Do I have enough information to find the radius?
  • Context: High School
  • Thread starter Thread starter Godspanther
    Information Radius
The discussion centers on determining the radius of a circle given two points A and B on its circumference and the length of the chord AB. It is established that additional information, specifically the arc length or a third point, is necessary to accurately calculate the radius. The formula for calculating the radius using the sagitta, \( r = \frac{s^2 + l^2}{2s} \), where \( l = \frac{AB}{2} \), is highlighted as a practical tool used in construction and mirror grinding. The conversation also touches on the application of this formula in crafting a scimitar, emphasizing the importance of precise measurements for accurate results.
  • Understanding of basic circle geometry, including chords and arcs.
  • Familiarity with the sagitta theorem and its application in radius calculations.
  • Knowledge of measurement techniques and error analysis in geometric calculations.
  • Basic skills in drafting or graphical representation of geometric shapes.
  • Research the sagitta theorem and its applications in construction and optics.
  • Learn about geometric constructions using compass and straightedge techniques.
  • Explore methods for measuring and minimizing error in geometric calculations.
  • Investigate the design principles for crafting curved blades, specifically scimitars.
This discussion is beneficial for mathematicians, engineers, craftsmen involved in sword-making, and anyone interested in the practical applications of geometry in design and construction.
Godspanther
If there is a circle, 360 degrees, and 2 random points A & B are chosen on the circle. A straight line is drawn between those two points. You are not shown the whole circle. All you can see is A, B the straight line and an arc representing an unknown number of degrees. You know the length of the line from A to B. Assuming everything is to scale can one determine the radius of the circle or is more information needed?
Mathematics news on Phys.org
No. If you construct the normal on the midpoint of the line, the center of the circle will be somewhere on that normal, but that is all.
The arc is the essential information here. What does it mean to know an arc of the circle? An arc has obviously at least three points which are enough to determine the circle.
You can resolve it graphically if you are able to precisely draw an isosceles triangle within the arc and cord area.
Damn. Now granted I suck at math, which really sucks since it is the language of reality itself, still I had hope. Since all circles are the same a person could draw a line at a 90 degree angle from the mid-point of line AB to the Crest of the arc. I had hope the there was a formula that one could use comparing the length of AB to the length of the midpoint line let's call that one C. If such a formula existed then one could draw a line of AB length in any size circle and be able to determine the circles size based on the length of line C. At least that is what I had hoped.
That formula exists, it is used in construction.
Is this homework?
The situation looks like this:
If you have the arc length above the chord, then we are left with two possibilities. If we have a third point, then we have the circle.
If one knows the sagitta then $$ r=\frac { s^2+l^2} {2s}$$ where ##l=AB/2##
Is this homework?
Lol. No. I am 41 years old. I have a passing interest in forging. I am contemplating what would be the optimal degree of arc to create a perfect scimitar. The closest I can find online is this one. https://www.trueswords.com/Arabian-...vPlyZYonirFBQ-I4qoHK6Zjy3gk0mikuhmaxCVicPuhys But the blade is short. If I can find a formula I can print the picture, make the measurements and figure out the arc for a blade between 32-36 inches. I am still debating best blade length and will likely examine multiple designs.
Very interesting project.
Please, see:
https://www.mathsisfun.com/geometry/arc.html
That is just the sort of thing I was looking for. That you very much.
Known to all grinders of telescope mirrors as the Sagitta Theorem as I mentioned in #8 above. I bring it up because I have corrected my original post from ##~l=AB~##to ##~l=AB/2~## which comports with @Lnewqban result
Lnewqban said:
First: I did not get the fact that you also have got the arc itself, not just the line AB. Second: The formula I quoted above is mathematically correct, but when the height is small relative to the width, the uncertainty in the radius calculation can easily be very large.
Yes when grinding a telescope mirror you use it to calculate the depth of the sagitta required to produce a mirror of desired radius ( and therefore focus) from a circular glass blank. Commonly a "feeler" gauge of some sort is usually created to test "s" the sag depth as you grind (you call it "height"). Because you know l=AB/2 very accurately for the mirror blank the technique is quite precise.
But if you measure l with error ##\Delta l## then$$ r=\frac { s^2+l^2} {2s}$$ $$\Delta r=\frac {\partial r } {\partial l} \Delta l$$ $$\Delta r=\frac l s \Delta l$$ As you have noted
You are absolutely correct; the method is as accurate as the measurements.
As you have seen, the OP just wants a rough estimate so he can shape a sword.
I have seen it used in buildings construction as well, where errors are not that critical either.
The formula for the uncertainty in r relative to the measurement error in l cited above is correct, but my problem lies with the measurement error in s. In that case, you have: \Delta r=\frac{\partial r}{\partial s}\Delta s= \frac{4s^{2}-2(s^{2}+l^{2})}{4s^{2}}\Delta s = (\frac{1}{2}-\frac{l^{2}}{2s^{2}})\Delta s .
For completeness sake:
if the errors are independent $$(\Delta r)^2=|\frac{\partial r}{\partial s}|^2 (\Delta s)^2+|\frac{\partial r}{\partial l}|^2|\Delta l)^2$$
For me the cleanest way to write this is
$$(\Delta r)^2=\left |1-\frac r s\right |^2~ (\Delta s)^2+\left|\frac l s\right |^2(~\Delta l)^2$$
(Revised)
If the sword is really going to be a circular segment (no modifications) wouldn't it be easier just to make a big compass drawing with a stick (or string) and some chalk on cardboard? Anyhow you have (re) learned some geometry. Have fun
  • · Replies 18 ·
  • · Replies 16 ·
