Does an electron have a known diameter and rest mass?
An electron does not have a precisely defined diameter or rest mass due to the principles of quantum mechanics, specifically Heisenberg's Uncertainty Principle and wave function collapse. Decoherence plays a critical role in transitioning quantum systems to classical states, but it does not entirely eliminate the potential for superposition. The interaction between an electron and its environment can lead to a stable classical system while still allowing for a small probability of the electron existing in a superposition state. Thus, while measurements yield uncertainty, the properties of an electron can still be described within defined limits.
  • Understanding of Heisenberg's Uncertainty Principle
  • Familiarity with Schrödinger's equation
  • Knowledge of quantum decoherence
  • Concept of wave function collapse
  • Explore the implications of Heisenberg's Uncertainty Principle in quantum mechanics
  • Study the mathematical formulation of Schrödinger's equation
  • Investigate the process of quantum decoherence in detail
  • Learn about the measurement problem in quantum mechanics
Physicists, quantum mechanics students, and researchers interested in the foundational aspects of quantum theory and the behavior of subatomic particles.
DMuitW
I'm still very confused to some extent.
I know that from QM, an electron, due to Heisenbergs UP can't be measured definitely. It is following Schrödingers equation, and is presented as a vector in Hilbert space ,i.e. in a "electron cloud" of propability.
But here my theory is incomplete. I've read some things about when a measurement is made (lets not go into detail about what kind of measurement), possible states are reduced (wave collapse), creating a classical part.
Decoherence is the process the propability wave undergoes due to interaction and "continuous" measurement with environment. In this way, the quantum system is continuously measured, resulting in a "stable" (can be macroscopic) system. So according to what I read and decoherence told me, from the moment a classical system is created, its states are reduced, wave -function collapsed, and stay classical, due to constant environmental measurement upon...
So I think the electron that has been created along with the other parts of the system, is constantly measured, allowing no more a superposition state, leaving you, according to me, with a classical particle.
How then, can a well defined classical system, created by decoherence, that is able to stay stable thru constant environmental interaction, be build up of particles that can in some way or another still be superposed?
Thanks.
No and yes.
It is a common misconception that a classical system, such as an electron, is constantly being measured and therefore cannot exist in a superposition state. However, this is not entirely accurate. While decoherence does play a role in the collapse of the wave function and the creation of a classical system, it does not completely eliminate the possibility of a superposition state.
Firstly, it is important to note that decoherence does not occur instantaneously. It takes time for the environment to interact with the quantum system and for the wave function to collapse. Therefore, during this time, the electron can still exist in a superposition state.
Additionally, decoherence does not completely eliminate the possibility of a superposition state. It only reduces the probability of observing the system in a superposition state. This means that there is still a small chance that the electron could be in a superposition state, even after decoherence has occurred.
Furthermore, it is important to remember that the concept of measurement in quantum mechanics is not the same as our everyday understanding of measurement. In quantum mechanics, a measurement is simply an interaction between the quantum system and the measuring device, and it does not necessarily result in a collapse of the wave function. So even if the electron is constantly being "measured" by its environment, it does not mean that it cannot exist in a superposition state.
In conclusion, while it is true that an electron cannot be measured definitively and has a wave-like nature, it is not accurate to say that it does not have a known diameter and rest mass. These properties can be described and measured with a certain degree of uncertainty, but that does not mean they do not exist. And while decoherence does play a role in the collapse of the wave function and the creation of a classical system, it does not completely eliminate the possibility of a superposition state.
  • · Replies 17 ·
  • · Replies 71 ·
