Do commutators hold in interacting theory?
  • Level: Graduate
  • Thread starter Thread starter geoduck
    Commutators Theory
7 replies · 2K views · last reply
geoduck
Do the Fourier coefficients of an interacting field obey the commutation relations? I think I was able to show once that they do if the Fourier coefficients are taken at equal times (the coefficients are time-dependent in the interacting theory), but my proof felt shaky.
In any case, does anyone know the answer for equal times, or unequal times?
I do not believe they hold in general because, for example, in QCD the interactions introduce:
\begin{equation}
\langle \bar{\psi}_i \psi_i \rangle = c
\end{equation}
where c is some constant and we sum over flavour indeces. I don't see how standard commutation relations can hold with a non-zero VEV of the product of these fields.
The commutators for elementary field operators must hold in interacting theories otherwise the construction would be ill-defined. But for more complicated operator products which require regularization this need not be the case; it can happen that a quantization anomaly is introduced which spoils the classical Poisson brackets or trivial commutators.
A well-known example is the axial anomaly where the classically conserved charge Q5 fails to commute with the Hamiltonian after quantization & regularization, i.e. [H,Q5] ≠ 0
Are you saying something like [f(X),P]=i (df/dx) might not hold, where f(X) is a complicated operator product of X's, if f(X) requires regularization?
In QM I am not aware of any anomaly. I am not talking about QM but about QFT.
In QFT you don't have X and P as operators but field operators like [itex]\phi(x)[/itex], [itex]\pi(y)[/itex] and commutators like
[tex][\phi(x),\pi(y)] = i\delta(x-y)[/tex]
Let's make an example: the axial charge is constructed from fermionic field operators as
[tex]Q_5 = \int_{\mathbf{R}^3}d^3r\,\bar{\psi}(x)\,\gamma^0\, \gamma_5 \,\psi(x)[/tex]
Applying the naive commutators before regularization one finds
[tex][H,Q_5] = 0[/tex]
which would correspond to a conserved axial current
[tex]\partial_\mu j^\mu_5 = 0[/tex]
But due to gauge-invariant regularization preserving
[tex]\partial_\mu j^\mu = 0[/tex]
one is forced to introduce a regulator violating the axial symmetry; therefore one finds
[tex][H,Q_5] = \mathcal{A}[/tex]
and therefore
[tex]\partial_\mu j^\mu_5 = \mathcal{a}[/tex]
where A represents the anomaly (which is a term depending on the spatial dimension and topology).
The commutators of the fermionic Fourier components for [itex]\psi(x)[/itex] remain valid, but the commutators of the Fourier coefficients of [itex]j^\mu_5(x)[/itex] are modified. So what happens is that due to quantization and regularization the structure of a composite operator may change. The conclusion is that at least for composite operators the naive replacement of Poisson brackets with commutators and the naive application of Fourier transformation of field operators need not always be valid.
Don't the commutators e.g. in QED vanish during renormalization due to Z becoming infinite?
Which commutators? For the axial charge?
Starting with the anomaly equation
one finds
[tex]i[H,Q_5] = \partial_0 Q_5 = \int_{\mathcal{M}^D} d^{D-1}x\,a_D(x)[/tex]
for D-dimensional space-time and spatial manifold D (assuming reasonable boundary conditions or compact M). This expression does not vanish in general
I think what is meant is that if the canonical commutation relations hold for the bare fields, then what about for the renormalized fields? The commutator should be 1/Z less, where Z is the field strength normalization, which goes to infinity.
This is worrisome because if you form bilinears out of the renormalized fields, then their commutators vanish, which ought to mean that there can be no microcausality?
I am always confused by this. If you have:
∫∫∫(div f)d3x
then by Stoke's theorem this is the flux of f over the surface, and if you mandate that fields vanish at the surface, then this term is zero.
But isn't it true for a scalar function g=g(x,y,z):
[tex]\int\int\int \partial_y g(x,y,z) dxdydz[/tex]
that the above expression also vanishes? So requiring the integrand to be a 3-divergence is a little too strong: if it's merely a partial derivative then wouldn't it vanish?
So not only does ∫∫∫(div f)d3x vanish, but each term in the sum of div f vanishes:
[tex]\int\int\int \partial_x f_1(x,y,z) dxdydz=\int\int\int \partial_y f_2(x,y,z) dxdydz=\int\int\int \partial_z f_3(x,y,z) dxdydz=0[/tex]
