Does Chrome Paint Make a Good Mirror?
  • Context: High School
  • Thread starter Thread starter erickulcyk
    Chrome Mirror Paint
The discussion revolves around the effectiveness of chrome paint as a reflective surface for creating a conical mirror intended for a camera system that requires a 360-degree view. Participants explore the properties of reflective materials, surface smoothness, and alternative solutions for achieving clarity in the reflected image.
  • Eric questions the suitability of chrome paint for creating a conical mirror, citing budget constraints.
  • One participant explains that the ability to reflect an image depends on the smoothness of the surface, noting that even chrome paint can distort images due to surface irregularities.
  • Another participant suggests using a mirror film as a more effective and cost-efficient alternative to chrome paint, highlighting the challenges of achieving an even coating with paint.
  • Eric mentions current use of mirror film but points out issues with achieving a flat application and the resulting image distortion.
  • A participant emphasizes the importance of surface smoothness and suggests exploring preformed conical reflector hoods designed for lighting, which may offer better photographic clarity.
  • Another participant adds that the angle of light hitting the reflector significantly affects image quality, indicating the need for experimentation with different materials and angles.
Participants express differing views on the effectiveness of chrome paint versus mirror film, with no consensus on the best approach for achieving a clear reflective surface for the camera system.
Challenges include achieving a smooth surface for optimal reflection, the impact of surface application techniques, and the influence of light angles on image quality. These factors contribute to the complexity of the problem without clear resolutions.
erickulcyk
So we are trying to make a conical mirror so that our camera can see 360 degrees around a robot. Our budget is not very big, and I found this chrome paint on http://www.alsacorp.com/products/mirrachrome/mirrachrome.htm
that I thought might work, but I'm not sure. What do you think?
Thanks,
Eric
Science news on Phys.org
As I understand it when it concerns something having the ability to "reflect" and image like a mirror does, it has to do with how smooth the surface area is. While metals are generally very reflective due to this, things like glass(crystalline structured) work well for reflecting because they are very relatively smooth on the atomic level. Since light reflection is concerning how photons (atomic sized)are reflected back the smoother surface the better. Notice on your link how even the car painted with the chrome paint slightly distorts the image. This is because (while an image is being reflected back) it is not reflecting the photons back in the same uniform direction they came in when coming in contact with the surface (therefore making the image come back "sloppy"). So I don't think its a question of the reflectiveness of the paint but rather how smooth the surface it is being applied to. Since you are wanting to use it so you can see through a camera I imagine you want the best clarity you can, which may not be obtained when simply relying on the reflectiveness of the paint.
Anyone with a better understanding of the physics behind it please correct me if I was misleading about something.
This will not be very effective as a mirror. Getting an even coating is the biggest problem. I would try a mirror film like here [http://www.specialty-graphics.com/2800_FDC_Metallized_Sign_Vinyl.html] . It's cheap [~ $2 / sq foot] Even if it doesn't work like you hope, you're not out the $80 alsa wants for a 4 oz can of mirrachrome paint.
I think we are currently using mirror film now, the problem is that it is difficult to get it perfectly flat on the cone and there is a seam where the two edges meet. Together, these create a warped image and a big blind spot.
Eric
Like I said its all about how smooth the surface along with how reflective it is. Its really tricky to get reflective films to have the photographic clarity you are looking for in a camera image, especially when you are bending or wrapping it 360 degrees. You might want to look around for conical reflector hoods made for lighting systems in greenhouses. While you may run into similar problems (as far as it being camera quality reflective) you will find a wide variety of shapes and materials preformed into something that will work for your design.
Also i think I should add about how the angle of where the light is hitting your reflector will greatly affect the image quality through your camera. So if you go with something like a reflective hood (or any other surface/material) you will have to experiment and compensate for the different angles being reflected back, and which ones work best.
20K
  • · Replies 59 ·
16K
  • · Replies 33 ·
