Do floating objects of equal mass experience the same buoyant force in different fluids?
  • Level: High School
  • Thread starter Thread starter jayadds
    Buoyancy Conceptual
6 replies · 8K views · last reply
jayadds
Say that I have two objects of the same mass and volume. I place one into freshwater and another in glycerine. In both cases, the objects are floating. Would the buoyant force from both of these fluids acting on the object be the same?
From my understanding, buoyant force measures the weight of an object if it's floating. Since both of the objects are of the same weight and are afloat , does it make sense to think that the buoyant force would be the same in the two situations?
Many thanks.
Yes.
Since the objects are floating, the buoyant force must equal the weight.
Note that the waterline on the hull will not be the same as the glycerin line. I.e. They will displace different volumes of fluid to get the same buoyant force.
Now imagine the two identical objects are not floating, but hanging on a scale like this:
Brass and wood laboratory balance beam scale on a wooden base, with two hanging pans at the ends of the beam, a brass weight marked A2 near the stand, and a small pan on the base.
Your water and glycerin are in buckets standing on a scale like this:
Line drawing of a two-pan balance scale with a central pointer and a copyright symbol in the lower right corner.
Both scales are initially balanced. Then you submerge the objects into the buckets, and they do not float, but submerge fully (without touching the walls).
Does the balance of the scales change? If yes, how?
Brass and wood balance scale on a wooden base, with two empty pans hanging from the beam, a small pan on a stand at the right, and brass cylindrical weights beside it, labelled A2 on the pedestal.
Line drawing of a balance scale with two empty pans on a central pivot and a pointer, on a rectangular base.
Hmm...that's a really good question. I would think that the balance of the scales would not change. This is because the displaced fluid from the fully submerged object does not escape from the buckets and thus, the mass in both of buckets remain equal when the objects are added. This is just my thinking though. Is this correct?
Consider the buoyant force on each submerged mass. Is it the same for each?
Try to figure out the upper scale first, where the objects hang, and consider what DocAl said.
