Do curl/time dependent Maxwell's equations imply divergence equations?
The discussion revolves around the implications of curl and time-dependent Maxwell's equations on divergence equations, particularly focusing on the conditions under which the divergence of magnetic and electric fields can be considered zero. Participants explore the foundational nature of these equations in classical electromagnetism and whether they can be derived from other principles.
  • Some participants argue that the divergence equations can be derived from the curl equations of Maxwell's laws, suggesting that they are not fundamental but rather derived relationships.
  • Others propose that the assumption of a time at which the magnetic field is zero is problematic, questioning whether this holds for all physical situations, such as plane electromagnetic waves that have non-zero magnetic fields at all times.
  • A participant points out that a plane wave does not have the magnetic field equal to zero everywhere at any instant, countering the notion that such a condition can be universally applied.
  • There is a discussion about the implications of the condition that the time derivative of the divergence of the magnetic field is zero, leading to the conclusion that if the magnetic field is zero at one instant, it must be zero at all times.
Participants express differing views on the foundational nature of the divergence equations and the conditions under which they hold. There is no consensus on whether the divergence equations can be considered derived or fundamental, and the discussion remains unresolved regarding the implications of time-varying fields and their relationship to magnetic monopoles.
Some assumptions about the continuity of derivatives and the nature of physical fields are not fully explored, and the discussion includes unresolved questions about the applicability of certain conditions across different physical scenarios.
LightPhoton
TL;DR
Just like charge conservation is not something extra, but instead is derivable from Maxwell's equations, similarly by the given argument so are the divergence equations, making them, just like conservation of charge, non-fundamental in classical EM
In Classical Electromagnetic Radiation, Heald and Marion take the divergence of Faraday's and Ampere-Maxwell's laws and state:
$$-\vec\nabla\cdot\frac{\partial\vec B}{\partial
t}=\vec\nabla\cdot\vec\nabla\times\vec E=0$$
If we assume that all the derivatives of B are continuous, we may interchange the differentiation with respect to space and time:
$$\frac{\partial}{\partial t}\vec\nabla\cdot\vec B=0$$
or
$$\vec\nabla\cdot\vec B =\text{ constant in time}$$
Now, if at any instant in time B = 0, then the constant of integration vanishes.If we assume that the field originated at some time in the past, then
$$\vec\nabla\cdot\vec B =0$$
even for the time-varying case. Physically, we may argue that there are no magnetic monopoles in the steady-state situation so that ##\vec\nabla\cdot\vec B =0##; and because the addition of time-varying fields cannot generate such monopoles, ##\vec\nabla\cdot\vec B =0## must be generally valid.
And they use a similar argument for ##\vec\nabla\cdot\vec E= 4\pi\rho##.
But wouldn't this imply that there really are only two fundamental equations in classical EM (and Lorentz force law)?
Which equations are fundamental and which are derived is a matter of choice. You can also derive Maxwell’s equations from the conservation laws or from the gauge symmetry.
Also, if you do choose to start with Maxwell’s equations, then you can also derive the Lorentz force law.
LightPhoton said:
TL;DR Summary: Just like charge conservation is not something extra, but instead is derivable from Maxwell's equations, similarly by the given argument so are the divergence equations, making them, just like conservation of charge, non-fundamental in classical EM
or
Could you clarify how you are arguing that there must be a time at which ##\vec{B}=0## for all physical situations? Wouldn't a plane electromagnetic wave propagating in free space be a valid solution to Maxwell’s equations in Minkowski spacetime, which extends infinitely in time and has a nonzero magnetic field at every instant?
Additionally, if you must rely on physical reasoning to argue that ##\nabla \cdot \vec{B} = 0##, even if only for the steady-state case, wouldn't that imply ##\nabla \cdot \vec{B} = 0## is not being derived solely from the other Maxwell equations?
I don't follow. A linearly-polarized, monochromatic plane-wave of period ##T## propagating in free-space has ##\vec{B}=0## twice in every period.
The OP required ##\vec{B} = 0## everywhere in space at a single instant in time. However, a plane wave does not have ##\vec{B} = 0## everywhere at any instant—it may be zero at certain points, but it is always nonzero elsewhere. I initially had the same thought as you did.
The condition ##\frac{\partial}{\partial t} \vec{\nabla} \cdot \vec{B} = 0 ## implies ##\vec{\nabla} \cdot \vec{B} = f(x,y,z)##. If you require ##\vec{B} = 0## everywhere at some instant, then this forces ##f(x,y,z) = 0##, ensuring that ##\vec{\nabla} \cdot \vec{B} = 0## for all time.
Thanks, now I understand and I agree.
