Undergrad Divergence & Curl -- Is multiplication by a partial derivative operator allowed?
Divergence and curl are expressed as the dot and cross products of a gradient, leading to questions about the validity of multiplying by a partial derivative operator. It is clarified that this multiplication is a convention rather than an abuse of notation, as it represents applying the operator to a function. However, there are two distinct types of multiplication: one for operators and functions (external operation) and another for functions themselves (internal operation). The associative property does not hold between these two types of multiplication, which can lead to confusion. The discussion also notes that the same symbols are used for different operations, contributing to potential misinterpretations.
Fascheue
Divergence & curl are written as the dot/cross product of a gradient.
If we take the dot product or cross product of a gradient, we have to multiply a function by a partial derivative operator.
is multiplication by a partial derivative operator allowed? Or is this just an abuse of notation
Likes Delta2
I wouldn't say abuse of notation, rather a convention we make that the multiplication by the operator is the same as to apply the operator (to the function).
Likes Fascheue
like this?
\begin{equation*}
\frac{\partial}{\partial x} * y = \frac{\partial y}{\partial x}
\end{equation*}
Couldn’t we then do this?##
\begin{equation*}
\frac{\partial(x^2)}{\partial x} * y = \frac{\partial }{\partial x} * x^2*y = \frac{\partial(x^2y)}{\partial x}
\end{equation*}
Which is not correct.
No, ##\frac{\partial}{\partial x}## is an operator, whilst ##\frac{\partial(x^2)}{\partial x}## is a number.
Likes Fascheue
We have two different multiplications here which you consider to be the same kind but they are not and there is no reason to assume that the associative property holds (because they are different kind of multiplications) and indeed it doesn't hold.
Multiplication 1 (##*##): Multiplication of an operator with a function. This (*) is also called in some books as an external operation because it is between elements from different sets (the set of differential operators and the set of functions)
Multiplication 2 (##\cdot##): Multiplication of two functions, this is an internal operation because it is between functions, i.e elements of the same set the set of all functions.
We have no reason to assume that the associative property holds between these two different operations that is that ##(a*b)\cdot c=a*(b\cdot c)## and indeed it does not hold in this case.(##a=\frac{\partial}{\partial x}, b=x^2, c=y##).
You got one point here though, that we use the same symbol for these two different operations, so we have a little abuse of notation (or symbols) here indeed.
Likes Fascheue and etotheipi
Are there also two kinds of dot products then? One involving multiplication 1 and the other involving multiplication 2?
΅Well yes this dot product ##\nabla\cdot \vec{E}## is different than this ##\vec{E}\cdot\vec{E}## though we use the same symbol.
Likes Fascheue
