Do quarks and leptons have electromagnetic fields?
6 replies · 2K views · last reply
sirios
Hi, we know that the particles have intrinsic properties for them electric field and magnetic moment, but for what I mean particles, I mean quarks, the fundamental blocks of (protons, neutrons and mesons) with everything that nobody explained as electric and The magnetic field of a particle and lepton quarks occurs can someone explain me, or is that just another mystery to be unraveled by quantum theories?
well, what I tried to ask was this: if there is a theory, other than string theory, that explains how an electric field of a quark or lepton is generated from photons? or how the electric charge property is defined, that is, positive or negative? since the theoretical models can not go beyond the quarks.
sirios said:
well, what I tried to ask was this: if there is a theory, other than string theory, that explains how an electric field of a quark or lepton is generated from photons? or how is the property of the electric charge defined, ie, positive or negative? since the theoretical models can not go beyond the quarks.
You are confused about a number of things:
1. Everything is not made of photons
2. The basis of electric charge is not a definition but comes from what's called U(1) symmetry.
3. Unfortunately, right now, string theory hasn't quite worked out as its originators hoped - it was a very valuable development but has not really explained anything fundamental like symmetry I mention above, but is still in active development:
https://www.quantamagazine.org/string-theorys-strange-second-life-20160915.
I think you need, in light of the above restate your query. But the following may help you:
https://www.amazon.com/dp/1591024242/?tag=pfamazon01-20
Thanks
Bill
Hi guys, I'm correcting the question because I think a lot of people did not understand what I asked, well, what I tried to ask was this: if there is a theory, besides string theory, that explains how an electric field of a quark or lepton are generated from photons? or how is defined the property of electric charge, ie, positive or negative? since the theoretical models can not go beyond the quarks.
Thanks
Bill
Thank you só much
String theory does not explain that.
Quantum field theory provides a great description of it. This works for all charged particles, leptons and quarks alike.
