Does Time-Energy Uncertainty Violate Energy Conservation?
The discussion revolves around the implications of the time-energy uncertainty principle in quantum mechanics and its relationship to energy conservation. Participants explore whether energy conservation is violated during short timescales, particularly in the context of virtual particles and interactions such as electron-electron interactions.
  • One participant questions if energy conservation is violated during the existence of virtual photons in electron-electron interactions, suggesting that the principle only establishes a lower bound.
  • Another participant explains that the energy-time uncertainty principle indicates that a physical state can have uncertain energy, but this does not imply that energy is not conserved in quantum mechanics.
  • Concerns are raised about the misleading nature of popular explanations regarding virtual particles "borrowing" energy, emphasizing that the time-energy uncertainty relation differs from the position-momentum uncertainty relation.
  • A participant clarifies that virtual particles are mathematical constructs in perturbation theory and do not possess the properties of actual particles, asserting that energy and momentum conservation holds at interaction vertices in Feynman diagrams.
  • There is a discussion about whether energy and momentum conservation applies along internal and external lines of Feynman diagrams, with some participants affirming this idea.
  • One participant reflects on the implications of the time-energy uncertainty principle for excited states of atoms, questioning the feasibility of maintaining an electron in a specific energy state for a finite time.
  • Another participant elaborates on the concept of virtual particles being "off mass shell" and the mathematical implications of integrating over off-shell particles in quantum field theory.
  • Concerns are raised about the short range of weak interactions due to the heavy W and Z bosons, linking this to the time-energy uncertainty principle and the energy required for their creation.
Participants express differing views on the implications of the time-energy uncertainty principle for energy conservation, with some asserting that conservation is maintained while others question its applicability in certain contexts. The discussion remains unresolved regarding the interpretation of virtual particles and their role in energy conservation.
Participants note that the time-energy uncertainty principle does not have a strict mathematical foundation like the position-momentum uncertainty principle, leading to varying interpretations. The discussion also highlights the complexity of virtual particles and their representation in quantum field theory, which may not align with classical intuitions about particles.
Tanjore
Hi folks, I am new to physics forums , an engineer by profession, I have newly developed some interest for pure physics, can someone please enlighten me on the violation of energy conservation by the time energy UP? The way I understand it the principle only puts a LOWER bound.
Is conservation of energy indeed violated for a short time, taking the example of
electron-electron interaction?
for a short time that the 'virtual' photon exists is the conservation of energy violated?
what about the conservation of momentum?
The energy-time uncertainty principles basically says that sometimes a physical state has an uncertain energy. For instance, an excited state of an atom has a finite lifetime before it decays to the ground state, which translates into a slight uncertainty in the energy of the excited state. A practical result is that the light emitted by atoms falling down from that excited state can have a range of frequencies (= photon energies) instead of all having the same exact frequency.
However, this is not the same thing as saying that energy is not conserved. In quantum mechanics energy is still conserved. If you measure the energy of a system, leave it alone for any amount of time, and then measure the energy again, you will get the same value. This is because measuring the energy forces the system into a state of definite energy.
In Feynman diagrams energy and momentum are conserved even when virtual particles are present. For example in electron scattering you have an electron which gives up some of its energy and momentum to a virtual photon, which then deposits that energy and momentum in the other electron.
Unfortunately popular books quite frequently use statements regarding "virtual particles borrowing energy for a short time from the vacuum" in order to explain the time-energy uncertainty relation. This is missleading for a couple of reasons.
First the time-energy uncertainty relation is very different from the position-momentum uncertainty relation as tzhe latter one can be derived strictly based on a mathematical (geomezrical) structure of the Hilbert space plus certain operators acting on it. In contradistinction the time-energy uncertainty relation is more a "visualization"; there is no time operator in QM.
Second the term "virtual particles" is missleading as they are only mathematical artefacts arising in a certain approximatin, perturbation theory; they do not have properties of particles as used in quantum field theory, there are no associated states in an Hilbert space.
Third, if one looks at virtual particles in perturbation theory, they are represented by inner lines in the famous Feynman diagrams. Every vertex in such a diagramm (where several lines meet = where the particles interact) carry an algebraic structure descring the interaction plus a so-called delta function which guarantuees in the incoming and the outgoing momentum and energy are equal; that means at such a vertex no momentum or energy are destroyed, created, borrowed o whatever. Energy-momentum-conservation holds strictly.
Edit: this agrees with Duck's explanation
Hmm. I could not understand the technical things that you mentioned but thanks a lot for mentioning about the vertices of the feynman diagram, if energy and momentum are conserved at the vertices then they ought to be conserved all along the internal as well as the external lines. Is this right?
Tanjore said:
... if energy and momentum are conserved at the vertices then they ought to be conserved all along the internal as well as the external lines. Is this right?
yes!
Thanks a lot both of you!
Just though you might appreciate this extra 'nugget' to continue to stimulate your new-found interest in particle physics. It's an explanation (that I've copy and paste from here: https://www.physicsforums.com/showthread.php?t=32834) of what is meant by the terms - "on mass shell" and "off mass shell":
The 'mass shell' for a particle of mass m is the surface in the E - p1- p2 - p3 space satisfying the equation
E^2 - p1^2 - p2^2 - p3^2 = m^2 (factors of c omitted)
It's kind of a hyperboloid in 4 dimensional space.
Or if P is the energy-momentum 4-vector (E, p1, p2, p3),P.P = m^2
(You may see this with the opposite sign of P.P depending on the
metric.)
In classical special relativity all particles are 'on mass shell'. For
LaTeX Code: p=0 we recover the infamous
E^2 = m^2
or with factors of c replaced
E^2 = m^2 c^4
In quantum field theory particles are allowed to propagate even if
they do not satisfy this equation. In that case they are said to be
'off mass shell'. These are also called 'virtual particles'. However,
there is a penalty to pay for this, because in that case the amplitude
of interaction goes as
1/(P.P - m^2)
Particles that can propagate to infinity ('real particles') are always
'on mass shell'. In a collider experiment, a few centimetres is a
reasonable approximation to infinity, so one takes the incoming and
outgoing particles 'on shell'. Intermediate states are 'off shell' or
'virtual'.
The main point is that virtual particles are allowed to be of-shell i.e. to violate E² - p² = m².
But (!) a virtual particle is not just "one off-shell particle", but it is "an integral over all off-shell particles integrated of the complete (E,p) i.e. 4-momentum space - restricted by delta-functions at the vertices. That's the reason why a virtual particle is not a particle at all but a description for a mathematical calculation.
I remember that an electron in an excited state decays very quickly (E&M processes are very fast compared to strong or weak processes), so that should correspond to a huge spread in energy by the time-energy uncertainty relationship. However, you do see spectral lines rather than a rainbow smear, so the uncertainty can't be that bad?
Anyways, does this mean that you can never excite hydrogen into the n=2 state? Because for it to be in an n=2 state it has to stay there for infinite time, since if it only lasts between say t=-10 seconds and t=10 seconds, then it was really a wavepacket composed of states of all n?
Is this the spectral density form of the propagator? I remember that not only do you have to integrate over the complete (E,p) space, but also sum over the many-particle states which are part of the Hilbert space in the interaction picture. However, for this part, you only integrate over space for which E^2-p^2>=4m^2 since there must be at least two particles. But it seems that this cloud of virtual particles are real states in the full Hilbert space.
I read somewhere that the reason that weak interactions have short range is that the W and Z are very heavy, so if your initial particle (say a neutron) doesn't have the energy equal to the mass of the W, then it has to borrow heavily to create a W, which means the W can only exist for a short time by the time-energy uncertainty principle, which means it can only travel a short distance before it turns into an electron and antineutrino: in fact this distance is so short that the interaction can be approximated as a 4-point interaction - i.e., an instantaneous interaction. This is what Fermi calculated in the old days before the W was even known about.
RedX said:
I read somewhere that the reason that weak interactions have short range is that the W and Z are very heavy, so if your initial particle (say a neutron) doesn't have the energy equal to the mass of the W, then it has to borrow heavily to create a W, which means the W can only exist for a short time ...
Unfortunately things like that have been written in popular books, but that's confusing and missleading. The particle doesn't borrow energy E to create the W; instead the W violates the mass-shell condition E²-p²=m²; E and p are conserved, nothing is borrowed, not even for a very short time. Yes, there may be not enough energy E (and momentum p) to create a real W; instead the process uses the available energy E (and momentum p) and creates a W of some mass m=m(E,P); m becomes a function of E and p! That's what is meant be "off-shell". If you look at an off-shell photon that it has non-zero mass.
I didn't get it from a popular book. The last paragraph of page 13 of a review article written for Annual Reviews of Nuclear and Particle Science:
http://arxiv.org/abs/hep-th/0701053
says something like it too.
I agree with you: I can see the delta functions that conserve everything at each vertex. But how is it that if W is really heavy, you can ignore it for low energy processes and say that weak decay occurs by a point interaction? So I feel that it's not just a mistake by the author and there might be something to the energy-time uncertainty relation. I don't know.
OK, fine.
Omitting loops you immediately have (p²-M²)-1 = 1/M² + ... for p² << M². So for small p the propagator between two vertices collapses to a single vertex; the coupling is therefore ~ 1/M²
It is not a mistake but a perfectly valid statement; but you need not refer to something like "borrowing energy". It is simply an application of standard Feynman diagram analysis.
@RedX : </i>then it has to borrow heavily to create a W, which means the W can only exist for a short time by the time-energy uncertainty principle, which means it can only travel a short distance before it turns into an electron and antineutrino:</i>
But the time energy uncertainty principle gives a lower limit for how long a particle of energy E can last, it does not put an upper limit.
Also I have another question, in the time energy uncertainty relationship there is an inequality, I mean it is an inequality, so now my question is this , is the inequality just mathematical or does it have any importance in the physics of the process meaning can the inequality be ignored( because I have seen in textbooks that mass of pi meson is calculated simply by ignoring the inequality, can that be done?) can we simply ignore the inequality. My friend said, it could be ignored because the uncertainty in the energy of the particle is at the most equal to the energy of the particle. Is it right? can it be ignored?
Some of this is horrible to read. I am sure it would make sense, but is horrible to read without proper latex.
Anyway, to the OP, my few cents. The uncertainty between energy and time [tex]\Delta E \Delta t[/tex] does not violate any conservation laws. You cannot extract energy which is already there.
All it means is that a state which exists for a very short time cannot have a well-defined energy. Nothing amazingly weird is going on. The shorter you make a measurement, the more undefined that measurement becomes in relation to the energy of the system. If you watch over a system for a great length of time, you have a well-defined energy in contrast.
as QuantumClue said: it does not borrow energy! Yes, the W exists for a very short time and travels a short distance. Measuring the lifetime of the W (which is impossible as it is too short) would result in a probability distribution with a width Delta T; measuring the energy of the W results in a distribution with a width Delta E; these two values are related by the time-energy uncertainty. But again: energy is always conserved.
In addition to all the answers given here, please also read our FAQ in the General Physics forum. And yes, it implies that this is a very frequent question that we get on here.
Zz.
Just one more question, why do so many textbooks ignore the inequality in the relationship when finding the mass of the virtual particles? can they do that? Is it ok to ignore the inequality?
What do you mean ignore the inequality?
What I mean by ignoring the inequality is that in the relationship they simply take
delta E*delta t = h/2, they use this for calculating the mass of pi meson in some textbooks, but the actual relationship is delta E*delta t >= h/2. so how can they simply ignore the '>' part of the relationship?
The uncertainty principle has taken many forms over history, and was finalized in its correct form not by Heisenberg, but by Kennard in 1927. It might interest you to know, it has had the appearance of:
[tex]\Delta x \Delta p \approx h[/tex]
But Heisenberg in his first formulation (in his original paper) did use an equal sign:
http://www.aip.org/history/heisenberg/p08a1.htm
The reasoning based on the time-energy uncertainty relation in order to determine masses of exchanged particles, decay constants etc. is never rigorous but always an estimation which should give us an order of magnitude, but which in many cases is more accurate than that. Therefore ignoring constants of order unity and similar things is OK.
I hate to beat a dead horse, but is not the pion a virtual particle in nuclear interactions? And yet Yukawa just took the radius of the nucleus, divided by the speed of light to get time, and then used the time-energy uncertainty relation (with an equality as been mentioned) to predict the mass of the pion? Now how can one predict the mass of a real pion from a virtual exchange?
Yukawa knew that a massive exchange particle introduces an exponential decay of the nucleon potential. So nucleon / nucleus size, range of the potential and mass of the exchange particle(s) are related. It works remarkably well, but is not exact.
  • · Replies 16 ·
  • · Replies 20 ·
  • · Replies 17 ·
