Does Constant Acceleration Always Change Velocity's Magnitude?
The assertion that constant acceleration always changes the magnitude of velocity is false. In scenarios such as a steady circular orbit, an object can maintain a constant speed while its velocity vector changes direction due to centripetal acceleration. This demonstrates that while acceleration can be constant, it does not necessarily result in a change in the magnitude of velocity, as the direction of the velocity vector can change without altering its magnitude.
  • Understanding of vector quantities, specifically velocity and acceleration
  • Knowledge of circular motion dynamics
  • Familiarity with the concept of centripetal acceleration
  • Basic principles of classical mechanics
  • Study the principles of centripetal acceleration in circular motion
  • Explore the differences between linear and angular velocity
  • Learn about vector decomposition in physics
  • Investigate the implications of constant acceleration in various motion scenarios
Physics students, educators, and anyone interested in understanding the nuances of motion dynamics and vector analysis in classical mechanics.
mohabitar
The magnitude of the velocity of an object must change if the magnitude of its acceleration is a constant. True or false?
I chose true, however the correct answer is false. Here's my reasoning: If acceleration is constant, that means velocity is linear. If velocity is linear, that means it's magnitude is increasing.
Where did I go wrong here?
consider the velocity and acceleration of an object in a steady circular orbit for a counterexample to your reasoning.
What if the velocity is constant?
Then acceleration is zero
The acceleration also has a constant of zero.
velocity is a vector and it is defined by it's magnitude and direction-should any of these change, we say that velocity changes. When you have a non zero acceleration,velocity will surely change, but since it is a vector it doesn't have to be it's magnitude that changes. circular orbit is indeed a very good example.
Well if its not its magnitude, then what changes? Direction?
To take the example of a steady circular orbit (e.g. Earth around the Sun) - the Earth is held in the orbit by acceleration that is directed towards the Sun but has a constant amplitude. The velocity vector changes but again its amplitude is constant.
Since you only have to provide one counterexample to disprove the original statement, another answer would be a=0, v=const, but only because of a little slop in the problem formulation IMHO :-)
  • · Replies 16 ·
  • · Replies 16 ·
