Does weight change in an elevator?
  • Context: High School
  • Thread starter Thread starter pb23me
    Gain Weight
In an accelerating elevator, the concept of weight can vary based on the definition used. Traditional physics defines weight as the gravitational force (mg), which remains constant regardless of the elevator's acceleration. However, when considering weight as the reading on a scale, it does change due to the elevator's acceleration, resulting in a phenomenon known as "apparent weight." The apparent weight increases during ascent due to the additional force from the elevator's acceleration, while it decreases during descent.
  • Understanding of Newton's laws of motion
  • Familiarity with the concepts of gravitational force and acceleration
  • Knowledge of the difference between mass and weight
  • Basic principles of General Relativity (GR) regarding coordinate systems
  • Study the differences between mass and weight in various contexts
  • Learn about the effects of acceleration on apparent weight in different scenarios
  • Explore Newton's laws of motion in relation to elevators and other accelerating systems
  • Investigate the implications of General Relativity on weight perception in non-inertial frames
Physics students, educators, and anyone interested in understanding the effects of acceleration on weight perception in real-world scenarios, particularly in relation to elevators.
pb23me
Does an object gain weight?
When a person is in an elevator and the elevator begins to go up...Does the person actually gain weight? I know mass will not change obviously, but does the variable "g" vary due to acceleration?
It depends on your definition of "weight." Most physics textbooks define "weight" as "gravitational force" (which equals mg near the surface of the earth). In this case your weight doesn't change in an accelerating elevator.
Some sources (including Hewitt's "Conceptual Physics") define "weight" as "what a bathroom scale (or other similar device) reads." In this case, your weight does change in an accelerating elevator.
'g' is the acceleration due to gravity, which doesn't change when a person is in an accelerating elevator. What changes is the normal reaction, sometimes referred to as the apparent weight.
Note: posted simultaneously with jt
apparent weight as in inertia ? Making your weight increase in the in the beginning of ascend .
Classically, no, as pointed out. But in the GR framework, if your coordinate system is attached to the elevator, yes, the weight increases.
Should it be W=mg+ma?
That would be the "apparent" weight mentioned by Gokul and jtbell.
In an exam question, they are unlikely to ask you, "When a person is in an elevator and the elevator begins to go up, does the person gain weight?" because this depends on your definition of weight.
They are more like to ask you, "If a person is standing on some weighing scales inside an elevator. The elevator starts from rest, goes upwards, stops, and comes back down, and stops again. Describe, at different stages, the readings on the scale (giving reasons for your answer)."
  • · Replies 22 ·
  • · Replies 54 ·
  • · Replies 24 ·
  • · Replies 38 ·
  • · Replies 29 ·
