Does Orbiting a Charged Planet Create a Constant and Positive B Field?
  • Level: Graduate
  • Thread starter cragar
    Charged Planet
5 replies · 2K views · last reply
cragar
If I am orbiting a charged planet that is like being in free-fall around the planet.
So would I see a B field in my frame? Is me orbiting the planet the same as me floating in space and have the planet rotate.
You would see a magnetic field. If you are charged as well, it would give an additional force downwards/upwards (depending on the charges).
If the charge is distributed on the surface (or the whole volume), a rotating planet would give a magnetic field, too - it would look different, but its shape really depends on the system where the field is calculated.
yes;no
What if I was orbiting inside a spherical shell with charge on it, would I see a B field then?
The E field would be zero inside the charged shell.
as would the magnetic field...assuming the charge is uniformly distributed...
B field inside a spinning charged sphere is constant and positive
