Does the current increase or decrease through the resistor ?
2 replies · 3K views · last reply
Jahnavi
Circuit schematic with battery E, r, resistors R1, R2 and variable resistor R between nodes A and B, with currents I1 and I2 labelled, followed by four answer options.
This looks to be a simple problem but the answer key has left me wondering whether I am thinking correctly .
I get option 1) whereas answer key states option 3) .
Since the variable resistance R increases , the resistance across the parallel branch (R2+R) increases .This leads to a higher voltage drop across R1 .As a result current increases in R1 .
Since the overall current from the battery decreases and current through R1 increases , current through R2 decreases .
I am getting option 1) . Is that right ?
  • Circuit schematic with battery E, r, resistors R1, R2 and variable resistor R between nodes A and B, with currents I1 and I2 labelled, followed by four answer options.
Jahnavi said:
Since the variable resistance R increases ...
Look at the circuit schematic carefully. If the slider is all the way to point A, what path does the current from A to B take?
Just after I had posted this , I realized the mistake . I should have been more careful .
Thanks !
