Does a magnetic field always do work?
The discussion centers around whether a magnetic field does work, exploring various scenarios such as electromagnets and permanent magnets. Participants examine theoretical implications, practical examples, and differing interpretations from literature.
  • Some participants assert that magnetic fields do no work, particularly when the displacement is perpendicular to the force, referencing the equation W = |F||d|cosΘ.
  • Others argue that in cases like electromagnets lifting objects, work is done because the displacement aligns with the magnetic field direction.
  • One participant mentions that while magnetic fields do no work on moving charges, they can exert torque on magnetic moments and produce translational force in inhomogeneous fields.
  • A participant highlights that the work in lifting a car with an electromagnet is performed by the power source driving the electromagnet, not the magnetic field itself.
  • Another participant questions the role of permanent magnets in doing work, suggesting that they also lift objects and inquires about the energy consumed in that process.
  • There is mention of conflicting views in literature, including a reference to David J. Griffiths' work, which some participants find unconvincing.
Participants express differing views on whether magnetic fields do work, with no consensus reached. Some agree on specific scenarios where work is done, while others maintain that magnetic fields do not perform work in general.
Participants reference various interpretations and examples, indicating a need for clarity on definitions and conditions under which work is considered to be done by magnetic fields. The discussion includes unresolved mathematical and conceptual nuances.
Abdul Majid
Magnetic field do no work.
Is this always true?
If so then what is the explanation of that crane thing?
What do you mean by "that crane thing"?
Crane pulling a car.
Using electromagnets
From what i know, A field (which is actually force itself presented in a two-step process) does no work only if the displacement produced by that force is in a direction perpendicular to force. i.e.,
W = |F||d|cosΘ
If Θ =90°, w=0
Here. the displacement created by the electromagnets is in the same direction as the direction of magnetic field...so work is done.
That is right but many authors contradict with that,they still say that magnetic fields do no work like David j griffth has said in his book.
A magnetic field does no work on a moving charge. But It does work on a magnetic moment by exerting a torque and twisting the moment e.g. a compass needle aligning itself to the magnetic field. And it can also do work by producing a net translational force on a magnetic moment if the field in inhomogeneous over the moment e.g. two magnets attracting one another.
With the example of the electromagnet lifting the car, the work is actually done by whatever power source is driving electromagnet. Griffiths explains an analogous scenario in Introduction to Electrodynamics 3e with a current loop and a metal block. The key is in accounting for the movement of the car itself towards the electromagnet, which produces a force component acting against the moving electrons in the circuitry of the electromagnet (in one frame of reference), requiring the power source driving the electromagnet to do work.
The geometry will always work out no matter which reference frame you take as static (car or electromagnet). Relative velocities change how the force is applied. This approach also works with examples like two bar magnets attracting each other, but must be explained on the atomic level.
That is perhaps in 4e of griffth.
Not that convincing i think.
Laner
Would not a large permanent magnet also lift the car? Whats doing the work in that example?
What do we call the motion on a ferrous object a permanent magnet induces, and what is the name of the energy being consumed to do that work
And oh by the way , whatever we call that , it never runs out...
When a permanent magnet attract an object it does work pulling the object towards itself just as the Earth's gravity pulls object to itself. the work goes into kinetic energy like a mass falling. The energy is returned when someone does work by pulling the object away from the magnet.
  • · Replies 22 ·
  • · Replies 42 ·
