Do AEST (Absolute Euclidean Spacetime) models work?
83 replies · 8K views
name123 said:
The mass of a photon is referred to quite often. I've private messaged you.
Because of this, I feel that this (and possibly other conclusions)
would classify this as a non-mainstream theory.
name123 said:
TL;DR Summary: My question is, does the AEST approach work, while preserving proper time momentum, and flat Euclidean spacetime (even with gravity), or are there problems with it?
So, as I am sure other earlier responses have suggested, there are problems with it.
So, I think this question has been answered.
While aspects of it may be of interest,
I do not think this Special and General Relativity forum is the appropriate place to continue an extended discussion on it and its many facets.It may be appropriate to discuss one clearly-defined issue at a time,
but not a whole set of issues arising from a non-mainstream theory.
This is just my opinion... but I came to PhysicsForums because I wanted to focus on mainstream physics.
on Phys.org
name123 said:
I don't see any incompatibility there
That is more of a problem than anything else.
You have had several problems pointed out. And with a handwaving “absolute spacetime solves all of my problems” (I am not convinced on that point) you march on and use relative spacetime when it suits.
You are trying to have your cake and eat it too. Either you have a relative spacetime with all of the acknowledged problems and you can adopt a convention of rest or you have an absolute spacetime and you cannot adopt a convention of rest (even if the absolute spacetime doesn’t solve the acknowledged problems)
name123 said:
But without any experimental way of determining whether an object is at rest in relation to absolute spacetime, those using the model by convention just assume one to be to get the results.
And this really doesn’t work. Since you cannot know which is the absolute frame but since only the absolute frame supposedly fixes the problems then you can never know if you have fixed the problems.
The foundations of this approach are shaky and full of holes.
Can you explain how the absolute frame supposedly fixes all of the problems identified above? I remain very skeptical
robphy said:
It seems to me that this author's approach has a nonzero "mass of the photon", which is at odds with our current understanding
And at odds with current experimental evidence.
For a point of organization, let’s leave off the photon mass discussion, and focus on the “Euclidean spacetime” (space-proper time) issues. The community has identified the following problems with the space-propertime approach:
1) the points are not themselves physically meaningful
2) worldlines intersecting doesn’t imply nearby objects and vice versa
3) causes can come after effects
4) light rays retrace themselves making a light clock essentially impossible to analyze
5) the concept doesn’t even apply for light rays since it gives a division by zero
6) (did I miss any?)
It is claimed that “absolute” Euclidean spacetime somehow solves those problems. How? I really don’t see it.
1) The points do make it meaningful that there is a physical distinction between proper time and the time parameter in the model, even if it isn't possible to establish what is at rest in absolute spacetime. Thus a photon would be thought to move in absolute time, but not in proper time.
2) World lines intersecting in which Fig that I supplied?
In Fig 2 they would imply being in exactly the same parameter time at the point of intersection, and there would be 0 spacetime distance.
If Fig 3 the line length will tell you whether they are at the same point in parameter time, and they would be 0 spatial distance I think, though there could be a distance in proper time.
In Fig 4, the Minkowski diagram, they would be at exactly the same parameter time, and there would be be 0 spatial distance, but you couldn't tell by looking whether there was any distance in proper time.
3) The paper explicitly denies this is the case. But please explain how that is so given that the angle can't be larger than 90 degrees, or rather if it is then in AEST theory (but not I guess in relative Euclidean geometry), as I mentioned, a particle is interpreted as the reversal of intrinsic properties such as charge and spin.
4) Light rays would only appear to retrace themselves in Fig 3 because their movement in parameter time is not shown. That would not be the case for Fig 2 or Fig 4.
5) What concept doesn't even apply for light rays?
There is already a distinction between coordinate time and proper time. That is not relevant.
The issue is that the space-propertime diagram is composed of points that have no physical meaning. If you dispute this then kindly write down the physical meaning of the points. What distinguishes one point in space propertime from another?
Physically different points in spacetime represent things that happened at different times (physically measured with clocks) or different places (physically measured with rulers). It is a clear physical meaning. There is no similar interpretation for space propertime that I know. Two different points in space propertime can happen at the same time and place.
E.g. in the figure that @Ibix supplied.
Look at the diagram by @Ibix The points where the two traveling twins meet the home twin are the same event. A signal from the “later” one could be sent to the “earlier” one.
Once you include coordinate time as an axis, the diagram is no longer Euclidean.
The foundational idea that all objects travel through space propertime at ##c##.
Anyway, it is becoming clear that you are not interested in learning what is wrong with this concept. You simply want to promote it.
I see little value in continuing this thread. Your stated question has been answered.
As @Ibix already showed, an example for this can be seen in the Epstein diagram of the twin paradox. When the twins meet again, ##A## has aged by 26 years and ##B## only by 10 year. Therefore, they are shown at different points on the ##\tau## axis.
Source (see points A and B):
https://www.relativity.li/en/epstein2/read/c0_en/c7_en
So photons don't move through proper time in TR?
I thought Montanus was pointing out that in the Minkowski Diagram (Fig 4 attachment #55) the time is actually the parameter time, and in TR that is proper time I thought. And I thought the photons did move in that time in TR. If that is so then that is a clear physical difference between the two models, and why I guess Montanus was pointing out that people in TR had mistaken it for a spacetime diagram.
I was under the impression that the different points in spacetime represent things that happened at different time (measured by clocks), or different places (physically measured with rulers).
A bit like with Newtonian physics. Where space and time were considered absolute. There was still the issue of a frame of reference with space. And there is still that issue with a frame of reference for space with space-propertime. I was under the impression that the difference with Newtonian physics and space-propertime was that the clocks could not be expected to all tick at the same rate. The rate at which the clocks would tick would depend on the velocity in space, since as mentioned the theory does contain the postulate that: in the absence of gravitation all objects move with a four dimensional Euclidean velocity equal to the speed of light in a vacuum. Thus the more one moves in the space dimensions, the less one will be moving in the proper time dimension. And that will be reflected in the time that one clock ticks compared to another.
It seems to me that you have misunderstood the diagram. But I realise it could be me that is having a problem understanding what you are saying.
If you look at the diagrams I supplied in #55. The diagram supplied by @Ibix is a Fig 3 type diagram. But look at a Fig 2 type and imagine that type of diagram of it. It would be clear that the when the twins meet back up it is at the same parameter time. One wasn't earlier. What the difference in proper time in Fig 3 type diagram represents is that the proper time of one twin is different to the proper time of the other. That their proper times are different isn't a causality issue.
Seems strange you would say that when I answered each thing you wrote.
In standard relativity, the concept of "proper time" is not even applicable to photons. Lightlike objects are fundamentally different physically from timelike objects. The concept of "proper time" is only applicable to timelike objects.
It is coordinate time in whatever inertial frame the diagram is being drawn.
No. Coordinate time is not the same as proper time in standard relativity.
It appears that not only do you not understand AEST, you also don't understand standard relativity.
In any inertial frame, points on a photon's worldline map one-to-one with values of coordinate time. But, as above, coordinate time is not the same as proper time, and the concept of "proper time" is not even applicable to photons.
That's true, but it's beside the point. If two worldlines in spacetime meet at a single point, that means those two objects physically met each other. But if two "worldlines" in space-propertime meet at a single point, that tells you nothing physically at all. That's the objection @Dale was making. You have not answered it.
The same coordinate time in any inertial frame. Or, more important, the same point in spacetime.
No, but it is an issue for space-propertime, since it means a single physical event--the two twins meeting up again--is not represented by a single point in space-propertime. This is one illustration of the fact, already mentioned, that points in space-propertime have no physical meaning, unlike points in spacetime.
No, you haven't. You have answered nothing whatever. See above.
Ok, well there is a difference there then. In AEST proper time is applicable to photons. It is just that they don't move through it. And I assume in AEST there is no distinction between lightlike objects and timelike objects. And that there is no need to perform the operation you did in
PeterDonis said:
[PeterDonis didn't write this, just not sure how else to provide link to post]
I think that was what Montanus was considering a mistake that has taken place in TR. That from the diagrams I supplied in #55 you can see where the Minkowski diagram comes from. I'll just requote what his thoughts on it were.
"The projection of the full diagram in Fig. 2 to the diagram in Fig. 4 illuminates why there is a light cone in the Minkowski diagram and a gap outside the light cone. It also illuminates that the trajectories of the objects moving in the AEST at an angle φ and −φ are mapped on the same trajectory in the Minkowski diagram. The present approach makes clear that the Minkowski diagram actually is a space diagram extended with a parameter axis. If one regards (erroneously) the time parameter as the simultaneous
fourth coordinate for all the objects, the diagram in Fig. 4 then will be mistaken as a space-time diagram. Unfortunately this is the situation in the TR. Together with the aforementioned inconsistent definition of distances it leads to an illogical and contradictive model for spacetime."
But you seem to be stating that in TR when establishing the coordinate time of an observed object in a different frame of reference, the proper time of the observer is not a parameter. And therefore he is wrong to think that the Minkowski diagram is actually a space diagram extended with a parameter axis.
I thought I gave quite an extensive answer, which evolved explaining that the information it gave depended on what type of diagram the worldline was in. And explained the difference whether it was a Fig 2 type, Fig 3 type, of Fig 4 (Minkowski) type.
Regarding the Fig 3 type explanation you even wrote:
Ok, it seems to me that space-propertime is compatible at least with a past present future conception of time (I actually cannot see how else to view it without considering it to have 5 dimensions, but that might just be me). If so then the 4D Euclidean spacetime replaces the 3D Euclidean space of Newtonian physics. And thus for any point in parameter time, if two entities have the same space coordinates they will have met up. But, in the 4D Euclidean spacetime used, it wouldn't be a point like in the 3D space used in Newtonian physics, as there is an extra dimension, propertime. And so in the 4D Euclidean spacetime it would be a line. A line on which all points have the same space coordinates, but which have different propertime coordinates. As people could meet up with a range of different values on their clocks. And going further, it also seems to me as a layperson, propertime seems to reflect the idea of clocks slowing down when they move relative to absolute spacetime.
  • Skeptical
You still have not addressed my key point from my very first post which I have repeated multiple times. If you were interested in learning you would try it, but you are interested in pushing your concept.
Please provide a physical description of what physically distinguishes two points in space-propertime. What is the physical meaning of points in such a diagram?
Spacetime has physical meaning, space propertime does not. You are arguing without learning.
Proper time is not defined on a null worldline. Instead an affine parameter must be used.
See, here you are just making a weak argument rather than saying "oh yes, that is a problem". A space-propertime diagram, as shown by @Ibix, is very problematic. We tell you it is problematic and your response is not to say "yes it is problematic" but to say "well a different kind of diagram is not problematic". Pointing to a spacetime-propertime diagram doesn't fix a space-propertime diagram. It tacitly acknowledges the problem. If a space-propertime diagram worked then why would they need to introduce a spacetime-propertime diagram?
The issue is that a space-propertime diagram is very unnatural and non-physical. As I mentioned above and which you still have not addressed there is no physical meaning to the points in a space-propertime diagram. The points in a spacetime diagram have a physical meaning and the worldline parameters also have a physical meaning in spacetime.
It makes no sense to treat the parameters as a coordinate. For one, each worldline has its own parameter, that is why we can use proper time for timelike worldlines and an affine parameter for lightlike worldlines. For two, that parameter is only defined along that worldline, so it doesn't make sense to treat it as though it were defined elsewhere. It is inherently problematic to represent proper time as it is represented in a space propertime diagram.
Here is the issue. See the annotated diagram. Points A, B, and C are the same event. That is the first collision/reunion event. A pulse of light emitted at point D can affect points A, B, and C. So it is clear that in this presentation effects (A) can precede causes (D). Remember, worldlines in a space-propertime diagram don't have to intersect to actually be at the same place and time, so the fact that lightlike lines go at 90 degrees has no bearing on whether or not effects can precede the cause.
name123 said:
It isn't just re-writing the math of standard SR because as you can see from the list of papers above one is called "General relativity in an absolute Euclidean space-time". And it uses flat Euclidean geometry even in situations with gravitation, and has the concept of absolute time.
The way Carroll L. Epstein introduces it (here is the book online version), it is definitely just a different geometrical interpretation of the same SR & GR math. Basically a different type of diagram showing some things that a Minkowski-Diagram doesn't, but also missing some things.
Different types of diagrams have different interpretations for elements in them. In classical physics we use different diagrams too: time-position, time-velocity, position-velocity, ... Nobody is expecting that all diagram elements like points, path lengths or path crossings have the same physical meaning in all of them, or are equally meaningfull.
Yes, the graphical elements of different diagrams have different meanings, that is in fact the concept I am trying to convey. It seems that the OP does expect that the points in a space-propertime diagram are physically meaningful, despite my harping on this issue non-stop.
It does not. The past present future organization is discarded as I showed above in the annotated version of @Ibix 's diagram.
It does indeed do this, but that is all it does. That is why we are showing other examples of things it does not do. If you want to claim that something "works" then you probably need to specify what you claim it works for. As a general model of physics, it does not work. As a nice graphical indicator of time dilation it does work, and that is about it.
And as soon as you introduce SR's coordinate time ##t## then you are no longer using a space-propertime diagram and no longer using a Euclidean metric. In order to make the space-propertime diagram work for more than just time dilation you have to augment it with coordinate time. It is then no longer Euclidean and it is no longer space-propertime. The need to do this shows the stringent inherent limitations that you have yet to acknowledge about a space-propertime diagram.
Okay, clarifying this is important. But I don't see it as an argument against using space-propertime diagrams, along with space-coordinatetime diagrams. Some diagram elements are more meaningful in a space-propertime diagram, where the path length is the coordiante-time interval. In a space-coordiantetime diagram the path length has no directly interpretable meaning, and you need additional math to compute the proper-time interval from it.
Bolding above by me.
Sure, one can have supplementary drawings and plots (like space-propertime or space-space or whateverElse-whateverElse2).
But
one cannot dispense with the Minkowski spacetime diagram (with its Minkowskian spacetime geometry) for special relativity, as these many alternative approaches attempt to do.
Nor do I. It is fine to use space-propertime diagrams for what they are useful for.
They are not useful as a Euclidean spacetime to replace standard Minkowski spacetime. Space-propertime is not simply a Euclidean spacetime. This thread is about whether or not “Euclidean spacetime” works. The OP and his favorite author don’t want to just use space-propertime diagrams for what they are useful for, but rather as a Euclidean replacement for spacetime. The point I am making about the points is crucial for understanding why that overly ambitious goal doesn’t work.
And this means that points in space-propertime can't have any physical meaning for light, any more than they do for timelike objects.
First, you shouldn't assume. You should know. If you don't know even something as basic as that about AEST, what's the point of this thread? Aren't you just wasting everyone's time?
Second, the distinction between lightlike and timelike objects is a physical distinction. You can observe it in experiments. One obvious observation is that you can't change your speed relative to a lightlike object: if you accelerate towards it, it doesn't slow down relative to you, as a timelike object does, it blueshifts. Any theory that does not capture this obvious physical difference is just wrong.
I have no idea what you are talking about here.
Montanus' claim that there is a mistake in standard relativity is one of the main reasons why he is considered a crackpot. The standard spacetime model of relativity makes precise quantitative predictions about experimental results that have been verified to many decimal places. That includes the parts of the model that Montanus claims contain a "mistake".
Montanus' thoughts here look like word salad to me. He is trying to claim that standard spacetime diagrams in flat Minkowski spacetime are somehow invalid. That doesn't even pass the laugh test. Again, the fact that he makes such claims with apparent seriousness is one of the main reasons why he is considered a crackpot. It's as if he were to claim that standard arithmetic is somehow wrong because mathematical objects like 1, 2, and 3 actually aren't valid numbers.
Your statement here doesn't make sense. There is no such thing as "the coordinate time of an observed object". Coordinate times belong to events, not objects.
As for transforming the coordinates of events from one inertial frame to another, it should be obvious from the Lorentz transformation equations that "proper time" is not a parameter in such transformations.
You thought wrong. That's because, as I have already stated, you do not appear to have a good understanding either of AEST or of standard SR. Which, again, makes me wonder if this whole thread is not a waste of time. Maybe Montanus himself could come here and at least give some kind of substantive response to the concerns being raised (though from what I've read so far of what he wrote, I doubt it). But he's not posting here, you are, and it certainly doesn't seem like you can. So what's the point?
All of this looks like word salad to me.
After moderator discussion, this thread will remain closed. The OP question has been addressed. Thanks to all who participated!
