Does this spherical triangle exist?
The discussion centers on solving the 'ant and honey problem on a spherical bowl,' specifically finding the shortest route between two points on a sphere while adhering to a latitude constraint. The proposed solution involves following the great circle until reaching the latitude limit, then traversing along the latitude before resuming the great circle path. The conclusion reached is that the shortest path is determined by the azimuthal angle of the tangential point on the rim circle, with two distinct cases based on whether the angle is less than or greater than 90 degrees. The initial assumption of a close approximation to the shortest path was proven invalid.
  • Spherical geometry concepts
  • Understanding of great circles and latitude
  • Knowledge of azimuthal angles
  • Familiarity with optimization problems in geometry
  • Research spherical geometry and its applications
  • Study optimization techniques for constrained paths
  • Explore the properties of great circles on spheres
  • Investigate the implications of azimuthal angles in navigation
Mathematicians, physicists, and anyone interested in optimization problems related to spherical geometry and navigation challenges.
nixed
I am trying to solve the 'ant and honey problem on a spherical bowl' to find the shortest route between two points on a sphere when the path is constrained by not being allowed to pass higher than a certain latitude (so interrupting some great circles connecting the two points).
I intuitively think that the shortest route in this case would be to follow the great circle between the two points until the latitude is reached beyond which you cannot go; then walk along the latitude until the great circle is picked up again; then follow it down to the destination. But I have not been able to prove that this is the shortest route. If the following triangle exists then my proposed solution is not the shortest route, but if it doesn't exist then it is the shortest route.
Here is the question: Can a triangle be drawn on the surface of a sphere which has points A, A',B with known lengths A-A' and A'-B and included angle AA'B greater than 90deg for which the following property holds
|AB - AA'| < |A'B|
Mathematics news on Phys.org
I think it would be better to stick to one thread for this question.
OK thanks ! By the way I discovered that my assumed shortest path is only a close approximation to the true shortest path so the proof I was attempting based on the inequality is invalid!
This is the shortest path when the great circle from A to H is disrupted by a latitude restriction imposed by the missing top of the bowl : Choose the great circle from A which just touches the rim circle tangentially at one point C. If the azimuthal angle ø of point C around the rim from A is < 90° the shortest path from A to H is then 2x the distance A to C along the great circle then C to point ø=90° along the latitude (the rim). If C 's azimuthal angle ø≥ 90° the shortest route is 2x the distance along the great circle connecting A with the point on the rim 90° from A.
Problem solved!
  • · Replies 16 ·
  • · Replies 36 ·
