What Does Divergence-less Field Imply in Griffith's E&M Theorem 2?
  • Thread starter Thread starter DuckAmuck
    Fields
The discussion centers on the implications of having a divergence-less field in Griffith's E&M Theorem 2. It establishes that if the divergence of a vector field F is zero, then F can be expressed as the curl of another vector field A. Participants clarify that the integral of F over a closed surface equals zero due to Gauss' theorem, as the divergence is zero. They also discuss how the surface integral of F is independent of the surface chosen, concluding that splitting the surface into two parts results in equal and opposite integrals. Overall, the conversation emphasizes the relationship between divergence, curl, and surface integrals in electromagnetic theory.
DuckAmuck
So I am reading through Griffith's E&M and am on page 54. (This isn't a homework problem). He has a "Theorem 2" where he says if and only if you have a divergence-less field can you have these following conditions.
So if you have a field Div F = 0, then F = Curl A. That's easy.
Here is the confusing part: Then he says integral over the surface of F.da is independent of surface and integral over the surface of F.da =0 for a closed surface.
I am not sure how to prove these things. I get 0 as a result no matter what because of the levi-cevita symmetry. Please could somebody let me know what I am doing wrong.
Thank you so much.
-DA
It follows from Gauss' theorem. The flux of a vector field F out of a closed surface is equal to the integral of the divergence of F over the volume bounded by that surface.
Okay, so I don't need to introduce Curl A?
I just say Integral over S of F.da = Integral over V of Div F?
How then do I show it's independent of surface?
It's only independent of the surface if div F = 0.
If div F = 0, then clearly ∫ div F = 0 no matter volume you do the integration over.
I see. It's because Integral over 0 is Cdxdy = Cdydz = Cdxdz and the only way that can work is if C = 0.
How do you then show that integrating over an open surface results in something independent of surface?
Likes Aasish
Integrating what over a surface? A zero vector field?
Yes. Integral over an open S of F.da, when Div F = 0. How is it indep of surface? Is it that since S1 + S2 = S (where S is a closed surface), integrating F over S1 would result in the opposite of integrating over S2? Since the results are equal but opposite, the integral only depends on how the surfaces are split?
How do you show this symbolically?
Yes, that's correct. We write that symbolically like this:
\int_{S_1} F \cdot dA + \int_{S_2} F \cdot dA = \int_{V} \nabla \cdot F = 0
So,
\int_{S_1} F \cdot dA = - \int_{S_2} F \cdot dA
Okay, so then you use Stoke's Theorem to get a path integral. Thank you so much dx :)
One way to get the same result, w/o introducing line integrals, would be as follows.
You have a divergence-less vector field F, so you know:
\nabla \cdot F = 0
and
F = \nabla \times A
for some vector field A. From Gauss we have that:
\large{ \int_V (\nabla \cdot F) dV = \int_{\partial V} F \cdot dA }
where V is any arbitrary volume, and \partial V is the closed surface that defines its boundary. Since \nabla \cdot V = 0, we conclude that the surface integral of F over any closed surface must be zero:
\int_{\partial V} F \cdot dA = 0
Furthermore, since F must be the curl of some vector field A, we can further conclude that:
\int_{\partial V} (\nabla \times A) \cdot dA = 0
or in other words, that the surface integral of the curl of the vector function A over a closed surface must be zero.
  • · Replies 20 ·
