Does a photon go in all directions when emitted?
  • Level: High School
  • Thread starter alvaros
    Photon
244 replies · 46K views · last reply
Shahin said:
this wavefunction, has a maximun and a particular region in which it is very probable to find the photon, and outside this region we can neglect the probability of finding te photon. So we can conclude that, if the photon has size, a volume, it could be the volume of this region.
You just wrote : a region in which there is a certain probability of finding the photon. That's correct. Then you say, the volume of that region is the size of the photon, right ? But then i can say, well you will always have probability 1 (ie absolute certainty) to find that photon in this region because the photon's volume is just as big as that region. Once you are in the region, you will observe the photon because it "fills up" they entire region. Clearly, this is incorrect.
No, the ONLY thing you can say is : there is a certain probability of finding the photon in that region which has a certain volume. THAT IS ALL ! No information is given about the actual shape of the photon ! Just like the electrons in orbitals.
marlon
Shahin said:
No no, i didnt mean that thing. You are talking about the bohr radius, that is the radius of certain orbit in a certain system of reference, and has nothing to do with what i wrote. In your example, |psi|^2 is not "big" in all the sphere that has the bohr radius centred in the nucleo, so the condition |psi|^2>1/10maximun(|psi|^2) does not hold. The correct analysis would be, for example, represent |psi|^2 as a function of r, and yo will see that |psi|^2 is only appreciable in a little region around the bohr radius.
The wave function for the ground state of the hydrogen atom is
[tex]\psi = \frac{1}{\sqrt{\pi} a_0^{3/2}} e^{-r/a_0}[/tex]
with the corresponding probability density
[tex]|\psi|^2 = \frac{1}{\pi a_0^3} e^{-2r/a_0}[/tex]
where
[tex]a_0 = \frac{\hbar^2}{mq_e^2} = 0.0529 nm[/itex]<br /> <br /> is the (first) Bohr radius.<br /> <br /> Clearly the probability density is maximum at [itex]r = 0[/itex], with the value<br /> <br /> [tex]|\psi|^2_{max} = \frac{1}{\pi a_0^3}[/tex]<br /> <br /> Setting [itex]|\psi|^2 = 0.1 |\psi|^2_{max}[/itex] and solving for [itex]r[/itex], I get <br /> <br /> [tex]r = - \frac{a_0}{2} \ln 0.1 = 1.15 a_0[/tex].<br /> <br /> Using your criterion, then, the size of an electron in a ground-state hydrogen atom is (1.15)(0.0529 nm) = 0.0608 nm.[/tex]
Schrödinger's Dog said:
To be frank the question has been answered very well, there is no size, only a mathematical probability of where a photon will progress and this has nothing at all to do with an actual "size of the photon" I think you're confusing the issue.
Mathematical probability? The mathematical concepts are only in mathematic. There is no reason for that agree with existence of a photon's size is a mathematical probability. Since if it has been true, I'll assume that because I don't know the electron approximately size, according to "mathematical probability" can select a value that differs with reality. But I agree with that because we have not any information about a photon's size, we can connect it to "mathematical probability".
Thanks.
Mr Beh
where
[tex] <br /> <br /> NO NO NO NO. I think it is my fault because i didnt explain myself propely. Obviously, what i was meaning writting |psi|^2 was the density of probability, different in each case. So for the hydrogen atom you have to take r^2|psi|^2 and then you can do the analysis correctly. Anyway, I HAVE NEVER SAID that we can size the electron using this method, because, of course the electron has no size. I have just mentioned it as an idea about how to know the size of a photon.[/tex]
So the electron has no size but the photon has ? I really don't get why you think this is the case. How does this size determining method work ? I tried to reread your previous posts but i did not find a valid explanation. I guess this method does not work according to the stuff you wrote in the volume of the region in which you can find a photon.
marlon
Shahin said:
NO NO NO NO.
What no, no, no, no? How do you explain that the result obtained by jtbell is k=1.15 and not k=100 or k=0.01?
Regards, Dany.
P.S. Don’t worry. You are not required to get passing grade, maximum, you will have second chance.
marlon
Because you did not reason for your allegation about rejection of the photon's size existence that it has been logical.
Thanks.
Mr Beh
Before people continue with all of this, please take note that (i) the Particle Data Group has at least http://pdg.lbl.gov/1998/consrppbook.pdf" and (ii) nothing on the "size" of a photon for any given frequency.
There is a clear definition on what is MEANT by the "size of an electron". One only need to look this up to know how such a thing is defined. Now, can you find me a similar reputable source on how the size of a photon is defined? I don't mean something that YOU made up yourself. I mean go look either in PDG, or the CRC Handbook, or the CODATA latest edition. Please find the exact definition on the size of a photon. Note that I didn't ask you to find me a value, because unlike the definition of the electron classical radius, a photon's property, such as its energy, can vary with frequency, etc. All I asked was for you to find a legitimate source such as the one I had provided, and show me how those sources define the size of a photon.
While this may not be simple, it is a straightforward task and will go a long way in deciding this never-ending question. Why? Because it will establish in the clearest fashion on whether the standard, current, accepted physics that we know of has such a definition. All everyone has done is make a guess work that it could be this, or it could be that. Why not establish once and for all if we DO have such a definition, as clear as the definition for the electron?
So find me one, and please make an exact citation to the source.
Zz.
Zz.
In today era, we must difine the photon's size discussion: because we haven't a sufficent technology (there are also our mathematical and theoretical concepts without existence the legitimate books etc.) to prove that does its spatial coordinates exist or not, like the many open problems and undetected things in the universe, then we had to say that there are neither can not answer or answer according to own informations. (If you claim to prove your belief about this issue, you can explain it).
Thanks.
Mr Beh
Thanks.
Mr Beh
In other words, you are making SPECULATIONS with nothing to support your claim.
Let me point to you the PF Guidelines and IR forum.
At the very least, you are admitting that nothing in legitimate physics has anything to back your claim. Now, anyone else up to the challenge?
Zz.
Regards, Dany.
I have explained the question in my last post. Read carefully:
I think it is my fault because i didnt explain myself propely. Obviously, what i was meaning writting |psi|^2 was the density of probability, different in each case. So for the hydrogen atom you have to take r^2|psi|^2 and then you can do the analysis correctly, getting a different result. Anyway, I HAVE NEVER SAID that we can size the electron using this method, because, of course the electron has no size. I have just mentioned it as an idea about how to know the size of a photon.
marlon
I think the photon has no size. It was only an idea of how to asign a number called "volume" to a photon, if it would be possible.
ZapperZ said:
Before people continue with all of this, please take note that (i) the Particle Data Group has at least one value for the size of an electron and (ii) nothing on the "size" of a photon for any given frequency.
Before people continue with all of this, please take note that the Particle Data Group (Rozenfeld Tables) contains the addition 300 pages. Following your attitude (I can’t call it logic) there are no such notions and data like electron life time, proton life time, photon life time, etc. Moreover, the neutron, all other fundamental fermions and bosons do not exist.
In addition, notice that presented value for the “size” of an electron (classical electron radius) is of order 10^(-15)m whereas the electron Compton wavelength is of order 10^(-13)m and that means that here you have no idea what you are talking about. The classical electron radius is the definition of the range of validity of CED and has nothing to do with the “size” of the electron. Indeed, the range of validity of QED begins at least two orders of magnitude before.
“The size of a photon” is jargon used in PF. The professional term is “the coherence length”. The legitimate source is:
L. Mandel and E. Wolf, “Optical coherence and quantum optics”, Cambridge Univ. Press, (1995).
The only way to know how this source defines the “size of a photon” is (as usual) to read it. In my opinion, it is impossible to understand the behaviour of the elementary particles (High Energy Physics) without reading that book. In contrast with the low energy physics at high energy scale all fundamental fermions and bosons are pointlike.
In that very special case, I have no comment.
If you are interesting, I will prepare post describing how quantum physics historically emerged starting from M.Faraday discovery of the charge quantization and the problems emerged in thermodynamics and statmech as earlier as 1850. That will include the explanation of the physical content of A.Einstein Ph.D. thesis where the first time the “size” of the atom was calculated. And indeed the wave-particle duality. It may be good for kids like Shahin. Please, let me know, since I am lazy.
Regards, Dany.
The coherence length (or coherence time) is not a measure for the size of a photon, but just a measure of how long phase information is predictable in a wavetrain and amplitude and phase correlations exist.
According to your definition, laser light would be several orders of magnitude "larger" than sunlight. That does not sound appropriate to me as the longer coherence time and length concerning lasers is a consequence of the different process of photon creation.
I know to read and I do not need your explanations yet. However, you did not understand what I wrote in post #24. Now you apparently wrote the same. You may compare in order to see that (you can’t understand only the second sentence; the content will be clear after I will publish the expected results).
Lack of the experience prevent your understanding of the physical content of jtbell beautiful demonstration that the suggestion is correct. You may understand much more reading Hans de Vries, post# 84 in “Very simple QFT questions”.
Regards, Dany.
Zz.
Now you have not an idea "by helping a legitimate source" and also because of all own, scientific and experimental statements absence, I don't see a safe reason to argue with you and persons similar you.
It is a very common oration in PF. According to above point, you must reffer to it.
But,
1- By using the energy packet concept for a photon, we can not violate existence size of a photon. Since this packet has spatial coordinates.(x,y,z). We have also at speed discussion "DIFFERENTIATION " of any spatial coordinate, therefor energy of photon ([tex]h\frac{c}{\lambda}[/tex]) is dependent to these coordinates. Now if we delete them from structure of space - time (there are no dimansions except time), then the energy packet concept ,also, will vanish.
2- We can not assume that a photon is just a point. Because at initial time of
emiting photons from a source, there is a requirement that the source emits infinity number of these points. Of course it is a unreal imagination.
3- In double-slit experiment, if the diagonal of each slit will constrict, then the number of photons that is crossing from slits, will reduce. It occurs because of that these energy packets have volume and accumulation photons is a factor for justification that.
L. Mandel and E. Wolf, “Optical coherence and quantum optics”, Cambridge Univ. Press, (1995).[\QUOTE]
Thank you very much "Anonym" for introdiucing this valid source. I'll read it surely.
Thanks.
Mr Beh
They don't? Here's part of the PDG.
http://pdg.lbl.gov/2007/listings/lxxx.html
AT LEAST, there's SOME definition of the size of an electron, whether it is useful or not! There's nothing even approaching this for a photon, yet you seem to insist that such a thing is valid! If we use your logic, then there is even less of a ground to talk about such a thing.
And as someone else has pointed out, one can easily argue that this is not necessarily be the size of anything. Besides, if we want to talk about the coherence length, then talk about the coherence length! This is different, and at the very least, has SOME definition associated with it. I am fully aware of what a "coherence length is" I also will ask you if you seriously think that people who ask about the size of a photon would in fact know what a "coherence length" is, and even know why you think this is what they mean!
Again, you missed the point of this exercise. I didn't ask for arguments legitimizing such a concept. Issues such as size of a photon, size of an electron, etc... etc... are very, very seldom an issue in real physics. Only people like Proof.Beh and others seem to think that these are "important" concepts that have any meaning. They don't. An overwhelming number of physics papers do not deal nor care about these. even in elementary/particle physics. Therefore, I asked for, from standard references, if there is such a definition for any of these things that people seem to want to talk about in this thread. That's it! I didn't ask for values, or even arguments for the relevance or importance of such things. I asked for some sort of a definition that at least is on the books that people can actually agree on. PDG and others have provided at least some definition of the electron classical radius. One can buy that or not, but at least, there is a CLEAR definition of one. I work with electrons and even when we treat these as classical particles, I do not recall needing to consider its "size" beyond the point-particle approximation. So I asked for something similar for the size of a photon! Why? People argue back and forth if it exist or not, or if there's such a definition. So I asked for a legitimate source in which there IS a definition of the size of a photon! Use that as the "ground state" to work on if there is one. If we ALL can agree that the "coherence length" is the definition of the size of a photon, then FINE! But then people who have the illusion that this is your classical idea of "size" will have to abandon all hope. You also will have to qualify the discussion by saying that this isn't a universally accepted definition of the size of a photon, because none of the standard references indicates the size of a photon as the coherence length.
Note that sources like the CODATA reference not only tell you the values of various fundamental constants, they also tell you how these values are defined, and what techniques were used to obtain these values. This is what I asked for. I take it that since you have to resort to redefining what is meant by the size of a photon, that none of these standard references have ANY indication of having a definition of the size of a photon. So kids, if this is true, then you need to ask yourself why, in all of these fat reference books, is there no such definition of the size of a photon? Is it because (i) physicists are too dumb to know what it is; (ii) they haven't discovered it yet or (iii) there is no such definition and the concept is meaningless?
Zz.
I have no idea what you just said here. Could you use a different and better translator?
But,
Can you give me a citation on something legitimate beyond your guess work that actually equate the "energy packet" as being the physical photon size? I know what an wave packet is, so don't spend any effort teaching me what it is, nor is this a new argument. I just want you to point to me a source that has made the argument that "wave packet" = "photon size".
And note that if you actually believe this, this is NOT the "coherence length". so now, in this thread, the people who are arguing that the concept of a photon size is valid have two separate and different definitions for the size of a photon. Why? Because there's no accepted concept from legitimate sources and so people seem to think they can define it anyway they please from whatever concepts that are already floating out there.
May I suggest that you two fight it out amongst yourselves? I can't be expected to argue against such a concept when I have two different definitions to argue against. Whoever comes out on top, give me a call and then we'll talk.
Zz.
Clearly saying that a photon has no size and then trying to assign a volume to it is a contradictio in terminis. Again, you are speculating here and your speculations are based upon an incorrect interpretation of the mathematical formalism of basic QM (i.e. the example you gave a few posts back to which jtbell responded) !
Thanks.
Mr Beh
I clearly explained why a photon has no size (like a car has), you cannot pull that trick on me. But anyways, i want to ask you to answer to MY questions, please. What's the formula for calculating the photon's size ? Can you refer me to e textbook, paper, etc where this stuff is explained ?
You DO know that speculation does not go unpunished in this forum ? LUCKILY !
The PROPAGATION through space (NOT space time continuum, which is a general relativity thingy not a QM thingy !) of the energy packet indeed requires varying spatial coordinates. But again, i explained to you that we cannot talk about any path between source and detector unless we would measure it. But measuring changes the photon's wavefunction ! I URGE you to reread the double slit experiment and try figuring out why it is USELESS to be talking about a photon's trajectory in terms of x,y and z. Again, please refer me to a textbook that gives me an equation of this path in terms of x,y, and z. Besides, all of this deals with the trajectory, not the actual photon size. You argue that the energy packet "depends" on x,y and z (whatever that means). Well, it's spatial position DOES because it propagates through space. BUT THAT IS ALL YOU CAN SAY ! Based upon this, what POSSIBLE claims can you make on the photons structure ? What equations describe that size/structure.
Please, answer to THOSE questions which i already asked you THREE times !
Thanks
marlon
Zz, come on! You are very experienced manipulator and you even can’t imagine how I enjoy reading your posts!
To the best of my knowledge, that question (definition) and it possible connection with the advanced and retarded solutions of Maxwell eqs. was the content of R.P. Feynman Ph.D. study. The obtained results allowed him as continuation of the research to formulate QED.
As I explained in my post #22, the size of photon may be measured macroscopically by defining the diameter of the black body box.
Understanding of that point allowed to M. Planck and A. Einstein to start formulation of the Quantum Theory.
Later L. de Broglie demonstrated in his Ph.D. thesis that the same approach valid for the massive fields in general and for the electron in particular. That allowed to E.Schrödinger, W. Heisenberg and P.A.M. Dirac to complete the non-relativistic version of the Quantum Theory.
No. It is not my attitude here in QP of PF. I present here the superorthodox approach to the QT. What I say is written in every standard textbook on QT, except the M.Born statistical interpretation of QM. Only with respect to this point there is no general consensus inspite that there exist tons of experimental results that demonstrates that M.Born is wrong and E.Schrödinger and A. Einstein are right.
However, I do not believe that the QT may be studied through the Internet Forums, Wiki-Piki or Gogol-Mogol. I try to present the POV such that it will lead certain kids to go to the literature and to try understanding what is written there.
It is because the connection between the Quantum World and the Classical World is not fully established and fully understood yet. It is the Measurement Theory and the Measurement Problem (Schrödinger’s Cat: collapse of wave packet) all about.
ZapperZ said:
I work with electrons and even when we treat these as classical particles, I do not recall needing to consider its "size" beyond the point-particle approximation… If we ALL can agree that the "coherence length" is the definition of the size of a photon (and electron), then FINE!
I have no professional knowledge in details of the Particle Accelerators. You are the expert. I asked you question about the Inverse Schrödinger’s Cat. I need your help to know whether I am wrong or not. Please, answer my question (HUP and Particle Accelerators).
Regards, Dany.
P.S.
Fine! I am the one that provided the ultimate prediction that the proton is the QM ground state of three bounded quarks. It is the obvious result of my Ph.D. study entitled “Quantum Mechanics of Non-Abelian Waves”.
Note that I did not say that wave packet is equal to photon size. I replyed to marlon's statements for his justification about linking the photon size to energy packet of a photon. In addition, if we explain a photon structure in model of the "energy packet" Or a quanta then a photon size (if guess that it is, really) reduces to same packet. Also if a photon has created by combination an electron and a positron that they have spatial coordinates, please you discuss an example similar to processing production a photon that the its product has been a thing without no size!
What are you talking about ? What do you mean by "linking the photon size to energy packet of a photon" ? I ALWAYS stated that a photon has NO size so why on Earth would i "link" that concept to something else ?
PS : Don't forget to answer my questions, please.
marlon
If a photon has no size, and it's useless to be talking about a photon's trajectory in terms of x,y and z, then, where is the photon? (Excepting in the detector?)
P.S. Notice that I'm not claiming that photon has size.
WE DON'T KNOW !
Only when you measure with the detector, you will observe the photon indirectly !
Think of what the double slit experiment teaches us.
marlon
marlon said:
WE DON'T KNOW !
marlon
What do you mean with "you will observe the photon indirectly"? Is there a way to "observe it directly"?
Zz.
LoL. So again, I remember that there are no unique definition for describing existence of a photon size like that I said in my post #40. Therefor we don't derive a good CONCLUSION. Since we argue with our own knowladges. Also ,ZZ, you confess that you haven't a legitimate source to prove your claim that it is neither existence of photon size or rejection of it.
Dear marlon, we argue with our own informations. Because in nowheres, don't see a good answer for existence of photon size. There are no safe textbook for advocacy our claims about this subject. But if you have a legitimate source that shows a photon has no size, please introduce it. Perhaps derive a good and logical solution. Also, the x, y and z dimansions create the structure of space. Thus again, if they delete, there is no space that photon
propagates through in it. Can you live at home that it has not SUBSTRUCTION?
Thanks.
Mr Beh
I mean that whenever we "observe" a photon or an electron, we observe the result of the interaction of that photon/electron with the apparatus (for example emitted EM radiation etc etc).
marlon
marlon
Yes, and, of course, the same is true for every other measure we make in physics. Do you agree?
Don't twist things around. I asked you for a definition or equation that describes the photon trajectory and size. Why won't you just give me that information ? Why o why ?
1) How about the notion that a photon, electron, etc are DEFINED as point particles in quantummechanics ? Check any QM book on that.
2) How about the fact that the concept of size is NEVER used in the formalism of QM. Check any QM on that.
Huh ? Come again ? When did i ever say that the x,y and z coordinates "are deleted" (whatever that mean be). I ALWAYS stated that photons propagate through space !
Thanks.
Mr Beh
That's the point. A home is described by classical physcs while a photon is described by QM. QM is fundamentally DIFFERENT in nature and this is the aspect from which you misinterpretations originate. Don't worry, we have seen this happening tons of times on this forum. Just learn from what you read and pick up an intro QM book to get you on your way.
GOOD LUCK
Bye
marlon
The observation of ANY phenomenon at the atomic scale follows this procedure, YES. Otherwise, the HUP would be violated. But how is all of this related to the "topic of discussion in this thread" ?
marlon
