Does a Star's Fuel Running Out Lead to a Black Hole or Stellar Plasma?
  • Context: High School
  • Thread starter Thread starter Arceus74
    Black hole Hole
The discussion revolves around the fate of a star when its fuel runs out, specifically whether it leads to the formation of a black hole or a state of stellar plasma. Participants explore concepts related to temperature-gravity equilibrium, gravitational collapse, and the nature of singularities, engaging in both theoretical and speculative reasoning.
  • Some participants propose that when a star's fuel is exhausted, gravity overcomes other forces, leading to collapse, but question how temperature impacts this process.
  • Others argue that the concept of a "singularity" is a mathematical representation that does not correspond to physical reality, suggesting that current models break down at this point.
  • A few participants suggest that a phase change or a new stable state might occur during collapse, with ideas like "quark stars" being mentioned as a possible outcome, although lacking empirical evidence.
  • There is a discussion about the effective escape velocity exceeding the speed of light, implying that once within the Schwarzschild radius, nothing can escape, including light.
  • Some participants express uncertainty about what happens inside a black hole and suggest that current theories do not adequately predict the conditions there.
  • Several comments emphasize that the existence of quark stars remains hypothetical and requires further understanding of exotic matter and physics not yet established.
Participants do not reach a consensus on the nature of the collapse or the fate of the star. Multiple competing views are presented regarding the role of temperature, the meaning of singularities, and the possibility of alternative states like quark stars.
Limitations include the dependence on current theoretical frameworks, unresolved questions about the behavior of matter under extreme conditions, and the lack of empirical evidence for proposed states like quark stars.
Arceus74
I have a question that when the fuel of star runs out there is a imbalance is temeperature-gravity equilibrium.
When it collapses to a single point where mass gets compressed so much,but shouldn't the temperature at instant increase so much that the mass could not be compressed to infinite density at all.This should result in a stellar plasma.But people claim this is false.Could you explain why?
Astronomy news on Phys.org
It's only collapsing in the first place because gravity has overcome all other forces which previously had held the star in equilibrium.
There are no longer significant nuclear or EM interactions to oppose gravity.
We don't actually know what happens to the collapsing mass once inside the event horizon, but arriving at a single point having infinity density sounds improbable.
Some sort of phase change resulting in a new stable state, but within the event horizon seems more likely to me.
Arceus74 said:
When it collapses to a single point ...
This "single point" is a mathematical representation that is not believed to represent physical reality. Contratry to the incorrect statements in pop-science, "singularity" does not mean "point" in means "the place where our model breaks down and the math gives nonphysical results and we don't really know WHAT is going on.". It is believed that a solid, empirically demonstrable theory of quantum gravity will give a better picture of what is really happening at the heart of a black hole.
Well gravity did overcome all the phases during that instant but when it is about to reach a high dense state surely temperature should have a impact isn't it.I mean where does all the kinetic energy go?
So if it doesn't become a point then what force opposes it from not becoming a point.It must be temperature.
All I can do is repeat what I said
... "singularity" does not mean "point" in means "the place where our model breaks down and the math gives nonphysical results and we don't really know WHAT is going on.".
We don't know since we can't investigate inside a black hole and we can't reproduce the conditions.
My bet is still on some kind of change of state to a condition which is at present unknown to us and isn't predicted by current theories.
A 'Quark star' is one such suggestion which seems reasonable, but there is no evidence to support that idea.
A black hole does not require infinite density. According to GR, gravitational collapse is inevitable regardless of the strength of the material if an object collapses to within its Schwarzschild radius, which is given by ##2Gm/c^2## for mass ##m##.
This is somewhat denser than a typical neutron star of one to two solar masses. It is not clear exactly where the limit lies for neutron stars lies; it is thought that neutron stars would give way under the pressure somewhere around that point, but it seems theoretically possible that there might be a more dense form such as a "quark star" which is more massive than a neutron star but can still resist total collapse. Either way, the Schwarzschild radius goes up linearly with the mass but the volume at a given density only goes up with the square root, so there is a threshold not much higher where nothing can prevent collapse.
One way of looking at collapse is that the effective escape velocity exceeds the speed of light in that case, so not even light can escape. The question of what happens behind the event horizon isn't covered by current physics, but if GR holds there is only a finite proper time before a falling observer hits the singularity at the centre, and there is no way to escape that.
The hypothetical 'quark star' is something which is a bit heavier than a neutron star but hasn't collapsed into a black hole. According to GR, there is only a limited range of masses over which such an object could exist. I'm not aware of any current evidence for the existence of such stars.
In order to describe the collapse of a star, it's better to talk about a gravity - pressure equilibrium and what happens when gravity is the winner. Talking in simple terms and without all the details involved, for a small star, when the fuel of star is exhausted, meaning that there are no more nuclear reactions to fight gravity, then due to degeneracy pressure among electrons, there is no further collapse, so we usually have cooling of star and creation of a white dwarf. If the star is massive enough (about twenty times the mass of our sun or more) and a supernova explosion leaves a massive core (> about 2.5 times mass of the sun), there is no known repulsive force inside the star that can prevent gravity to collapse the core and the result is a black hole.
As phinds pointed out, singularity is a mathematical point not a physical one. So, because the model breaks down there, there is no point to state that this becomes a point or not.
No there isn't evidence of quark stars, I agree it's only hypothetical and requires physics we don't yet know about and exotic forms of matter which have never been observed.
That being said, it does seem more reasonable than proposing 'the singularity' is a real object having zero dimensions and infinite density.
What properties the exotic matter of a (hypothetical) quark star might have is unknown.
Can such matter degenerate further? - maybe. maybe not.
Within an event horizon as predicted by GR there are simply no possible paths through space-time which do not inevitably hit the singularity within a limited time, regardless of what form the matter takes. At present, the nature of the singularity itself is not addressed by physics.
Which is why a quantum theory of gravity is somewhat the 'holy grail' for theoretical physics at present.
If we nailed that then the awkward singularity might go away.
Are you claiming that nothing inside the event horizon is covered by current physics, or only that what happens at the singularity (or at the Planck scale) isn't covered? If the former, then I don't know why you would say that.
Same question.
No, I'm not saying nothing is covered. Perhaps I should have said what happens "eventually". I was answering someone who seemed to think it might be possible to have something stable behind the event horizon, and saying that as far as GR goes that's not possible.
Also at present, what happens behind the event horizon is by definition unobservable, so it's not very easy to apply the scientific method to it!
I wouldn't overstate this. For example, we have pretty good models of the interior of Jupiter. I don't think there's any realistic prospect of ever testing those models directly and in detail, since we can't use seismic waves as we do on earth, but that doesn't mean we can't believe the models. Another good example would be predictions of the future evolution of our sun, which we will never live to verify directly.
And it's actually not true that the interior of an event horizon is unobservable. You can go in there and observe it. You just can't publish the results in Physical Review.
Even from the outside, there are things you can check. You can check that, for example, the mass, charge, and angular momentum of the collapsing body remained constant during the collapse to a black hole and are in some sense "still in there." You can also check negative predictions, such as the prediction that nothing comes flying out through the event horizon.
[QUOTE=" I was answering someone who seemed to think it might be possible to have something stable behind the event horizon, and saying that as far as GR goes that's not possible.[/QUOTE]
Why isn't anything stable,Just because we can't observe it doent mean there is nothing stable?
The mathematics of GR extends beyond the event horizon, and says that the shape of space-time is such that there are no possible paths forward in time which stay in one place. Every possible path ends up in the singularity after a limited time.
You mean that black hole itself becomes a singularity and matter which once became a black hole behaves differently?
A black hole is the term for a gravitationally collapsed object, from which not even light can escape. In the simplest case (and as an approximation in the general case) a black hole possesses an approximately spherical "event horizon", whose radius is determined by the object's mass, which is effectively the limit from which nothing can escape. As anything approaches that limit, its possible future paths become more and more directed towards the object, and for anything inside that surface there are no possible paths which even stay still, and every possible path heads towards the middle.
What happens at the middle is the "singularity", in that the mathematics says that everything falls into an infinitesimal point, and the physics can't say anything sensible about it. It is usually assumed that when one gets close enough to that point, quantum theory will have something to say about what happens, but there is no general standard explanation.
All this stuff about black holes is of course only true about the actual universe if General Relativity and its standard interpretation are still accurate in this extreme case. I'll admit I am personally sceptical about this for various reasons, but GR is the best theory we have so far and these forums are only for discussion of mainstream scientific ideas. Provided you accept GR's mathematical description of black holes, then it is completely impossible for anything to be stable beyond the event horizon because space-time itself only contains paths that fall towards the singularity.
This is impossible. There are no "stable states" inside the event horizon.
Quark stars, which are speculative, are hypothetical stables states of matter which would be somewhat more compact than neutron stars, but would still have a radius larger than the Schwarzschild radius for their mass, i.e., they would not have formed an event horizon. (Actually, the limit for an object in stable equilibrium is 9/8 of the Schwarzschild radius for its mass; this result is known as Buchdahl's Theorem.) They are not stable states of something that has already formed an event horizon and fallen inside it. As I said before, there are no such stable states.
According to classical GR, it does become a point. But practically all physicists believe that classical GR breaks down in this regime (i.e., very close to the "singularity" in the classical GR model of a black hole), and that corrections due to quantum gravity become significant. The problem is that nobody really knows what those corrections due to quantum gravity are, since we don't have a good theory of quantum gravity. So we don't know the answer to your question at this point.
So is there any new theories that scientists are working on to explain these except GR.
Plenty of physicists are working on quantum gravity in one version or another. String theory is one version of quantum gravity. Loop quantum gravity is another.
How is string theory related with this,could you expain briefly?
String theory is, among other things, a quantum theory of gravity.
But doesn't string theory explain how the universe began?Can you relate this so that i can understand?
  • · Replies 27 ·
  • · Replies 21 ·
  • · Replies 70 ·
13K
