Does PYroMat only consider ideal gases?
5 replies · 5K views · last reply
Juanda
TL;DR
I get different results of ##Z## depending on the method I use to find it.
On a different thread, we calculated ##Z## for ##\mathrm{CO_2}## for some pressure and temperature conditions.
(Let's assume this is absolute pressure. Not gage pressure.)
$$T=297 \ \mathrm{K}; \ P=5438467 \ \mathrm{Pa}; \ V = 0.05 \ \mathrm{m^3}$$
I did it 3 ways:
  1. "By hand" using tables from a book and eyeballing values from a table. ##Z=0.64##
  2. Using a Python Library named "GasCompressibility". ##Z=0.61##. Pretty close. I guess the differences are a result of my eyeballed values from a table.
  3. Using a Python Library named "PYroMat". This allowed us to directly find the specific volume of the gas for the given conditions without having to calculate ##Z## which is very convenient. However, it produced a different specific volume than the one obtained with the other methods so ##Z## must be different. After calculating it from other values. I got ##Z=1##.
Since the first two give very similar results, I assume they are correct and the third one is at fault. However, I can't find the error. In fact, the third one should be the simplest since it doesn't require intermediate calculations.
After checking their web more closely, I saw this note:
Screenshot of the PYroMat documentation titled Properties of many ideal gases, listing available properties: cp, cv, d, e, gam, h, mw, R, s and v, with their descriptions.
Is it possible that this library is assuming ideal gas behavior for all gases? That'd explain why I'm getting ##Z=1##. I think that's odd because the library can be used for multi-phase mixtures and saturated gas differs significantly from ideal gas behavior.
Documentation list titled Multi-phase equation-of-state models: seven fluids (N2, O2, CH4, CO2, H2, R134a, R1234ze) and properties cp, cv, d, e, gam, h, mw, R, s, v, x.
This is some simple code I used to compare the results from the two libraries.
[CODE lang="python" title="GetCompressibility-vs-PYroMat"]import pyromat as pm
import gascompressibility as gc
V = 0.05 # Tank's volume [m3]
Temperature_sensor_array = 297 #[K]
Pressure_sensor_array = 5438467 #[Pa]
P_cr_CO2 = 7.39*10**6 # Critical pressure (top of the bell) [Pa]
T_cr_CO2 = 304.2 # Critical temperature (top of the bell) [K]
R = 188.9 # Gas constant [J/kgK]
# Using PYroMat to find Z.
pm.config['unit_pressure']='Pa'
pm.config['unit_temperature']='K'
pm.config['unit_mass']='kg'
pm.config['unit_volume']='m3'
co2 = pm.get('ig.CO2')
Specific_volume_pyromat = co2.v(T=Temperature_sensor_array, p=Pressure_sensor_array) #[m3/kg]
Specific_volume_pyromat = Specific_volume_pyromat[0]
Z_PYroMat = Pressure_sensor_array*Specific_volume_pyromat/(R*Temperature_sensor_array)
print('Z calculated from "PYroMat is: Z =', round(Z_PYroMat, 5))
# Using GasCompressibilty to find Z.
P_R_CO2 = Pressure_sensor_array/P_cr_CO2
T_R_CO2 = Temperature_sensor_array/T_cr_CO2
#This library requires odd units and gage pressure.
Pressure_sensor_array_PSGI = (Pressure_sensor_array-(0.1*10**6))/6895
Temperature_sensor_array_F = (Temperature_sensor_array - 273.15) * 9 / 5 + 32
Z_0 = gc.calc_z(sg=1, P=Pressure_sensor_array_PSGI, T=Temperature_sensor_array_F, H2S=None, CO2=1, N2=None, Pr=P_R_CO2, Tr=T_R_CO2, pmodel='piper')
print('Z calculated from "GetCompressibility is: Z =', round(Z_0, 5))[/CODE]
Juanda said:
TL;DR Summary: I get different results of ##Z## depending on the method I use to find it.
I did it 3 ways:
Do either of the first two methods use the Pitzer and Brewer acentric factor to get a more accurate value of Z?
The title of your third method specifically indicates ideal gases.
I searched the book for those keyworks and they don't show up. Although maybe its mentioned in the source Chemistry book.
Scatter plot with fitted green curves of compressibility factor Z against reduced pressure PR at several reduced temperatures TR, with data points for methane, ethylene, ethane, propane, n-butane, iso-pentane, n-heptane, nitrogen, carbon dioxide and water.
I tried searching for them on the GasCompresssibility webpage and it doesn't show it either. Would this match what you're expecting regarding how things are calculated?
Documentation heading 'Pseudo-Critical Models' with two entries: 'Sutton()' class object to calculate pseudo-critical properties based on Sutton's method, and 'Piper()' class object to calculate pseudo-critical properties based on Piper's method.
This link also details which model is used to calculate ##Z##.
Yes. I read it but I don't see how that matches the fact that the library is also used for saturated mixtures. The vapor in the mixture is most definitely not behaving as an ideal gas, right?
These are multi-constant equations.
A saturated vapor is pure gas, and not a mixture; it is a single phase at its dew point. A mixture is comprised of several molecular species.
See Smith and van Ness, Introduction to Chemical Engineering Thermodynamics.
Sorry. I said mixture but I meant to say multi-phase. I was trying to say that the PYroMat library is able to calculate saturated liquid+vapor mixtures which I find odd since it seems to be treating the vapor as an ideal gas.
Aren't these kinds of tables (below) obtained experimentally? Maybe PYroMat is using experimental values for the multi-phase calculations and then it switches to ideal gas once it's all vapor?
Table D1: Saturated CO2 with columns for temperature, pressure, specific volume (vf, vg), internal energy (uf, ug), enthalpy (hf, hg) and entropy (sf, sg) for temperatures from -50 to -22 C.
I'm trying to decide if PYroMat is a library I should get more used to using or if I should discard it. The library GasCompressibility seems useful and reliable since it produced the same result as the "by hand" calculation using the book.
Even if it treats the vapor as an ideal gas, it must use data on the density of the saturated liquid as a function of temperature, and, if you specify the mass fraction vapor, you can get the averaged specific volume of the combination of liquid and vapor.
Tables like this are generated from analytically fitting data, with the fits constrained by thermodynamic relationships. This table takes into account non-ideality. To generate this table, all you need to know the Cv or Cp of the gas as a function of temperature in the ideal gas limit, the PvT real gas behavior of the gas, the Cp of the liquid at low pressures (say 1 bar) and the PvT behavior of the liquid.
I'm not familiar with this tool, but if it assumes ideal gas behavior of the vapor, it is probably not going to satisfy your needs at all conditions.
