Does Enterprise see the shuttle approach?
  • Thread starter Thread starter NikkiNik
    Approach
11 replies · 2K views
NikkiNik
Deep Space Nine sees Enterprise and a shuttle approach from exactly opposite directions with 0.6 c and 0.4 c, respectively. At what fraction of the speed of light (b) does Enterprise see the shuttle approach?
V2=(v1+ v1,2)/[1 +(v1*v1,2/c^2)]
I used -0.6c as v2 and 0.4c as v1 but when I solved it in the end I had 1c= 1v1,2 so I know I did something wrong I just don'e know what
The way you've written the formula, you should be using v1,2 = -0.6c and solving for V2. Although I think a better way to write it is
[tex]u = \frac{v_1 - v_2}{1 + \frac{v_1 v_2}{c^2}}[/tex]
Oh wait, I made a sign error - see my edit. It should be a minus sign on top. (Because, think about it: if both Enterprise and the shuttle were approaching DS9 at the same speed, .5c, you definitely should not be getting 0 for the relative velocity.)
Ok I solved it the way you said and I got 2.63e-1c but that's not right. I even got the same answer when I solved it my way?
Sorry one more question...if I add the velocities at the top then it would be 1/7.6e-1 and the answer would be 1.32c which I don't think is right. And if I solved it the first way, the answer being 0.263c (positive or negative) is incorrect...what am I doing incorrect?? Sorry I keep replying so quickly
I think you're plugging in some number incorrectly. When I plug in, I get a relative velocity that's higher than both 0.6c and 0.4c, but that is still less than c.
Think of the expression in the numerator--the v1 - v2 term--as being the classical relative velocity. Classically, the relative speed would be 1c (0.6c + 0.4c), right? Is that what you used?
yes I did (.4c)-(-.6c) =1c
then I didvided by (1 +(-.24c^2/c^2)=0.76
I divided the first answer by the second and got 1.316c ?
Why are you using -0.6c and +.4c in the denominator? That would be inconsisent with the numerator, where you're allowing the two speeds to have the same algebraic sign...
Ok I see but why would both of the signs be negative and not only one?? Is it because they are going in opposite directions
Don't think too hard about the signs. Just think about the "relative" speed between the two spaceships. According to either the Enterprise or the Space Shuttle, the other is approaching at 1c classically.
The term in the numerator just gives us the classical relative speeds. Since they are approaching each other, the perceived speed is going to be a speed larger than what the Enterprise perceives for either of them. If you have a negative sign for either of them, the effect will be decreasing the relative speeds, instead of increasing them.
