Does normal contact force exert torque?
In the discussion about whether normal contact force exerts torque, it is clarified that the normal force acts perpendicular to the surface and does not necessarily pass through the center of mass of the object. This means that while the normal force can exert torque, it depends on the point of application and the distance from the center of mass. The torque due to the normal force can be calculated as the vector product of the normal force and the perpendicular distance from the point of contact to the center of mass. Additionally, the normal force plays a crucial role in preventing collisions between touching bodies by adjusting its magnitude and position. Overall, the normal force can indeed exert torque under certain conditions.
Sharp2
I came across a question in which a cubical body of mass 'm', edge 'a' is slipping down an inclination with constant velocity and torque due to normal contact force is to be found about the centre of the block.
As friction will exert an anticlockwise torque= 0.5amgsinx, where 'x' is the inclination, I was told that the normal contact force will exert an equal and opposite torque to keep the body in rotational equilibrium.
But doesn't normal contact force pass through the centre of the body? Then how can it possibly exert a torque?
Nope.
The normal force is called "normal" because it acts along a line perpendicular to the surface, i.e, along the normal. This line need not pass through the bdy's center of mass (or, for that matter, its geometric center).
The normal force "prevents" collision&interpenetration of two touching bodies and will, therefore, arrange itself in such a manner (in terms of magnitude&position where it acts) so that these collisions won't happen.
This will always be a success, until the internal stress in one (or both) surface(s) becomes too great, and a rupture/fracture occurs.
Thanks! I came across another question in which the normal force acts along the corner of the cube (to find the condition for toppling and sliding)! Thank you. =)
normal can exert torque
consider a case in which a disc is kept on an inclined plane
The torque due to normal reaction is the vector product of the normal reaction it self &the perpendicular distance between point of contact and center of mass.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
