Does QED Originate from Non-Relativistic Systems?
  • Level: Graduate
  • Thread starter Thread starter A. Neumaier
    Qed
185 replies · 25K views · last reply
Well, if it's not done, it's not done. Either it's computationally impossible with contemporary computer power or it's simply not interesting enough to spend monegy and ones time to do it in this way. I tend to think the latter is the case. I don't see any merit of such an endeavor. You rather use your compute capabilities for fruitful research, such as lattice QCD in vacuo and at finite temperature!
vanhees71 said:
Well, all I am saying (and I think also Arnold is saying) is that lattice QED is not the right formulation of the low-energy (long-distance) effective theory described by QED, leading to results that agree to experiment at 12 significant digits, but that's good old perturbative renormalized QED, formulated around 1948 and finally proven to exist at all orders as a Dyson renormalizable relativistic QFT in the mid 1960ies, when the problem of overlapping divergences was finally solved by the work of BPHZ.
The point is not to take lattice QED as the low energy theory - the point is to take it as the high energy theory (the starting point for arguing that textbook perturbative covariant QED is a low energy effective theory) - ie. the same as perturbative QED with a cutoff. And once you have a cutoff, you don't have Poincare invariance.
A. Neumaier said:
1-loop QED exists rigorously at all energies. It is invariant under exactly the same Poincare group as the full theory. Only the accuracy is not the same at high energies as that of fully nonperturbative QED, whose existence is in doubt. But it is already much better than anything what lattice QED has to offer.
Can you even show that 1-loop QED is a quantum theory? Typically, one needs to show that a QFT obeys the Wightman axioms or something equivalent.
Also, if your claim is true, then we would already have rigourous 3+1 interacting relativistic QFT. Yet as far as I know, there is not yet any successful construction of relativistic QFT, even in finite volume, for 3+1 dimensions. So I am very skeptical of this claim.
Then we agree on that.
Well, there are some merits to think about the aximatic foundation of QFT, but FAPP it's pretty useless since so far this program has not solved any of the problems to define non-perturbative QFT of interacting particles in (1+3)D spacetime. On the other hand the non-rigorous techniques of renormalized perturbation theory of the continuum theory, which keeps everything Lorentz invariant at each stage of the calculation (which is a great simplification and advantage also from a purely calculational point of view), is a great success for the Standard Model as a whole (not only QED as one of its parts). That's why physicists use this formulation and not lattice methods, where they obviously are not applicable for this purpose.
Last but not least, only the renormalized parameters, finite when an eventually used intermediate regularization (and discretizing spacetime to a lattice is one such possibility to regularize the theory) is put to the physical limit (in the case of lattice regularization lattice spacing to 0 and the volume to entire ##\mathbb{R}^4##) are physical. They are defined by the renormalization scheme and have a clear physical meaning within this scheme. The values of the renormalized and finite parameters (wave-function normalizations, masses, and coupling constants) are fixed by appropriate measurements of cross sections needed to fix these values.
But in the non-rigourous point of view, the series is a perturbative series or asymptotic series to the true relativistic theory. If we only keep the terms to 1-loop - usually in the path integral formulation - do we know that we have a relativistic Hamiltonian quantum theory?
But the point of the Wilsonian view is that we don't have to take the lattice spacing to 0. Taking the lattice spacing to 0 is the same as taking the energy to infinity, and no one has shown a way to take the energy to infinity for QED.
Demystifier said:
I am saying that these 12 significant digits scan also be obtained by perturbative renormalied QED at the lattice.
This is an extraordinary statement that needs proof to be credible.
A. Neumaier said:
This conclusion by experts on the subject is diametrically opposite to atyy's claims that lattice QED is a good approximation of QED, or a good starting point for low energy QED.
Their simulations (which were still fairly long distance and low energy, otherwise it would have taken eons to simulate) showed that already at computationally accessible spacing lattice QED behaves already almost like a free theory. At very short distance/high energy, the Landau pole ruins the closeness to real QED. Hence lattice QED is unlikely to give sensible approximations at any distances or energies.
... where it is already very close to free, much closer as in the experiments reported by by Montvay and Munster ? How can you believe that coarsening a nearly free theory that doesn't resemble QED at all gives a good low energy approximation to QED. The differences between lattice QED and real QED grwo with the energy as the former becomes more and more free while the latter is not asymptotically free and its interactions become stronger and stronger!
If this is not quantum theory then why is the subject called quantum field theory? Quantum theory existed already for 30 years and was in a very healthy state before Wightman devised his axioms. So the latter are surely not necessary to recognize a quantum theory.
Not even your hallowed lattice QED would then be a quantum theory!
You had asked for the Hilbert space of QED and I explained it. One can do covariant CTP (closed time path) quantum mechanics at one loop and gets in this approximation everything one wants, including the approximations from which one can derive the hydromechanics of plasmas.
One can take the energy to infinity in all 1-loop formulas and gets mathematically meaningful covariant results.
That they differ from potential theoretical physics at extremely high energies that can never be realized experimentally is completely irrelevant. It neither affects the Poincare invariance of the formulas nor the fact that 1-loop QED is quantum field theory, even one of its highlights, discussed in every book on quantum field theory.
Lattice QED is a quantum theory not because it satisfies the Wightman axioms, but because it obeys QM101 - Schroedinger equation, unitary time evolution, Hilbert space etc etc. To be clear, I mean Hamiltonian lattice field theory.
It is not sufficient to assert that something called QFT by convention is quantum. Satisfying the Wightman axioms is important because it shows that what one calls QFT is a relativistic quantum theory.
The problem with your statements is you seem to believe there is something called real QED. As far as I can tell, your proposal for real QED is 1 loop QED which is claimed to be a rigourously constructed relativistic QFT in 3+1D. I'm open to being convinced, but as far as I know, there is no rigorously constructed QFT in 3+1D at the moment, so I have to be skeptical.
My position is that without either lattice or a theory satisfying the Wightman axioms (or equivalent), QED cannot be said to be a quantum theory. It is only a collection of calculation fragments. Of course, they are very important fragments, and the Nobel to Schwinger, Tomonaga and Feynman was deserved, but it doesn't change the fact that it remained to be shown by Wilson, Wightman, Nelson, Osterwalder and Schrader why the standard perturbative renormalization deserves to be understood as a quantum theory.
Just get over it, there is no interacting QFT in 1+3 D satisfying Wightman axioms.
To be fair, as far as I know, it is not even clear whether free lattice quantum Maxwell theory (expressed as a usual lattice gauge theory in terms of holonomies, instead of a vector field living on the vertices) approaches free quantum Maxwell theory in the continuum limit.
Also, it is possible to obtain perfectly rigorous versions of perturbatively defined QFT's in the framework of AQFT, by using states with values in the ring of formal power series instead of the complex numbers. Of course, the Hilbert space formulation would look a little bit odd, because it would be some generalization of a Hilbert space over the ring of formal power series instead of the complex numbers and it's not clear how such a theory should be interpreted.
But I would agree that the ultimate goal is of course to obtain well defined QFT's that satisfy the Wightman axioms.
So would you agree that 1 loop QED is a rigourous construction of a relativistic QFT in 3+1D at all energies (finite volume is ok)?
atyy said:
So would you agree that 1 loop QED is a rigourous construction of a relativistic QED at all energies (finite volume is ok)?
It can be rigously formulated in the framework of perturbative AQFT (see Brunetti, Fredenhagen, ...), but that doesn't mean that we should be satisfied with it. Physical quantities in this framework are given by formal power series and it is not clear how they should be interpreted if they can't be summed. Of course, you can just take the first 137 orders and sum them up to obtain actual numbers that can be compared with experiments, but that's not very satisfying in my opinion. Not everything that can be formulated within some rigorous mathematical framework leads to an unproblematic physical theory.
And if we just take the first 1 or 2 or 137 orders, do we obtain a rigourous relativistic QFT?
No, you need values in the ring of formal power series, which is why the interpretation is unclear unless they converge. And even if you take all orders, the QFT will be rigorous only in the sense of perturbative AQFT and not in the sense of Wightman. (137 was just an random example. We expect the power series of QED to start diverging somewhere near that order.) But perturbative AQFT is a rigorous framework and things like Poincare invariance can be discussed within it. The point is not such much whether the framework is rigorous, but rather whether we should really adopt it as a framework for physical QFT's. I consider it more as a compromise, because the real goal (a 4d Wightman QFT) is nowhere in sight.
Why is this the goal, as opposed to finding alternative axioms or framework compatible with the known facts?
Thanks. Although I can't understand the detailed mathematical reasoning, that makes intuitive sense to me. And yes, I always mean rigourous and physical (ie. formal power series that cannot be summed are not physical).
Because the Wightman axioms are the most reasonable and intuitive axioms we could think of. Of course, many people have proposed alternative frameworks, but none of them seem as physically reasonable as the Wightman axioms.
A short introduction can be found here: https://arxiv.org/abs/1208.1428
Apparently, Kasia has written a book by now. Here's the link: http://www.springer.com/de/book/9783319258997 (I don't know if it's good)
Moderator's note: a number of off topic posts have been deleted. The discussion in this thread is specifically about QED as a theory; phenomena not described by QED are off topic for this thread.
Because within the known assumptions of a non-dynamic special relativity-compatible background (i.e. Minkowski spacetime) and locality (finite no. of spacetime derivatives), the only way to formulate axioms of QFT so that they resemble the axioms of QM (the Dirac-von Neumann set including state vector collapse) is the Wightman way. The alternative to Wightman's axioms are the Haag-Ruelle algebraic QFT axioms.
Why should we keep only terms to one loop. In QED Kinoshita et al have done the calculation to 5 or even more loops. The asymptotic series tells you where to stop, namely at the order, where the apparent corrections get larger than the previous order. The proper vertex functions and thus also the connected Green's functions used to calculate approximations to S-matrix elements in perturbation theory are manifestly Lorentz covariant.
The regularization has been taken to the physical limit after renormalization. That's the point of renormalization. The RG equations tell you, when the perturbative approach breaks down, namely when the running couplings get large (at low energies for QCD at (very) high energies for QED).
It is sufficient. Neither Weinberg nor Peskin and Schroeder base their treatises on quantum field theory on the Wightman axioms; this is only the mathematical physicists convention, and the latter are a small minority among quantum physicists.
2-loop QED is another real QED, also rigorously constructible. That you are not convinced doesn't matter; the Nobel committee was convinced enough, and the world followed.
To be precise, there is no known one. This is a small but very important difference.
This is incorrect. One can make many compromises in the Wightman axioms and still reconstruct a Hilbert space from them. In the Wikipedia treatment linked to, Axiom W3 (local commutativity or microscopic causality) can be dropped and the Hilbert space construction still goes through. With this axiom dropped it is very easy to construct plenty of models.
Sure, but that's my point, that the ultimate goal should be to come up with axioms that overcome some of those assumptions and still are compatible with the observations. It seems self-defeating to discard even in principle that somebody could come up with such axioms just because it is very hard or nobody has been able so far when historically that has been the way of scientific progress.
RockyMarciano said:
Neumaier goes on insisting in keeping it to low order because he knows that many QED procecess have higher order corrections that involve interactions other than the electromagnetic
QED is well-defined and covariant at any order, independent of corrections by other theories that are not QED. In this thread we are only discussing QED (and contrasting it if necessary with other theories such as QCD).
To get full quantitative agreement with reality to extremely high accuracy, one cannot use QED at all, but needs the standard model plus gravity. But this is a completely different matter.
Hm, but to what should such a model lead? I always thought the microcausality condition is very important to get a Poinare covariant S-matrix?
At least in Weinberg's book it's stressed that in order to have the S-matrix Lorentz covariant the Hamilton-density operator has to commute with itself for space-like separated arguments, because in the perturbative formulation you get time-ordering into the game, and this time ordering is only invariant under proper orthochronous Lorentz transformations if the Hamilton-density operator (or at least the interaction part) commutes with itself for space-like separated arguments.
Maybe you can weaken W3 to the extent that only this weaker condition is fullfilled, although I guess it's not so easy to construct Hamilton densities out of fields which do not commute or anti-commute for space-like separated arguments.
