Does Acceleration Affect Tension in a Sphere and Car System?
18 replies · 3K views · last reply
rudransh verma
A small sphere is suspended by a string from the ceiling of car. If the car begins to accelerate with a , the tension generated in string is(##T_0## is tension at rest)
F=ma
If I draw the fbd then some force will accelerate the car in horizontal direction which I think does not effect the string in vertical direction. So same tension regardless of acceleration.
But we know it will increase. So what will be the correct physics behind it?
  • Handwritten free-body diagram of a hanging sphere: a vertical string labelled T pulls up, weight mg points down, and a horizontal arrow labelled F = ma points right.
ergospherical said:
Are you sure that the string will remain vertical? What's wrong with this picture as it stands?
No. Fictitious force. Inertia. Something like it will act.
If it stands vertical the two resultant forces cannot affect each other. So tension will remain same but it’s not true.
Right, but let's stick to inertial frames for the meantime. If the string hangs at an angle, say ##\theta##, to the vertical, then the tension will have both a horizontal and a vertical component - yes? What does Newton II say?
rudransh verma said:
Homework Statement:: A small sphere is suspended by a string from the ceiling of car. If the car begins to accelerate with a , the tension generated in string is(##T_0## is tension at rest)
Relevant Equations:: F=ma
The question is not sufficiently specific.
Are you to give the tension the instant after the car abruptly begins the acceleration?
or
Are you to give the tension with sphere at the new equilibrium position - with respect to the car?
or
Are you to analyze the tension as the sphere undergoes motion?
Hold a small object attached to a string and swing your hand while holding the other string's end. Does the string remain vertical?
The upper end of the string is connected to the accelerating car and the sphere will remain at rest.
This is equivalent to the sphere accelerating in the opposite direction, while attached to a fixed car.
Pick a reference frame and stick to it: inertial frame or accelerating frame?
Either way, draw the appropriate FBD and write the corresponding ##\Sigma F=ma## equation for the horizontal direction.
##T=\frac{F_i+ma}{\sin\theta}## where ##F_i## is fictitious force
  • Handwritten free-body diagram of a ball on a string attached to a wedge moving right with acceleration a, showing tension T at angle theta, components T cos theta and T sin theta, and a leftward force F_i. Below: T sin theta - F_i = ma, and T = (F_i + ma)/sin theta.
You were advised (and I agree) to stick to an inertial frame. (Note that if you are using fictitious forces, you are in a frame moving with the ball and thus there's no acceleration.)
So, forget about using accelerated frames or fictitious forces. (You'll need them soon enough, but first get inertial frames down cold.) Draw the usual free body diagram for the ball: Only two forces act on it. Then apply Newton's 2nd law and see what you learn.
(Of course, I'm merely restating what @haruspex told you above.)
##T=mg\cos\theta+ma\sin\theta## (increased tension in rope as compared to T=mg).
  • Handwritten free-body diagram of a sphere hanging from a support by a string at angle theta to the vertical, with the car accelerating to the right at a. Labels show tension T along the string, T sin theta horizontally, and mg and mg cos theta below.
Not sure what you're doing here. Do this: (1) Analyze vertical force components; (2) Analyze horizontal force components.
I aligned my axis along tension T. So the eqn comes out to be ##T-mg\cos\theta=ma\sin\theta##
  • Handwritten free-body diagram of a pendulum bob hanging from a pivot on an accelerating car, with tension T along the string, mg and mg cos θ labelled, T sin θ shown, and acceleration a marked at the pivot.
  • Handwritten free-body diagram of a hanging sphere with tension T along a tilted axis, weight mg cos θ and mg labelled, angle θ marked, and an acceleration a with a sin θ and a cos θ components shown.
OK, fair enough. You'll need a second equation to solve for ##T## and ##\theta##.
What you have done so far is not incorrect. However, if you have to write Newton's second law in a situation where force vectors have angles between them that are other than zero or 180°, you have a two-dimensional situation which means that you have to write two equations no matter how you choose your coordinate axes. You cannot reduce the problem to one equation and you have an infinity of mutually perpendicular axes to choose from.
I have already indicated to you in another thread that, of all these choices, the algebra is made easier if the axes are oriented so that the acceleration is along one of them. Then the sum of the force components in the other direction will be zero. Of course, the final choice of axes is yours as is the task of figuring out what you could have done differently if you get stuck in the algebra.
##mg\sin\theta=ma\cos\theta##
##T=ma##
##T=ma##
The third equation holds only when the acceleration and the tension are in the same direction. Are they? Please show how you got it.
Third is the result when I solved the above two eqns.
That result is incorrect and I already explained why I think so. If you think it is correct, you have to show me why you think so by showing your work. Maybe you will discover an error.
