Does stopping a very fast object makes it lighter?
  • Context: High School
  • Thread starter Thread starter Reogl
The discussion revolves around whether stopping a very fast-moving object results in a loss of weight or mass. Participants explore various scenarios, including the behavior of electrons in magnetic fields, the effects of heating on mass, and the implications of relativistic mass. The conversation touches on theoretical concepts, experimental observations, and hypothetical situations.
  • Some participants assert that stopping a fast-moving object does not inherently cause it to lose weight, unless additional factors are involved.
  • One participant suggests that the mass of a system may change due to energy transfer, such as in the case of a discharging or charging battery, which can be experimentally verified.
  • Another participant introduces the idea that the mass of an object can be affected by radiation, particularly in the context of electrons in a magnetic field, where mass may increase or decrease based on energy interactions.
  • There is a discussion about the concept of relativistic mass and its relevance, with some arguing that it leads to misconceptions and is not used in modern physics.
  • A hypothetical scenario involving a meteor is presented to question whether halting it would result in any mass change, prompting further debate about the implications of such a scenario.
  • Some participants challenge the definitions of mass and energy conservation, suggesting that mass is not conserved in the traditional sense and that effective mass can be assigned based on energy content.
Participants do not reach a consensus on the relationship between stopping a fast-moving object and changes in mass or weight. Multiple competing views remain, particularly regarding the definitions of mass and the implications of energy conservation.
Participants express uncertainty about the definitions of mass and energy conservation, with references to outdated concepts and the need for clarity in modern physics terminology. Some claims about mass changes are based on experimental observations, but the extent and implications of these changes remain debated.
Reogl
Hey guys,
If we stop a very fast moving object will it lose weight ?..i need a hand on this matter. Thanks
Science news on Phys.org
No, unless something additional happens which you did not specify here.
No ideal what to add..
maybe: speed of moving object = half c , stop point in reference to the point of initial contact..
in a way , since you mention "unless" i assumed it is positive
Well ... hot brakes surely have more mass than cool brakes.
Now, if the mass of a car can not change, then other parts of a car must lose mass, when the brakes are gaining mass.
time \downarrow
m=1
...:cool:... fast moving
v=c/2-->
m=1
...<--F=1... x=0 start stopping
v=c/2-->
m=?
...:mad:<--F=0... x=1 End here
v=0
Let us postulate that:
1: mass is conserved in a closed system
2: radiation has mass
Now let us consider a fast moving electron that enters a magnetic field. In a magnetic field electrons:
1: radiate
2: decelerate
Mass is conserved in the closed system consisting of the electron and a magnet, so the mass increace caused by the creation of radiation is canceled by the mass decreace caused by the deceleration of the electron.
Awesome! mass was decreased then we have "light electron"
but will the -e absorb radiation & increase mass if magnet field is reverse to accelerate it?
I'm not sure about this - surely in some reference frame any moving object will be stationary, or in another reference frame have a much greater velocity. Wouldn't it only be apparent that it had 'higher energy' if it was collided with something?
A discharging battery loses mass, this can be verified experimentally.
A charging battery gains mass, this can be verified experimentally.
An electric car, with two batteries, accelerates using battery 1, and then decelerates charging battery 2 with the energy generated during the deceleration, has the same mass at the end as at the beginning, except that battery 1 lost some mass, and battery 2 gained some mass.
Now let us ask: How did mass travel from battery 1 to battery 2 ?
Well my answer is that when the car was moving at high speed, the mass had left battery 1, but the mass had not entered battery 2, so the mass was in the material of the car.
No magnetic field is needed in this case.
Let's weigh a cold piece of metal.
Then we warm the piece of metal using a micro wave owen.
Then we weigh again.
We notice that the weight incraced. The electrons in the metal absorbed radiation, and now the collection of electrons weighs more.
correction.."light electron" is not especial. same as any electron at rest..
#10 Interesting , thanks
a reliable source informed me that minimum mass of an object is when it is at rest..
Both postulates are wrong. Energy is conserved, and radiation has energy (but not mass). Mass is not conserved.
You can assign an effective mass to a system, based on its total energy content in its center of mass. That is conserved, but it is not the sum of masses of its components.
Do you know of any publication showing this?
The effect is there (with the effective mass as above), but it is so tiny that I did not know that it can be measured yet.
What if the object is a meteor that just missed the moon and is suddenly prevented by a superman from colliding with our planet successfully halted before entering the atmosphere?
Maybe far out example of no heat exchange involved, the doubt is: when we push on object it would gain mass to not reaching c, and halting the meteor is like pushing it too.
s.o.s.
Why do you expect any changes?
If you do not expect changes, why did you invent that scenario?
The concept of relativistic mass leads to all sorts of misconceptions, and you won't find it in modern physics any more. Just in some old textbooks and at bad science websites.
sorry..lets omit the "to not reaching c"
i expect answer.
scenario is part of the query.
oh.. is relativity passe
That is wrong.
Unless you use a definition of "mass" which was abandoned some decades ago.
mfb said:
That is wrong.
confusing one mfb
you mean That is right only if I use abandoned definition of "mass".
so where can i get this decades old "mass'' definition?I am new to science and starting on "emersion stage" and afraid someday i shall reach the "i had enough-of-it stage"
___________________________________________
Imagination is superior to knowledge : A German Physicist -Mathematician
Pots don't crack by themselves : A mother
I see.
So: When two fast objects are stopped, the effective mass of the object pair decreases.
For example, when an electron hits the magnetic field of the earth, the effective mass of the electron-earth system decreases, and radiation is produced with effective mass equal to the lost effective mass.
I meant that with good enough instruments the mass change of charging battery could be measured. I think there is no need to call this mass change "change of effective mass".
Right. See relativistic mass for details.
I would not talk about a single mass for "electron+earth" together... but if you do that, and the radiation is lost, the effective mass of "electron+earth" is reduced and the leaving photons carry some energy. However, that change is completely negligible.
  • · Replies 27 ·
  • · Replies 36 ·
  • · Replies 22 ·
