- 29,937
- 21,813
PeterDonis said:What is "the general case"? We are assuming for this discussion that there is no second parameter--p is the same for all couples.
If by "the general case" you mean ##p = 0.5## (or ##\lambda = 0.5## in @Dale's notation), then the actual evidence is that this is false; the global data seems to show a value of around ##0.525## to ##0.53##.
Yes, but does it question it to a different extent for couple #2 vs. couple #1? Does their different choice of process make a difference here?
Yes, I know it's not really ##0.5##. That just makes the calculations a bit harder and asymmetrical.
The main difference is that the distribution of families are different.
Case #1 has families all with seven children (i.e. families who set out with that policy always end up with seven children).
Case #2 has families with two children upwards.
This creates an asymmetry that gets picked up in the calculations. The simple calculations I've done above. But also, if we did add another parameter, it may well be reflected there also.
For example, my guess would be that the second family would be more likely to be one of the predisposed couples than the first. I could run an example tomorrow to check this, but I think I can see how the calculations will come out.
