- 13,926
- 16,810
Yes.laymanB said:So are you saying that the frame in which the traveling twin see himself at rest during the whole time from event A to B in a non-inertial frame?
Oh how that I wish it was. I find that most places that teach about the twin paradox make no mention of how to solve it without resorting to acceleration. Including the link you provided in this thread.PeterDonis said:Yes. That should be obvious.
laymanB said:Sorry, this is the only image I could find on Wiki Commons. I realize that it shows the "corner" as rounded off signifying a more realistic acceleration for the turnaround. This would be the spacetime diagram drawn in the Earth twin reference frame, correct? With his worldline from O to B in a straight line, and the traveling twin's worldline going from O to C and C to B? (Sorry to change the conventions we have been using)
So I was envisioning that if the spacetime diagram drawn in the reference frame of the traveling twin who considers himself at rest the entire time, that is image would be symmetric along the ct axis. Obviously not right.
Thanks, I think you are hitting on where my problem is at. Could you provide a link to that thread?PeroK said:There's a difference between a rest frame and an IRF. In a previous thread I analyzed this problem from the traveller's outbound IRF. In this frame, the Earth moves with constant velocity. On the outward leg, the traveller is at rest in this frame. But, on the homeward leg the traveller is also moving in this frame.
The thing the traveller cannot do is associate their rest frame with a single IRF throughout.
laymanB said:Thanks, I think you are hitting on where my problem is at. Could you provide a link to that thread?
Thanks. I very much enjoy both of your posts. Thanks to you and @PeterDonis for your patience.PeroK said:Search for "Einstein or Resnick" in the title. It's post #75 from Nov-15.
It's a useful exercise in SR if nothing else.
But, looking forward to your study of GR, you need to think more and more about the geometry of spacetime and follow the posts of @PeterDonis.
laymanB said:This would be the spacetime diagram drawn in the Earth twin reference frame, correct?
laymanB said:I was envisioning that if the spacetime diagram drawn in the reference frame of the traveling twin who considers himself at rest the entire time, that is image would be symmetric along the ct axis.
laymanB said:I find that most places that teach about the twin paradox make no mention of how to solve it without resorting to acceleration. Including the link you provided in this thread.
laymanB said:In post #27, you did say that the acceleration is not ignored, just idealized.
I think you and @PeroK have found where my confusion lies. It seems to be this misconception that I can equally analyze the problem from both the perspective of the Earth twin and traveling twin as if they are both in inertial frames the entire time and then compare the results. I have a sneaking suspicion that many others like myself are tripping over this same point. Time to get a better handle on frames. Thanks.PeterDonis said:The key problem is that, as has already been said, any "frame" in which the traveling twin is at rest the whole time is not an inertial frame. That means that, no matter what the spacetime diagram in that frame turns out to look like, you can't draw any conclusions based on it the way you can draw conclusions based on a spacetime diagram drawn in an inertial frame. For example, in a spacetime diagram drawn in a frame in which the traveling twin is at rest the whole time, the traveling twin's worldline will look like a straight line. But you cannot conclude from that that the traveling twin does not feel acceleration, or that his proper time between the start and end events is maximal; whereas you can conclude those things about the Earth twin from the diagram you showed, drawn in the Earth twin's rest frame, because that frame is an inertial frame and you can draw conclusions like that from a spacetime diagram drawn in that frame.
laymanB said:Time to get a better handle on frames.
You are right. This website is quite good if it is read carefully and you understand the implications of the changing IRF. If you don't, like I didn't initially, it seems like mathematical slight of hand.PeterDonis said:Read that article again, carefully. In particular, read the spacetime diagram analysis, carefully. Nothing in that analysis "resorts to" acceleration; the only time acceleration is mentioned at all is in postulating that it doesn't affect the mechanism of clocks.
laymanB said:If you don't, like I didn't initially, it seems like mathematical slight of hand.
PeroK said:It's actually "sleight of hand", but that's another matter.
Nicely done. Thanks for taking the effort to write this up.PeroK said:This confirms that if the traveller could instantaneously change direction, the results would be the same as obtained from the Earths frame.
Add a third party, one who travels at 0.6c in the opposite direction. So we have a stay-at-home, an outbound traveller, and an inbound traveller. The outgoing traveller never stops, simply reports their clock reading to the inbound traveller when they pass each other. When the inbound traveller passes the stay-at-home they report the outbound's outbound time plus their own time since they passed the outbound. This must give the same answer as the twin paradox, but there is no acceleration whatsoeverhutchphd said:The crux is that the traveling twin has to experience acceleration in order to make a return. So if he makes a linear trip it is during the interval when he decelerates from +0.6c to -0.6c where all of the asymmetry in aging must take place! So while he is turning around some weird stuff happens...
I just described a variant of the experiment with no acceleration and the same result. So "necessary" is false.hutchphd said:The acceleration is both necessary and sufficient for again meeting. It is the only such asymmetry in the problem. It therefore must be the "cause" of the age difference. QED
#51. See also PeroK's #45 for a longer discussion.hutchphd said:What number comment describes that variant?...I missed it...sorry
Oh I found it. In fact this is exactly my point...the asymmetry comes from the change in direction. All the time the rover twin is traveling uniformly, he will see the clocks on the Earth ticking more slowly than his (and vice versa). Imagine his surprise when his Earth twin is older! That extra time on Earth must have transpired during his deceleration! When he gets home he will be younger yet except for the noninertial parts of the trip each twin will agree (correctly!) the other's biological clocks are running slower. There are pieces of general relativity that deal with acceleration but I am not able to reproduce them out of memory and too lazy to work it out right now...Ibix said:This must give the same answer as the twin paradox
This is a very common misconception. Special relativity handles problems involving acceleration just fine as long as the spacetime is flat, as it is in this discussion. General relativity is needed only if the spacetime is not flat because there are gravitating bodies involved, and then it's needed even if no acceleration is involved.hutchphd said:There are pieces of general relativity that deal with acceleration...
If you are not already familiar with the Twin Paradox FAQ at http://math.ucr.edu/home/baez/physics/Relativity/SR/TwinParadox/twin_paradox.html, give it a try, and pay particular attention to the part about the "Time gap objection".hutchphd said:That extra time on Earth must have transpired during his deceleration!
You said it came from acceleration in #50 & 52, which is a different point.hutchphd said:In fact this is exactly my point...the asymmetry comes from the change in direction
This is not true if you mean "see" literally. Due to the Doppler effect, the traveling twin will see the stay-at-home's clock ticking slowly on the outbound leg and quickly on the inbound leg. The stay-at-home will see the traveller's clock ticking slowly for the 80% of the trip time the traveller can be seen to be heading outwards, and quickly for the 20% of the time the traveller is seen to be inbound. (Edit: the 80/20 figure assumes a speed of 0.6c and that my mental arithmetic is reliable.)hutchphd said:All the time the rover twin is traveling uniformly, he will see the clocks on the Earth ticking more slowly than his (and vice versa).
He won't be surprised at all if he's actually been watching the other's clock.hutchphd said:Imagine his surprise when his Earth twin is older!
This is true in a limited sense. As I noted above, the slow running of the other's clock is not directly observable. It's something that each twin calculates based on their direct observations plus some assumptions about how one should synchronise separated clocks. If the traveller does that process naively before and after the turn around then they find that what they were calling "now, on Earth" just before the turn around is not the same as what they now call "now, on Earth" just after the turn around. The difference in "now" will account for the extra time.hutchphd said:That extra time on Earth must have transpired during his deceleration!
As Nugatory noted, general relativity is not needed to analyse this. You can do an analysis (for the finite acceleration case, not the instantaneous turn around) using gravitational time dilation, but that has always seemed over-complicated to me.hutchphd said:There are pieces of general relativity that deal with acceleration
hutchphd said:I used to teach relativity to freshman engineering students for fun, so here is just one more thought to slightly mess with your head. The traveling twin could start his "life" already at speed 0.6c passing Earth (hence no acceleration) and the final comparison upon his return could by made by taking a snapshot as he zoomed past Earth on the return (again no acceleration). The crux is that the traveling twin has to experience acceleration in order to make a return. So if he makes a linear trip it is during the interval when he decelerates from +0.6c to -0.6c where all of the asymmetry in aging must take place! So while he is turning around some weird stuff happens...
