
Our assumption:
Therefore
P_1 = 1/B
P_2 = 1/(B-1)
P_3 = 1/(B-2)
Then use induction:
Assume
P_i = 1/(B-(i-1))
Show
P_{i+1} = 1/(B-i)
P_i=(1/(B−(i−1)))
If ##N \geq B## then putting ##P_i = p## for all ##i = 1,2,\ldots, N## will result in equal occupancy probabilities for all baskets. Basically, when facing Basket ##i## with some balls remaining, pick a ball, then spin a roulette wheel (or whatever) to decide whether to fill Basket ##i##. If you decide to fill it you place the selected ball in the basket; if you decide not to fill it, discard the ball (thus reducing the remaining balls by one.
If ##N < B## one way to achieve equal occupancy probability for each basket would be to first choose ##N## of the ##B## baskets at random (so that each basket has the same probability of being chosen). Then, among the chosen baskets, apply the equal-##P_i## scheme to each in turn. Perhaps this scheme is not acceptable to you, because the process of picking ##N## baskets at random cannot easily be achieved by looking at the baskets sequentially, one-at-a-time.
  • · Replies 0 ·
