Does the steady-state model resolve Olbers' paradox?
  • Context: Undergrad
  • Thread starter Thread starter Jaime Rudas
61 replies · 4K views
Jaime Rudas
[Moderator's note: Thread spun off due to topic change.]
Ibix said:
No. Things far away are seen as they were in the past, and redshifted. Far enough away and you see the universe as it was before star formation and ultimately you see the last scattering surface, so you do not see stars in every direction. This is the resolution to Olber's paradox.
In the steady-state model, is Olbers' paradox resolved by redshift?
Astronomy news on Phys.org
Jaime Rudas said:
In the steady-state model, is Olers' paradox resolved by redshift?
It can't be, because it doesn't expand.
A point about the Einstein static universe - AFAIK it's unstable to small perturbations, so it can't have stars anyway without becoming an expanding or contracting FLRW universe. In fact, it can only be filled with an ideal FLRW medium - i.e. an ideal fluid everywhere in eternal thermal equilibrium with itself. So I think that the resolution of Olber's paradox in that spacetime is that the sky is equally bright everywhere.
Well, I don't know if Einstein's original model can be considered as steady-state model; I would say it's static. The one I'm referring to is this steady-state model that does expand.
That model obviously violates General Relativity because of its "continuous creation of matter", which is impossible by the Einstein Field Equation. AFAIK this criticism has never been fully addressed by proponents of the steady-state model (which has morphed several times as new observations have been made).
Reply
Oh, I see.
I don't know. I suspect you'd need a complete theory of such a universe to answer that authoritatively, and I'm not sure there is one. I do believe that extinction is an important part of how steady state proponents propose to get redshift, so they probably propose that same mechanism to dim distant stars. Faster-than-inverse-square dimming would resolve Olber's paradox in favour of a dark sky.
The steady-state cosmological model was widely accepted by a large part of the scientific community in the 1950s, especially by those who considered any model implying a beginning for the universe unacceptable, and even more so if that model was formulated by a Catholic priest.
Observations made from the mid-1960s to the present have consistently supported the Big Bang model and contradicted the steady-state model.
But my question wasn't about whether that model fit reality, but rather whether or not it could explain Olbers' paradox through redshift.
I wouldn't say "a large part", but it was a signficant number, yes.
I don't know if the mathematical development of the model was sufficiently detailed to know whether it would make a prediction for this, and if so, what it would be.
The steady-state model implies that the density of the universe and the rate of expansion are constant in space and time. The question, then, is whether, under these conditions, Olbers' paradox is resolved by the effect of redshift. In other words, my question is whether redshift alone could explain Olbers' paradox.
But that alone is not sufficient to evaluate the effects of redshift. To do that you also need a spacetime geometry, and, as I've said, the steady-state model is inconsistent with the Einstein Field Equation (because of the continuous creation of matter), so it's not clear what spacetime geometry we would use. Again, I'm not aware of any actual math for this that's been proposed by any steady state model proponents. And without that, the question is simply not answerable.
But if spacetime is homogeneous and isotropic, isn't the metric necessarily FLRW?
And if the density is constant, isn't the Hubble parameter H necessarily also constant?
And if H is constant, doesn't that imply that ##a(t)=a_0 e^{Ht}##?
Reply
Actually, a few different mathematical models have been proposed for the steady-state universe. For example, take a look at this 1960 paper by Bonnor and the references therein: The relativistic model of the steady-state universe.
Reply
Equation 1.1 of the cited paper indicates that it is the FLRW metric with constant H.
Unfortunately, the paper then shows that the equations of motion of the cosmological fluid in such a system are completely undetermined. At the end of section 3 (about half way down p 477) it points out that formulae for redshift and other such phenomena in this universe therefore include an unknown function ##dr/ds## that would have to be supplied by some other physical theory. (And much of the rest of the paper is dedicated to pointing out how implausible any such theory would have to be.)
Reply
Not if your theory violates the Einstein Field Equation.
The Bonnor paper that @renormalize cited draws this conclusion, yes--basically that the spacetime must be de Sitter spacetime (pure exponential expansion) in order to satisfy the requirement of constant "density" (why that's in scare quotes will become apparent below) and rate of expansion.
Unfortunately, there is no "continuous creation of matter" in de Sitter spacetime. There can't be, because that spacetime is a solution of the EFE--the Bonnor paper uses the EFE to derive it, though IIRC de Sitter's original derivation was somewhat different--and "continuous creation of matter" is inconsistent with the EFE, as I've already pointed out. But we know it anyway because we know all of the properties of de Sitter spacetime, and that "continuous creation of matter" is not one of them.
Indeed, there is no matter at all in de Sitter spacetime; the only "stress-energy" present is the cosmological constant. The Bonnor paper doesn't call it that because it starts with the EFE with no "cosmological term", but in fact what it ends up with for what it calls the "stress-energy tensor" is the cosmological term--in terms of the Friedmann equation, ##p = - \rho##. Of course this is well known, that you can just as well move the cosmological term to the RHS of the EFE and call it "stress energy" ("dark energy"). But that doesn't change the fact that it's not "matter"--you can't make stars and planets out of it.
The Bonnor paper glosses over this at first as well, concluding instead that what it calls the "motion of matter" in the model is "indeterminate". What it is really saying, in more standard GR language, is that de Sitter spacetime is maximally symmetric--it has a 10-parameter group of Killing vector fields, just like "empty" Minkowski spacetime. So there is no preferred congruence of timelike worldlines picked out by the geometry, as there is in, for example, a matter-dominated (##p = 0## in the Friedmann equation instead of ##p = - \rho##) FLRW universe. Describing de Sitter spacetime as an FLRW spacetime obscures this fact because it requires picking out some particular slicing, corresponding to picking some particular inertial frame in Minkowski spacetime, and calling that the "comoving" slicing--but unlike in a matter-dominated FLRW universe, there are an infinite number of such slicings you could pick that all look the same, just as in Minkowski spacetime there are an infinite number of inertial frames you could pick that all look the same.
Later on, the Bonnor paper does conclude that "both the inertial and passive gravitational mass densities" are zero in the model. This, of course, is just another way of saying that de Sitter spacetime has no matter in it--the stress-energy tensor has only "dark energy" (##p = - \rho##) and nothing else.
In short, the Bonnor paper does not support the claim that the model it studies is a viable model within GR of the steady-state cosmology--rather the opposite, it illustrates why you can't have a viable model within GR of the steady-state cosmology.
I disagree. A homogeneous and isotropic spacetime is necessarily described by the FLRW metric, regardless of whether or not it satisfies Einstein's field equations.
PeterDonis said:
The Bonnor paper that @renormalize cited draws this conclusion, yes--basically that the spacetime must be de Sitter spacetime (pure exponential expansion).
Bonnor's paper doesn't draws this conclusion. Bonnor's paper STARTS from the premise that the steady-state model metric is:
$$ds^2=-e^{2kt}(dr^2+r^2 d\theta+ r sin^2 \theta d\phi) +dt$$
where a(t) is of the form ##a_0 e^{Ht}##.
That is, it suggests that the steady-state model has an FLRW metric despite not satisfying Einstein's field equations.
If it doesn't satisfy the EFEs it won't satisfy the Friedmann equations either. It feels like a bit of a stretch to classify a spacetime as FLRW if it doesn't follow Friedmann.
I think what Bonnor is doing is pointing out that the quoted metric isn't a steady state universe in the sense McCrae wants. The metric produces a constant energy density, yes, but it's everywhere exotic matter and yields dynamics inconsistent with observation in the Newtonian limit.
Reply
There is no contradiction; they are simply two different things. One is the FLRW metric, which is general for all homogeneous and isotropic spacetimes, and the other is the Friedman equations, which deal with the behavior of the scale factor for the particular case of spacetimes that satisfy Einstein's field equations.
The metric you cite, equation 1.1 in the Bonnor paper, does specify a behavior of the scale factor. It's not just "the FLRW metric", it's a particular special case of that category of metrics. And of course this metric is also a known solution, de Sitter spacetime, of the EFE/Friedmann equations.
It suggests no such thing. As just noted (and as I already noted in my earlier post), this metric does satisfy the EFE.
That said, it should be noted that "satisfying the EFE" is not as restrictive a condition as it might seem. Mathematically speaking, you can write down any metric you like, compute its Einstein tensor, divide it by ##8 \pi## (and possibly another numerical factor that depends on your choice of units), and call that the "stress-energy tensor" of your solution, and voila, your solution satisfies the EFE. The question is whether that SET makes any kind of physical sense.
In the case of the Bonnor paper, it basically applies this process (or more precisely, describes the McCrea paper it references as applying it) to the metric in equation 1.1 to show that it leads to a perfect fluid stress-energy tensor with ##p = - \rho##. Then the paper points out the ways in which this does not make physical sense as a description of "matter" of the sort the steady-state model claims. (And that's leaving aside the point that there is no "continuous creation of matter", which is a central feature of the steady-state model, anywhere.)
PeterDonis said:
What is your basis for this claim?
The principal contribution of Robertson and Walker was to establish that the metric previously introduced by Friedman and Lemaître is the most general metric compatible with a homogeneous and isotropic spacetime, as demonstrated in the original papers by Robertson (1935) and Walker (1937).
It turns out that Ben Crowell wrote an Insights article on the steady-state model:
https://www.physicsforums.com/insights/steady-state-model-no-longer-viable/
It discusses Fred Hoyle's way of addressing the "continuous creation of matter" problem, by adding what he called the "C-field" to the model, a sort of scalar field with zero energy density and negative pressure, so the condition ##p = -\rho## only applies to the combination of ordinary matter plus the C-field. That in itself would just be an "interpretation", so to speak, of the de Sitter metric, but Hoyle added to the model the continuous creation of hydrogen atoms by the C-field, which breaks local Lorentz invariance and violates the equivalence principle, as the Insights article discusses.
Crowell notes that the C-field mechanism, on its face, doesn't appear to violate local stress-energy conservation (zero covariant divergence of the stress-energy tensor), which was the issue I raised earlier in this thread with "continuous creation of matter". However, his description of how that works appears to me to leave something out: the "continuous creation" seems to be converting C-field to ordinary matter, and I'm not sure how that can be done while keeping the total energy density ##\rho## constant and continuing to satisfy ##p = - \rho##. I'll have to see if I can find a copy of Hoyle's paper online to look at the details of the math.
Bonnor's paper says:
In the steady-state model of the universe space-time is described by a four-dimensional Riemann space with metric
That metric is the FLRW metric when ##a(t)=-e^{2kt}##
From the above, I conclude that the steady-state model is inconsistent with the Einstein's field equations and has an FLRW metric.
You are correct that the metric you quoted describes an FLRW metric, since de Sitter spacetime, which is what that metric describes, is in the class of FLRW spacetimes.
You are wrong that that metric is inconsistent with the EFE. I have already explained why it is not, more than once. I have also explained how the Bonnor paper itself shows that it is consistent with the EFE.
As for the post of mine that you quoted, it has nothing whatever to do with the metric you quoted, nor can it be combined with any of the other things you quoted in your post to reach any useful conclusion. The post of mine that you quoted gave a completely different reason for believing that the steady-state model is inconsistent with the EFE. I have also explained in previous posts how that reason is not present in the metric you quoted, which, as I have also stated (and as the Bonnor paper states), is just de Sitter spacetime. That is a reason for believing, as I've also said in a previous post, that the metric you quoted cannot be a description of the steady-state model--since it lacks the crucial feature I described.
In short, you are cherry picking things that have nothing to do with each other, and then trying to tie them together into some kind of argument. That's not valid. Nor is it contributing anything useful to this discussion.
Yes, and I also said that Bonnor presents it as the metric that describes the steady-state model.
What I have said about this is the following:
I apologize for my poor writing. What I mean to say is that the FLRW metric describes homogeneous and isotropic spacetimes even when these spacetimes don't satisfy Einstein's field equations, and that the steady-state model, despite not satisfying Einstein's field equations, is described by the FLRW metric.
No, no, no. I didn't just quote you; I also quoted Bonnor. From your quote, I concluded that the steady-state model is inconsistent with Einstein's field equations, and from Bonnor's quote, I concluded that the steady-state model has an FLRW metric.
So, is Bonnor wrong to say that this is the metric of the steady-state model?
I consider that a very serious and totally unjustified accusation, so I ask that you explain in detail where the alleged cherry picking takes place.
Bonnor himself does not make the claim that that metric is the metric of the steady-state model. He references a paper by McCrea that uses this metric and claims that it is the metric of the steady state model. However, Bonnor's analysis, as we've discussed, shows that it can't be. There is no "continuous creation of matter" in the spacetime, and indeed there is no matter in it at all. Nor is there any definite state of motion that the matter (stars and galaxies) could have--but matter (stars and galaxies) has to have some definite state of motion. So that metric simply does not describe what the steady-state model is trying to describe.
So far in this thread we have not seen any mathematical model that does not satisfy the EFE. If you are claiming that the metric referenced in the Bonnor paper is the metric of the steady-state model, then, as I've already pointed out, it is obviously wrong to say that the steady-state model does not satisfy the EFE, since that metric does.
Also, I strongly suggest that you read what I said in post #19 about satisfying the EFE (if you already have, read it again). I don't think you have fully thought through what Bonnor is actually doing in his paper.
Bonnor does make the claim that that metric is the metric of the steady-state model, and at no point does he link this statement to McCrea's paper.
I'm not claiming that, Bonnor is claiming that that metric is the metric of the steady-state model
My cosmology notes refer to the metric with ##a(t)## unconstrained by the Friedmann equations as the RW metric, and with the additional constraint of the Friedmann equations/EFEs as the FRW metric. Lemaitre isn't referenced. However, reading the Wiki article, I note that this particular distinction may reflect the personal preferences of my lecturer and/or whoever taught him.
I think we need to be careful with what we mean by "the steady state model", especially in light of what Bonnor shows in that article.
He certainly states that the metric is the metric of the steady state model, and McCrea clearly believed this too. However, Bonnor promptly shows that it is not a realistic model of our universe, being what we would now call pure dark energy. So I think Bonnor is arguing along the lines that there is a self-contradiction here: the metric is the metric of a EFE-consistent steady state cosmological model, but it doesn't describe anything remotely like our universe so it can't be the steady state model that Hoyle et al had in mind. Hence I think some care about terminology is needed because Bonnor is deliberately contradicting himself (at least in some senses) to make his point.
Reply
