- 13,947
- 16,869
The better way to say this is that the resultant electric field ##\vec{E}(\vec{r})## can be written as the sum of two fields ##\vec{E}_q(\vec{r})## and ##\vec{E}_Q(\vec{r})## which are the fields that each charge would have if it were in its present position but the other charge were removed. The total flux of ##\vec{E}(\vec{r})## through ##S_1## (which encloses the charge ##q##) is ##x##, the same as the total flux of ##\vec{E}_q(\vec{r})## would be if the charge ##Q## were not present.rudransh verma said:Let me tell: the field of q does bend due to presence of Q. There is a new resultant field but that does not mean it will alter the field of q. It only gets bent ,not changed by the other field. And so the flux of S1 remains same. x.
Note that the flux of ##\vec{E}(\vec{r})## through a small part of ##S_1## will be different from the flux of ##\vec{E}_q(\vec{r})## through the same region - it is only the total over the entire closed surface that is equal.
