Does quantum mechanics obey causality?
80 replies · 9K views
n01
My intuition tells me that it does not given that physical phenomena don't obey the principle of sufficient reason under quantum mechanics (a dogma many still hold certain). A lucid definition of the PoSR can be found here. Meaning, that some events are non-localized and the distinction between localized phenomena and global phenomena gets significantly blurred.
I don't see where else to post this as it's more of a meta-physical question.
Quantum field theory obeys causality. The commutator between spacelike separated points in spacetime vanishes, which means they don't influence each other.
Its associated with the cluster decomposition property:
https://www.physicsforums.com/threads/cluster-decomposition-in-qft.547574/
Normal QM being based on the Galilean transformations doesn't. To fully understand the connection see the following beautiful book by the great theoretical/mathematical physicist Lev landau:
https://www.amazon.com/dp/0750628960/?tag=pfamazon01-20
I don't know why but that is the only book I know that gives the details, admittedly in Landau's usual terse style. Its very important but other books simply do not delve into it.
You will find QM dynamics developed from Galilean Relativity in Chapter 3 of Ballentine. Its the reason for Schrödinger's equation etc so is foundational and inescapable in ordinary QM. One must go to QFT to rectify it.
Thanks
Bill
Yes there is causality just sometime it is reversed
Its actually a deep physical question going to the heart of modern physics and its foundations from symmetry. It was quite possibly the deepest discovery of 20th century physics that symmetry is of such importance to physics like in the 19th century mathematicians discovered its importance to mathematics and especially geometry. I suspect there is a deep secret there waiting to be uncovered - but only time will tell.
Thanks
Bill
There is no causality in standard QM as can be seen by the form of the Hamiltonian obeying the Galilean transformations.
You are thinking of the retro-causal transnational interpretation. Its simply that - an interpretation.
Thanks
Bill
You have right.
One of the possible right interpretation.
bhobba said:
Its actually;y a deep physical question going to the heart of modern physics and its foundations from symmetry. It was quite possibly the deepest discovery of 20th century physics that symmetry is of such importance to physics like in the 19th century mathematicians discovered its importance to mathematics and especially geometry. I suspect there is a deep secret there waiting to be uncovered - but only time will tell.
Thanks
Bill
Yes,
I'm keenly interested on this from a quasi-computational perspective, and in some sense it's a tautology. So, let me elaborate if I don't start sounding metaphysical. Given that every physical law is either computable or non computable, then within such a system there will arise situations or "state of affairs" that could not be explained within the system itself. This is basically Godel's Incompleteness theorem stated in a nutshell.
My hunch is that QM and the logical conclusions derived at by Godel are in some deep sense intertwined and manifest in reality (I mean, how can they not be... unless we're talking about higher dimensions; but, even then those higher dimensions would require another higher dimension to maintain deterministic causality of each sub-dimension).
Hope that doesn't sound too outlandish as it does to me.
I take Godel a little more loosely, as in the system being used can't encompass all of reality, not that any given reality can't be modeled completely by a complete system. In my humble opinion, it is due to the introduction of supposed "infinite" degrees of freedom into a "finite" system which leads to the inconclusive result...
Is this a definition of causality or merely a requirement of such? There are those amongst us that might claim entanglement experiments demonstrate superluminal "cause". I am very much not one of them.
"they don't influence each other" is what I would consider as definition of locality - causality then arises if you consider the evolution in one time-direction.
There are non-local interpretations of quantum mechanics - but you don't have to follow those, there are also local interpretations.
People keep saying this, but to me, it's only addressing half of the quantum formalism. In quantum mechanics, you apply mathematics in two different ways:
  1. The state and/or the field operators evolve with time.
  2. You use the state to compute probabilities of outcomes.
The issue with whether QM is causal was never about #1, it was about #2. When you observe an outcome, does the state change? If so, how? The fact that field operators at a spacelike separation commute (or anticommute) doesn't have any obvious relevance to the question of whether Von Neumann's collapse happens, and whether that collapse (if it does happen) violates the no-FTL rule.
#1 would be sufficient to prove that causality is never violated, if that were the only process involved in QM (as is the case in many-worlds). But that conclusion doesn't follow from QFT, it requires an interpretation of QFT.
If there is a causal interpretation (and there is: MWI for example), and a non-causal interpretation, I would call the underlying theory causal. If it would be non-causal, then causal interpretations would be impossible.
IMO, the entire reason "Does QM obey causality" is a question is due to a lack of a well defined theoretical or operational definition of the term "causality". The appearance of probability in a theory complicates this question.
n01 said:
My intuition tells me that it does not ...
There is no physical evidence that at the quantum mechanical level there is any cause which specifically determines an outcome to a measurement (excepting repeated measurements when the systems is already in a known state). I doubt anyone here would dispute that statement.
It is a metaphysical question (as you say), because there are interpretations in which there are such causes. However, those interpretations cannot be discerned from non-causal interpretations by virtue of physical evidence. It is by inference and personal preference alone that such can be made.
If any of you are interested in entertaining this thought and possibly looking at it from a more specific example of the origins of causality in QM...
I have always been puzzled by what exactly determines a wave function collapse? Or stated another way, what keeps quantum systems evolving as opposed to simply collapsing on itself?
vanhees71 said:
There is no wave-function collapse. So you don't bother you with it :-).
Well, yes according to the MWI; but, in that case what determines that our universe is the way it is as opposed to other worlds?
I don't believe in the religion of MWI. I'm a proponent of the minimal statistical interpretation. "Collapse" is just the interaction of the measured object with the measurement device, which usually is macroscopic, and we coarse grain over many microscopic degrees of freedom which leads to the classical behavior of the relevant observables of measurement apparatus. Thus, in general we don't know the state of the total quantum system (measured system + measurement apparatus), and tracing over the measurement apparatus leads to a mixture for the state of the observed system.
Yes. Quantum mechanics is probabilistic, but it's not random. The probabilities are deterministic.
Do you call all interpretations religions?
Even worse, in the minimal statistical interpretations there is not even such a state, because you cannot give the wave function a physical reality (otherwise you need some way to get rid of it).
Is there an operational definition of or measure of something having "a physical reality?". IMO, the fact these so called interpretations can't be distinguished by the theory or experiment is proof they are simply added baggage that add nothing to the science.
The problem is that you need an interpretation to make experiments: you have to relate the theory to what you get as experimental result. This is trivial for all theories apart from quantum mechanics, so it seems to appear only there.
So you classify the Born rule as interpretation? It's what's observed to happen in experiments. Geiger counters count and photoelectrons are collected, at random.
I would like to understand to what extent this statement is justified.
I will use an analogy. Parent has two different candies. Two kids ask him for candies, one asks first and the other one later. Parent gives random candy to the kid who asks first and the other one to other kid. Basically either kid can't really influence which candy he will get and which candy will get the other kid by asking fist or second. But just the same the two events are not independent.
So just because commutator vanishes we can't really claim that the two spacetime points are independent, right?
It's the usual answer.
1. Commutator vanishing implies signal locality, which QM respects.
2. Commutator vanishing does not imply local causality, which QM violates.
Depends on how you use the rule, but in general: yes.
That is an interpretation already. How can you be sure it is random (all deterministic interpretations)? How can you be sure that your measurement result is the only one that happened (MWI)? How do you interpret small deviations from the Born rule (which will typically happen - within the uncertainty)? And why do you choose the Born rule?
All those questions do not have testable laws of physics as answer - they are interpretations.
Correct me if I am wrong, but the mainstream dominating thinking in Quantum Mechanics (QM) since the 1930s is the Copenhagen Interpretation (CI) conceived mainly by Niels Bohr. The non-causality of quantum effects is the heart in the CI. But since then (and even simultaneously with the CI) there are alternative models of QM which diminish the non-causality in QM and render greater causality to the quantum effects. The price for this is, as far as I get, that they assume some unidentified pilot waves, unidentified quantum fields, physical realities outside of our space-time. But all these do give some sense to the weirdness (non-causality) of QM as revealed in the CI.
An experimental evidence for a pilot wave pattern was found around 2 years ago in a macroscopic scale: https://www.quantamagazine.org/20140624-fluid-tests-hint-at-concrete-quantum-reality/
Please note that it's not any direct quantum effect found in a macroscopic scale, but just a pattern appearing in a macroscopic scale which is identical to a predicted pattern appearing in an alternative quantum model to the CI.
2 examples (books) for such alternative different models:
a. Wholeness and the Implicate Order, by David Bohm (The conceiver of the Pilot Wave model)
b. The Transactional Interpretation of Quantum Mechanics -- The Reality of Possibility, by Ruth E Kastner (the idea first conceived by John G Cramer in 1986).
Even classical statistical mechanics has this issue which is also an application of probability theory. Is it "truly random" (what ever that means) is not a question for physics unless it is a testable assertion. The Born rule states one uses probability theory to connect the formalism with experiments and says nothing about the results being or not being truly random. This connection has been tested with nearly every experimental application of the theory. For me the Born rule is not interpretation but an established fact. In this narrow sense it's no different than the application of probability in statistical mechanics.
Yes there is. Its when decoherence occurs. The question that is left up in the air, not addressed, explicitly or not explicitly stated etc etc, depending on what you are reading, and how careful they are, is how does a improper mixed state become a proper one. Colloquially its - why do we get any outcomes at all. THE book that carefully and exhaustively explains all this is Schlosshauer's standard text :
https://www.amazon.com/dp/3540357734/?tag=pfamazon01-20
Thanks
Bill
