Does This Sequence Converge in the 5-adic Metric?
rednalino
Metric Space and Topology HW help!
Let X be a metric space and let (sn
)n be a sequence whose terms are in X. We say that (sn
)n converges to s [itex]\ni[/itex] X if
[itex]\forall[/itex] [itex]\epsilon[/itex] > 0 [itex]\exists[/itex] N [itex]\forall[/itex] n ≥ N : d(sn,s) < [itex]\epsilon[/itex]
For n ≥ 1, let jn = 2[(5^(n) - 5^(n-1))/4].
(Convince yourself that 5^(n) - 5^(n-1) is always divisible by
4, so the exponent in the definition is always a positive integer.) The first few terms of this
sequence are
2; 32; 33554432; 42535295865117307932921825928971026432
so you would reasonably expect this sequence to diverge with respect to the usual metric on
Q (the one given by the usual absolute value).
However, show that |j2n - (-1)|5 ≤ 5^(-n) where ||5 is the 5-adic absolute value.
My Attempt:
I started by writing the claim in terms of v5(j2n + 1). Then i tried to find a recurrence that looks like this:
(j2n+ 1)^5 = (2n+1+1) + (some other stuff).
I was thinking I can show that the sequence (jn)n is also Cauchy with respect to ||5, so in Q5,the completion of Q with respect to ||5, the sequence (jn)n converges to a number j [itex]\ni[/itex]Q5 such that j2 = -1. It follows that Q5 is not an ordered field, unlike the completion of Q with respect to the usual ||5, which is our old friend R.
More people will be able to attempt to solve the problem if you define "5-adic absolute value".
http://en.wikipedia.org/wiki/P-adic_number
Basically, you take the rational numbers [itex]\mathbb{Q}[/itex] and you define some very weird norm on it. For a rational number [itex]q=a/b[/itex], you factor 5 out of it, so you get
[tex]q=5^n \frac{a^\prime}{b^\prime}[/tex]
Then you define
[tex]|q|_5 = 5^{-n}[/tex]
For example
[tex]\frac{23}{10} = 5^{-1} \frac{23}{2}[/tex]
So [itex]|23/10|_5=5[/itex].
Also, [itex]|5^n|_5 = 5^{-n}[/itex]. So [itex]5^n[/itex] converges to 0 in that norm.
Anyway. The OP should try to look at the expression
[tex]j_n^2+1[/tex]
and he should try to factor out 5 as many times as he can. Maybe try it first for small n.
Fredrik said:
That is one crazy norm. 5n converges to 0. :smile:
If p=10 (that's not a prime, I know), then you can show crazy things like
[tex]...9999999999 = -1[/tex]
In the sense that
[tex]\sum_{k=0}^{+\infty} 9\cdot 10^k = -1[/tex]
where convergence of the series is n the 10-adic norm.
It actually isn't so crazy. A naive student (who doesn't know that natural numbers have to have finitely many digitis), might do something like
Let [itex]x=...99999[/itex]. Then [itex]10x+9=x[/itex]. So [itex]x=-1[/itex].
In some sense, the 10-adic numbers are a formalization of that (wrong) argument. In the 10-adic numbers, the argument does work :-p
Then you define
For example
[tex]j_n^2+1[/tex]
starting with this
[tex]j_n^2+1[/tex]
where n=1 which is 2 from the first term from the given sequence
gives |22 +1| = |5|5 factored out 5 once.
repeated for the next term n=2, which gives |1025|5
where 5 could be factored out twice.
repeated for the next term |335544322+1| which could be factored out 9 times.
the last term given could have been factored at least 4 times.
how do i show that
5-V5[j2n+1] ≤ 5-n
