Does the Creation Operator Have Eigenvalues?
10 replies · 4K views · last reply
carllacan
Prove that the creation operator [itex]a_+[/itex] has no eigenvalues, for instance in the [itex]\vert n \rangle[/itex].
Action of [itex]a_+[/itex] in a harmonic oscillator eigenket [itex]\vert n \rangle[/itex]:
[itex]a_+\vert n \rangle =\vert n +1\rangle[/itex]
Calling a the eigenvalues of [itex]a_+[/itex]
[itex]a_+ \vert \Psi \rangle = a \vert \Psi \rangle = a \sum c_n \vert n \rangle = \sum a c_n \vert n \rangle[/itex]
[itex]a_+ \vert \Psi \rangle = a_+ \sum c_n \vert n \rangle = \sum c_n a_+ \vert n \rangle = \sum c_n\vert n+1\rangle = \sum c_{n-1}\vert n\rangle[/itex]
Equating both
[itex]a_+ \vert \Psi \rangle = \sum a c_n \vert n \rangle= \sum c_{n-1}\vert n\rangle[/itex]
We have
[itex]a c_n = c_{n-1}[/itex].
I think I can take the a factor out and then claim that eigenkets have to be linearly dependent, so their coefficients cannot be proportional to each other.
However, I am not sure that this does prove that the creation operatro has no eigenvalues.
Hi,
##a=1=c_n=c_{n-1}=...## is a solution of the equations for the coefficients. What happens when ##a_+## is applied on ##|\Psi>=|n>+|n-1>+...+|n-m>##?
bloby said:
Hi,
We get ##a_+|\Psi\rangle=|n+1>+|n\rangle+...+|n-m+1\rangle##. If the set of eigenvalues for the oscilator Hamiltonian is infinite (and it is, right?) the sum remains the same except for ##\vert 0 \rangle##, which becomes ##\vert 1 \rangle ##. Since this is the new ground state we have transformed the oscillator eigenkets into eigenkets for an oscillator with ##\hbar \omega ## more energy. Is that so?
What now? I don't know what do you mean.
carllacan said:
(and it is, right?)
Yes but you are more interested in eigenvector to express ##|\Psi>##.
Yes and what is ##a|\Psi>## with a=1 in the basis ##\{|i>\}##?
No, it's just some algebra to show that there is no vector ##|\Psi>## such that ##a_+|\Psi>=a|\Psi>##. The example with a=1 is just a simple example to see what happens.
If you add the bounds to the sums in your attempt at a solution you will see that there is a problem.
What do you mean with the bounds?
Sorry for the delay. I will try another way: you expended ##|\Psi>## on the basis ##\{|n>:n=0,1,...\}##. On one hand you multiplied it by a and you obtained ##a|\Psi>## on that basis. On the other hand you applied ##a_+## on it and you obtained ##a_+|\Psi>## on the same basis ##\{|n>:n=0,1,...\}##. For the two vectors obtained to be equal the coefficients must be equal for all basis vectors. Your result ##a c_n=c_{n-1}## cannot hold for all n, do you see why?
Try writing out the first few terms of each summation.
Wow, why do you apologyze? You're helping me! I really appreciate it, no matter how long does it take.
I've just realized that ##\hat{a}^{\dagger}\vert n \rangle = \sqrt{n} \vert n \rangle ##, so my recursion formula should've been ## c_n a = c_{n-1} \sqrt{n} ##.
Anyway, I don't see what's the deal with it. Is it with the ground state? It is 0 in one expansion and ##c_0 a ## in the other one.
bloby said:
Exactly. And they have to be the same, so...?
So ##c_0## is zero and so are all others. Thank you!
Some clean up is needed(what if a=0? what if ##c_0##,...,##c_i##=0?) but you get it.
