- 10,069
According to your own interpretation, tank F will not necessarily fill up first if tank A doesn't fill to the top.Dadface said:If it fills to the top then obviously tank A fills up first. If it doesn't fill to the top then tank F fills up first
If the input & output flows in tank A are the same when, say, the tank is ¾-filled, then tank J might be the one to fill up first. Assuming the pipes give the same restriction to the flow everywhere (Again, an assumption), the pipe J-K will also need the equivalent of a ¾ of the tank height to reach the input flow. That will never happen since the pipe J-K is about halfway into tank J.
This reasoning could also apply to tank C.
And given the proper flow and restriction, if tank C level gets higher than the input pipe, but not enough to reach the top, it could restrict further more the flow in tank B which may rise to the top first.
Is that constructive enough?
The point is that assuming there are no assumptions is not a valid argument as it clearly leads nowhere. The single drop dripping from the faucet is the information that stipulate the flow is slow enough that we can assume no pipe restriction, which answers your question:
A question that was already answered in post #2 and was also pointed out to you in post #45. But you still refused to admit defeat in post #46 by ignoring the justification given to you. The droplet symbol means «no matter how small are the pipes, they will never be a restriction».Dadface said:Most people here seem to be of the opinion that the second answer is the correct answer. But can they justify that answer?
