Division algorithm for polynomials
The discussion focuses on applying the division algorithm for polynomials to find polynomials q and r such that x^M - 1 = q(x^N - 1) + r, where M and N are positive integers with M > N. The user initially rewrites the equation and identifies that q must be of a certain degree but struggles with the next steps. They recognize that x - 1 is a factor of x^M - 1, leading to the conclusion that q(x) can be expressed as a sum of terms. The conversation emphasizes using the division algorithm effectively and encourages practice with simpler examples to clarify the process. The discussion ultimately aims to solve for q and r in the polynomial division context.
Kate2010
M and N are positive integers with M>N. The division algorithm for integers tells us there exists integers Q and R such that M=QN+R with 0\leqR<N. The division algorithm for real polynomials tells us that there exist real polynomials q and r such that xM - 1 = q(xN - 1) + r with r = 0 or deg r < N. Find q and r.
I have rewritten it as xQN+R - 1 = q(xN - 1) + r, so I think q must be of degree QN+R-N = N(Q-1)+R
However, it is not then always (in fact more likely not) true that N(Q-1)+R<N so 1 must have more than 1 term. But I am struggling to know where to go from here.
Thanks for any help :)
Take p(x) = xm - 1. What are the roots of p(x)? There is a clearly a root, 1, so x-1 is a factor. Now divide p(x) by x-1.
So I get to
xM-1 + xM-2 + ... + 1 = q(xM-1 + xM-2 + ... + 1) + r
But I don't know what to do now?
You are trying to figure out q and r in: xM - 1 = q(xN - 1) + r
You are aware that x-1 is a factor, which is clearly of the form xN - 1 (N=1). That gives you a hint on what the degree of r is.
You have also correctly identified the polynomial q(x) = 1 + x + x2 + .. + xm-1. So what is (x-1)q(x)? Does this give you your original polynomial xM - 1? So then what is r?
Why don't you use the division algorithm? Practice on something like x^14-1=q(x^3-1)+r. It's actually pretty easy. You just have to replace the numbers with M, Q, R and N.
Sorted! Thanks for all the help :)
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 24 ·
  • · Replies 16 ·
