Do Bohmian photons exceed light speed in the double slit experiment?
64 replies · 24K views
PRODOS said:
In the double slit experiment, Bohmian Mechanics http://plato.stanford.edu/entries/qm-bohm/#2s" the paths of real particles traveling from the two slits to the detector to look like something like this:
The above image shows particles traveling in non-straight paths.
It may surprise Demystifier :smile: but you can actually define a Bohmian QM
without anything moving faster than c. (for mass and mass less particles)
Because particles can't move faster as light but voids can.
To illustrate this, below the void "0" moves 8 positions to the right.
1101111111111 ==> 1111111111011
But this is just the same a eight ones "11111111" moving only a
single position to the left, that is at 1/8 of the speed. The void
can in principle move at any speed but the guiding wave is which
controls the "motion" of the void is limited by c.Regards, Hans
PRODOS, from drawing trajectories in space, nothing can be concluded about their time dependence. Consequently, nothing can be concluded about their velocities (except their space direction).
Concerning Question 2, the answer is yes if the wave function has a definite frequency. But in general it does not need to be so. Trajectories attaining A (or Y) at different times may have different shapes in space as well.
Thanks Demystifier.
As usual, you've given me plenty to think about and to study further.
:smile:
Demystifier said:
Thanks for the paper!
One comment: All such paradoxes emerge from the assumption that photon is ONE object. In the Bohmian interpretation there are actually two objects (wave function AND particle) and all such paradoxes trivially disappear.
But of course, most physicists find simpler to deal with a number of paradoxes than to accept a terribly complicated hypothesis that the photon consists of two objects.
From talking to members of the foundations community, I have the impression that their complaint isn't with the BM wave per se, but with its superluminal influences. Most of the physicists I've spoken with at foundations conferences are just not willing to invoke "spooky action at a distance" to resolve QM paradoxes.
But Bell has shown that superluminal influences are not an exclusive property of BM per se, but of ANY theory (compatible with QM) claiming that reality (i.e., objective physical properties existing even without measurements) exists. My impression is that most physicists who complain about superluminal BM influences are not aware of this general Bell's result.
Yeah, and even then it isn't so much superluminal influence as it is non-local effects.
It isn't sending signals between point A and point B at v > c, it is influence between point A and point B in t = (more or less) 0, as if the two points were not separated in a spacelike manner.
There are other possibilities as well, for example if influence were transmitted from point A to point B at v < c, but t < 0, farewell causality you say, but the effects would be as far as I know indistinguishable from A to B in t = 0.
Bohm's interpretation is useful to help consider what is actually happening, just as the Copenhagen is, but it is unlikely that they are remotely accurate phenomenological descriptions of reality.
I'm sure you're right in general, I've met physicists who have never heard of EPR-Bell phenomena. But, those in the foundations community are more knowledgeable and do appreciate that Bell's theorem entails giving up separability or locality -- unless, for example, there is information flow from the future (which is the basis for many so-called "backwards causation" interpretations, see the focus issue in Studies in History and Philosophy of Modern Physics 39, Nov 08). There is no interpretation that generates consensus in the community at this point. I suspect the only way a new interpretation will find widespread acceptance is that it yields new physics, because the conceptual cost must be outweighed by the scientific value and, as Bell has shown, there will be conceptual cost.
Well one can still argue that we deal with 'non-classical correlations' without any 'action-at-distance' involved. How can Nature conspire, in non-classical ways, to produce the appearance of action-at-distance is another thing but I wouldn't take lightly the 'conspirational hypothesis'; superdeterminism for example is fully compatible with all experiments conducted so far (it may lack 'le bon sens', to quote Duhem, but counterfactual definiteness is by no means untouchable).
And a few questions regarding Bohmian Mechanics (as I see you know it very well):
1. How it is explained within BM the fact that electrons do not fall into the nucleus? (as far as I know Vigier proposed the hypothesis that a radiation of very long wavelength is indeed emitted by the electrons but we aren't yet capable to measure it).
2. If the guiding wave affect the particle shouldn't the particle affect the wave as well? If the answer is yes how is this happening?
3. Why is Lorentz invariance so important? As far as I know there are indeed reformulations of Special Relativity - involving some changes at the level of the basic postulates but indistinguishable at the experimental level from the classical solution (based on the usual Lorentz transformations) - where a preferred frame of reference is accepted (thus fully compatible with Bohmian Mechanics). But my point is that although (local) Lorentz invariance is part of the accepted methodologies in Physics (I accept that it has a provisional edge over the alternatives) it is by no means required with necessity by the observed facts (anyway the Brans-Dicke theory etc are still with us). I wouldn't be surprised if a final (successful, the 'winner') TOE is not Lorentz invariant...
4. Why the density of probability P tends towards |PSI|^2, isn't this an ad-hoc hypothesis? (some accuse the ad-hoc nature of Bohm's explanation, namely that the value of P is pushed towards |PSI|^2 by aleatory interactions and the quantum dynamics, more or less like in the classical statistical mechanics).
5. Do you believe that a non-trivial change at the level of the basic postulates of QM could make a difference between the existing interpretations of QM, by pointing towards a clear 'winner' (possible an unconceived yet alternative)?
6. Are there other promising (non-local) hidden variables programs?
7. The spin?...but of course there is no real problem to consider it a phenomenological property
The quantum force (i.e., the force resulting from the quantum potential) is such that it prevents them to fall into the nucleus.
The answer is - no. (Otherwise, it would be in contradiction with standard QM.)
Fundamental Lorentz invariance is not necessary. However, since we need Lorentz invariance at least at some phenomenological level, a fundamental theory can explain phenomenological Lorentz invariance more easily if the fundamental theory itself is also Lorentz invariant.
Valentini has found a quantum version of the Boltzmann H-theorem, showing that the distribution will approach the equilibrium distribution |PSI|^2 even if it starts from an arbitrary distribution.
Yes I do. For a recent attempt in that direction see
http://xxx.lanl.gov/abs/0811.1905 [Int. J. Quantum Inf. 7 (2009) 595-602]
There certainly are other nonlocal hidden variables programs. Personally, I don't find them very promissing.
According to the Bohmian interpretation, particles do not really have spin. Instead, the appearance (or illusion) of spin is caused by the wave function, i.e., by quantum forces that change particle motions in such a way that they make illusion that particles have spin.
I don't know about Bohmian Mechanics(BM) very well. Please tell me some things.
Bohmian Mechanics is based on the quantum mechanics, isn't it?
The orbital angular momentum of the electron in the S orbital is zero.
So the electron in the S orbital is not moving in BM? (If the quantum forse prevents the electron to fall into the nucleus in S orbital.)
A nucleus with a large charge will cause an electron to have a high velocity. A higher electron velocity means an increased electron relativistic mass, as a result the electrons will be near the nucleus more of the time and thereby contract the radius for small principal quantum numbers. http://en.wikipedia.org/wiki/Relativ...ntum_chemistry
The relativistic effect shows that the electron is actually moving fast.
How do you explain these relativistic phenomina and electronic motion in BM?
If the size of the electron is too small(about classical radius), by equating the angular momentum of the spinning sphere to 1/2 hbar, the sphere speed leads to 100 times the speed of light. How Big is one electron in BM?
The spin g factor is about 2. This means that the mass and charge of one electron is separated . How do you explain this g factor?
I said that electrons do not move according to the classical laws. I did not say that they do not move at all.
The relativistic effects that you refer to are properties of the wave function. In BM, the wave function is exactly the same as that in standard QM. However, in BM the wave function of the electron is not identified with the electron itself. Yet, the wave function determines the motion of the electron, in such a way that observable properties of the electron are exactly the same as those predicted by standard QM.
In BM, electron is pointlike. It does not spin.
BM explains the g factor in the same way as standard QM does - as a property of the wave function.
In all your questions, you seem to be missing the crucial point of BM: the electron and the wave function of the electron are not the same. Yet, the latter determines the motion of the former.
I think that you say Bohmian Mechanics is the same thing as the quantum mechanics.
What's the meaning of the BM?
You say the electron and the wave function are not the same.
So, does the electron have the charge and mass? Or does the wave function have the charge and mass? What is the electron? (mass ? charge? )
Spin has a magnetic moment. The magnetic moment is caused by the movement of the charge. Do you say the wave function has the charge?
This is a familiar argument, but it makes the unnecessary assumption that the
net remaining charge that we measure is entirely responsible for the magnetic
moment (which is indeed impossible).
However. in a vacuum which admits both positive and negative charges there
is more charge available to generate magnetic fields as the net charge density,
which is merely the difference between the positive and negative charges.
As far as Quantum Electro Dynamics goes: The remaining net charge of an
electron is an exceedingly small part of the "real charge" of the electron which
is shielded by opposite charges due to vacuum polarization.
Regards, Hans
Regards, Hans
It seems that the Bohmian mechanics is the same thing as quantum mechanics and QED.
So Why does the Bohmian mechanics(BM) exist?
And Demystifier said that the electron and the wavefunction are not the same thing in BM.
So what is the electron(charge and mass)?
If both the electron and the wavefunction have the charge and mass, what is the difference between them?
And do you say that the charge and mass of the electron is meaningless?
The effective charge and mass which causes spin magnetic moment can change?
I'll let Demystifier speak for Bohemian Mechanics since this is his area.
In QED (or in molecular modeling) you have to assign to each point of a wave
function quantities like:
- charge density
- current density
- axial current density
- magnetic moment density (magnetization)
- polarization (electric moment density due to a moving magnetic moment density)
- mass density
- energy and momentum density
- spin density
- Hamiltonian and Lagrangian density
These quantities are expressions using Dirac's formulation of the
electron wave-function. The field quantities like charge/current
density and magnetic moment density result in electromagnetic
fields which have to be taken into account when calculating
interactions.
Regards, Hans
No, I do not say that.
In a version of the theory in which the effects of quantum field theory are ignored, the electron has both charge and mass.
The magnetic moment is caused by the movement of the charge in classical mechanics. However, it is not (necessarily) so in quantum mechanics.
You said the relativistic effects are properties of the wave function. So the relativistic effect is not directly related to the velocity of the electron? Is that really so?
In the relativistic theory, the velocity of the particles is equal to the velocity of us (in the opposite direction).
If the relativistic effect is not related to the velocity of the electron, when we move faster, doesn't the relativistic effect of the electron change ? (from our viewpoint)
If you say the electron is actually moving in BM, how is the elecron in the S orbital moving?
Why doesn't it radiate energy ? (the electron has charge as you said.)
And you said the electron is pointlike. So by equating the angular momentum of the spinning sphere to 1/2 hbar, the sphere speed leads to more than 100 times the speed of light.
You said the electron has mass. Is the mass of electron not related to the 1/2 hbar?
What causes 1/2 hbar?
And the spinning electron will go back to itself when it is rotated by an angle of 4pai (not 2 pai). If the electron is pointlike, is there a differense between 2pai and 4pai?
Yes, that is so.
Yes it does. But it can also be described by the relativistic change of the wave function.
For a proper treatment, radiation must also be described quantum mechanically, not in terms of continuous radiation, but in terms of photons. Thus, you need a Bohmian interpretation of quantum field theory, which is a more difficult subject. If you are interested, I can give you appropriate references.
Mass of electron is not related to the 1/2 hbar. 1/2 hbar is caused by a 4-component (or 2-component in a non-relativistic limit) spinor wave function described by the Dirac equation.
No, it is the spinor wave function that goes back to itself when rotated by an angle of 4pi (not 2pi).
Demystifier said:
"In the relativistic theory, the velocity of the particles is equal to the velocity of us (in the opposite direction).
If the relativistic effect is not related to the velocity of the electron, when we move faster, doesn't the relativistic effect of the electron change ? (from our viewpoint) "
"And the spinning electron will go back to itself when it is rotated by an angle of 4pai (not 2 pai). If the electron is pointlike, is there a differense between 2pai and 4pai?"
The spin is an actual thing (not only spinor wave).
Some experiments (which were independently performed by different teams) showed that the spinning neutrons went back to original forms when they are "actulally" rotated by an angle of 4pai (not 2pai).
(H. Rauch et al. Phys.Lett. 54A (1975) 425)
Do you say the spin of the neutron is different from the spin of the electron?
And how is the electron actulally moving in the S orbital in BM?
Not really. Spin is measured by the Stern-Gerlach apparatus which actually determines the POSITION of the particle. We only INTERPRET the change of position as being due to the intrinsic magnetic moment.
I will take a look and comment later.
Edit: I've just did it. They don't really measure any rotation of the neutrons. They just measure interference, which is theoretically explained by rotations of wave functions.
Not really. (Although there are some differences because neutron is a composite particle.)
Here is a deal: Write me the wave function for the S orbital and then I will tell you how the electron moves.
Demystifier said:
Actually, my area is Bohmian (not Bohemian) mechanics. :wink:
Oops :-p
Demystifier said:
But you may be surprised that I made a contribution to the "Bohemian" as well: :biggrin:
http://xxx.lanl.gov/pdf/physics/0702069 [Am.J.Phys.76:143-146,2008]
(See the lyrics after the Abstract.)
:smile:
The experiment (Phys Lett. 54A 1975 425) measured spatial rotation of the neutrons.
Did you really read this paper or something about this experiment?
They actually "spatially" rotated the neutrons by an angle of 4pai using "rotation by precession" in this real world . (The result is just consistent with 4 pai. It is not accidential.)
Spatiall rotation is consistent with the rotaions of spinor wavefunction ( you say spatial rotation is different from the rotation of the spinor wavefunction.)
Of course, we can not look at the spinning neutrons directly.
So they measured interference. (you say only about this last step. you didn't say the method of rotaion (this is most important.))
In my personal view, I DON'T believe "the spin of the electron".
But you believe in the quantum mechanics. So you misunderstand this experiment.
The 4pi rule is valid in all rotational directions. If the rotation is around
the spin pointer then you can measure only the interference. (The spin
pointer doesn't change direction) However, a rotation around any other
axis will rotate the spin pointer itself and change the direction of the
magnetization which is measurable.
Regards, Hans
Regards, Hans
I see.
What you say is indeed interesting.
But I didn't know about the other direction.
Demystifier said:
What exactly do you mean by that?
I don't believe "the spin of the electron".
Because as I have stated before, "spin" has some serious problems.
For example, the electron is too small. So by equating the spin angular momentum to 1/2 hbar, spinning sphere speed leads to 100 times the speed of light. (If the electron size is classical radius.)
The classical radius size is as big as nuclear size of the hydrogen .
Spinning electoron has magnetic moment and spin angular momentum.
And one electron has the charge and mass.
Magnetic moment is basically caused by the rotaion of the charge, isn't it?
Angular momentum is basically caused by the rotaion of the mass, isn't it?
Probably Nobody believes "spin" is a actual spinning of the electron.
In spite of that, why do we call it "spin"?
It is inconsistent.
It is inconsistent.
I completely agree that spin as a kind of rotational motion does not exist. Still, the effect that we call "spin" exists. We should probably use a different word for this effect, but it is just a matter of terminology, not of physics.
Nevertheless, there are reasons for calling it "spin": The sum of this and the ordinary angular momentum is conserved.
I wasn't aware of this detail of Bohmian quantum mechanics and I don't understand why a particle couldn't affect its pilot wave. Couder and Fort have shown experimentally that the particle and its steering wave must be considered as a whole. If the particle ceases to exist, the pilot wave disappears. And reversely, if the pilot wave is disturbed, the particle is unable to survive: http://www.physorg.com/news78650511.html.
If it did, then pilot wave would not satisfy the Schrödinger equation. On the other hand, all experiments confirm that the wave satisfies the Schrödinger equation.
