Does g(x) = xe^kx Have a Relative Extremum at x = -1/k or x = 1/k?
  • Thread starter Thread starter haris123
    Point
The discussion revolves around the function g(x) = xe^kx, where k is a negative constant. Participants are exploring whether this function has a relative extremum at the points x = -1/k or x = 1/k.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants are debating the nature of the extrema at the specified points, with some asserting that one point is a maximum while others suggest it may be a minimum. There is a focus on the behavior of the function's graph and its derivatives.
The discussion is active, with participants presenting differing views on the nature of the extrema. Some have offered reasoning based on the graph's behavior, while others are questioning the validity of those interpretations and suggesting a derivative-based analysis.
There is an ongoing debate about the definitions of maxima and minima, particularly in relation to the sign changes of the function's derivative. Participants express confusion about these concepts and seek clarification.
haris123
If g(x) = xe^kx where k < 0 is a constant, then we may conclude that g has
(a) a relative maximum at x = -1/k (b) a relative minimum at x = -1/k
(c) a relative maximum at x = 1/k (d) a relative minimum at x = 1/k
(e) none of (a) - (d)
i think the answer should be A
That would be right. But why do you think so?
the reason is because the graph is decreasing from - infinity to -1/k and increasing from -1/k to infinity. it changes from negative to positive. hence its a maximum. am i right?
If that's what you think it does, you are wrong. Changing from decreasing to increasing sounds more like a minimum. Can't you give a reason in terms of derivatives?
i am the one who needs help. so you tell me what do you think in terms of derivatives? btw from negative to positive is maximum
You can find out if a point is max. or min. by two methods -
1) Check the sign of f'(x) to the left and right of the point. If it's sign is negative to the left and positive to the right, then the point is a local minima.
2) Find out the value of the second derivative at the given point and check its sign. If it is negative then the point is a local maxima. If it is positive then the point is a local minima.
If f'(x) changes sign from negative to positive as we go through a point from left to right, then that point is a minimum not maximum! Review your calculus notes
