Divergent Sequence Homework: Determine Convergence
The discussion focuses on determining the convergence of the sequence defined by an = n^n / n!. The sequence diverges as n approaches infinity, confirmed by evaluating the first six terms, which increase significantly. The participants explore using limits and the squeeze theorem to support their conclusion, noting that the factorial in the denominator grows slower than the exponential in the numerator. A suggested approach involves factoring the expression to show that n^n / n! remains greater than or equal to n, leading to the conclusion that the sequence diverges to infinity. The final consensus is that the sequence is indeed divergent.
titasB
Determine whether the sequence is convergent or divergent
an = {nn / n! }
an = ( n . n. n ... n ) / 1 . 2 . 3 ... n )
⇒ an =n [ ( n . n. n ... n ) / 1 . 2 . 3 ... n ) ]
⇒ as n → ∞ , an → ∞
This is further confirmed by finding the values for the first 6 terms : 1, 2, 4.5, 10.67,26.04,64.8...
I'm not sure if this is sufficient however. Can we explain this using limits? If so wouldn't that give an indeterminant form? Of course the factorial on the denominator will always be smaller than nn but can this be shown using limits? Any help would be nice :)
Hint: Can you show that
$$\frac{n^n}{n!} \geq n$$
So something like this:
we can see the expression in the brackets approach infinity since the numerator is much larger than the denominator so,
∞ ≥ an ≥ n
and since n → ∞ this gives : ∞ ≥ an ≥ ∞
and so, an → ∞ as n → ∞ by squeeze theorem ⇒ the sequence is divergent
I think you need to be more precise. How many ##n##'s are there in the numerator of your second expression? Can you quantify "the numerator is much larger than the denominator"?
Consider factoring as follows:
$$\frac{n^n}{n!} = \left(\frac{n}{1}\right) \left[\left(\frac{n}{2}\right) \cdots \left(\frac{n}{n-1}\right)\left(\frac{n}{n}\right)\right]$$
Now look at the factors enclosed in the square brackets. Each factor is ##\geq 1##, so the product in the square brackets is ##\geq 1##. What can you conclude?
nn/ n! ≥ n
titasB said:
nn/ n! ≥ n
Right, now the rest of the argument works as you stated. The inequality shows that as ##n \to \infty##, the larger expression ##n^n / n!## must also diverge to ##\infty##.
Likes titasB
Awesome thanks so much!
  • · Replies 34 ·
