Does Newtonian mechanics assume the same time for all inertial frames?
  • Context: Undergrad
  • Thread starter Thread starter Kashmir
    Frames Inertial Time
18 replies · 3K views
Kashmir
Hartle, gravity
pg 34
" An observer in a inertial frame can construct a clock that measures the time t
"*)Is time something else that exists irrespective of clocks? What we do is just that we measure it? Pg 35
" ...It's a central assumption of Newtonian mechanics that there is a single notion of time for all the inertial observers"
What does the above sentence exactly mean?
Does it mean that whatever time is, it's same for all inertial frames? So if I take similarly made contraptions that serve as clocks, to every inertial frame,they would all tick at same rate with respect to one another?
What about non inertial frames? Why were non inertial frames excluded from
"...that there is a single notion of time for all the inertial observers".
Clocks directly measure proper time, usually denoted ##\tau##. If you know the relationship between proper time ##\tau## and some coordinate time ##t## then you can use the measurement of ##\tau## to calculate ##t##.
That is a bit philosophical. Without diving into the metaphysical connotations of "exists", proper time is the measurand of a clock. In other words, it is the thing that is measured. This contrasts with the measurement of a clock, the actual value obtained by the clock.
Kashmir said:
Pg 35
It means that Newtonian mechanics is wrong.
Non inertial frames were not excluded. It is simply a statement about inertial frames - which are the frames in which Newton's laws hold good.
Dale said:
Clocks directly measure proper time, usually denoted ##\tau##. If you know the relationship between proper time ##\tau## and some coordinate time ##t## then you can use the measurement of ##\tau## to calculate ##t##.That is a bit philosophical. Without diving into the metaphysical connotations of "exists", proper time is the measurand of a clock. In other words, it is the thing that is measured. This contrasts with the measurement of a clock, the actual value obtained by the clock.It means that Newtonian mechanics is wrong.
what is proper and coordinate time? Can you please explain it.
Thank you :)
A pendulum in an accelerating frame has different time period, so doesn't the clock move differently in this frame than in an non inertial one? So is time different for the non inertial one??
Thank you :)
Get a textbook on special relativity!
No. Not in Newtonian physics.
If a pendulum is hung in an accelerating elevator and won't it's period change?
For this reason, a pendulum clock is not an accurate time keeping device. Calling it a "clock" and treating it as a perfect reference for elapsed proper time in a circumstance where it is subject to variable proper acceleration is erroneous.
We do not expect a Grandfather Clock placed on the moon to tick at its nominal rate.
Put it on the surface of the Earth in reasonably constant gravity and calibrate it appropriately for the location where it is placed and you have yourself a clock.
Wikipedia has a paragraph on the effect of acceleration on clocks: https://en.wikipedia.org/wiki/Time_dilation#Clock_hypothesis
Thank you :)
Proper time is the time as measured by a correctly functioning physical clock. It includes the usual clocks and also other time-dependent physical processes like biological age or radioactive decay. It is defined only along the worldline of the clock and does not involve any notion of simultaneity. Each clock has its own proper time.
Coordinate time is the time coordinate in an arbitrary coordinate system. This is the time that defines simultaneity. It is the time involved in coordinate transforms, like the Lorentz transform. Coordinate time is not required to have any specific relationship to any physical clock, but even when (by some convention) it does match a physical clock’s time the coordinate time is different from the proper time: the proper time is only defined on the worldline of the clock and the coordinate time is defined throughout the coordinate chart.
Thank you :)
In addition to the earlier explanations, this might help:
On a position-vs-time graph,
the coordinate time is the "time" along the time-coordinate axis of the reference frame drawing the graph
whereas
the proper time [of an astronaut's worldline] is like the "arc-length of the curve of along the worldline"
(where "arc-length along the curve" on this diagram is measured by the astronaut's wristwatch).
In the position y-vs-time t graph below (t running to the right),
the coordinate-time of this graph is measured along the horizontal red line (y=0)
[which can somehow be "spread over space" to assign a coordinate-time to any point-event on the graph].
For these equal coordinate-time curve segments (from coordinate-time 0 to coordinate-time 2):
  • in Galilean physics (PHY 101), the three worldlines have equal elapsed proper-times.
  • in special relativity,
    the red worldline segment has the longest elapsed proper-time.
    The green worldline segment has a shorter elapsed proper-time.
    The blue worldline segment has the shortest elapsed proper-time among the three.
  • in Euclidean geometry, with the plot below interpreted as a y-vs-x graph (x running to the right),
    arc-lengths are measured by each path-surveyor's odometer.
    The red curve segment has the shortest arc-length.
    The green curve segment has a longer arc-length.
    The blue curve segment has the longest arc-length among the three.
Yes, but a quartz wristwatch will still keep the same time.
I'll have a go at this.
The time between two events measured in a frame where the events happen at the same position is called the proper time between the events.
The coordinate time is measured in a frame where the two events have a change in position. The coordinate time is usually related to the proper time, because the proper time is invariant in all inertial frames.
The proper time between two events for a non-inertial observer is generally less than it is for an inertial observer (ie the twin effect where the two events are departure and reunion).
Please correct me if I'm wrong.
Not quite. Proper time is measured along a worldline, and is independent of any choice of frame. But if you choose a frame properly, you can have coordinate time match proper time along your chosen worldline. (Note that if your chosen worldline is non-inertial, the frame you choose will have to be a non-inertial frame.)
No. Coordinate time is just a coordinate. There is no requirement that the two events must be at different spatial positions for their coordinate times to be defined.
Assuming both observers' worldlines pass through the same events, the inertial observer's proper time will always be the longest in flat spacetime (i.e., in special relativity).
PeterDonis said:
Not quite. Proper time is measured along a worldline, and is independent of any choice of frame. But if you choose a frame properly, you can have coordinate time match proper time along your chosen worldline. (Note that if your chosen worldline is non-inertial, the frame you choose will have to be a non-inertial frame.)No. Coordinate time is just a coordinate. There is no requirement that the two events must be at different spatial positions for their coordinate times to be defined.Assuming both observers' worldlines pass through the same events, the inertial observer's proper time will always be the longest in flat spacetime (i.e., in special relativity).
Thanks for the corrections.
Yes I should have added in worldline for clarity.
TBH here in the UK I don't think we use the term coordinate time, Its like you said, just the time coordinate which could be the proper time depending on your worldline.
I'm starting a module this year on SR and GR so you might see more of me in here as the weeks go by. :smile:
I always like to maintain a distinction between proper time and coordinate time even when using a coordinate system that matches some clock's proper time. The distinction is that proper time is defined only on the clock's worldline and it is invariant. The coordinate time is defined everywhere and it is not invariant. Basically, they are functions with different domains, even though in the intersection of their domains they do match.
We do. Or at least I was taught the term twenty years ago.
I think there's a few minor differences with some terms and notation but I'm pretty sure the actual physics will be equally good. :smile:
