Does z = x² + y² - 4 intersect the yz-plane?
14 replies · 4K views
madachi
Does the surface [itex]z = x^2 + y^2 - 4[/itex] * intersects the [itex]yz[/itex]-plane? If so, find the equation of the curve and write down the points of intersection.
[itex]yz-[/itex]plane, so [itex]x=0[/itex]
1) * becomes [itex]z = y^2 - 4[/itex] and this is the equation of the curve that intersects the [itex]yz[/itex]-plane.
2) So the intersection points are [itex](0,-2,0)[/itex] and [itex](0,2,0)[/itex]
Are 1) and 2) correct? Thanks in advance!
Shouldn't there be a third intersection point?
You found the intersection points of the curve on the y-axis, what about the z-axis?
Is it [itex](0,0,-4)[/itex] ? But I am slightly confused, doesn't the whole curve intersect yz-plane and so there are infinitely many points of intersection?
Thanks.
the graph of [itex]z = x^2 + y^2 - 4[/itex], is a parabaloid, rotationally symmetric about the z axis
the intersection of the surface with the yz plane (x=0) is the parabola [itex]z = y^2 - 4[/itex] which has, as you say, infinitely many points.
I'm not too sure what the last part is asking for, maybe it is where the curve intersects the y & z axis...
I wanted to do the question myself so I only show a part of the question.
The original question is:
If the surface intersects the [itex]xy, xz[/itex], and [itex]yz[/itex] coordinate planes, find the equation of each of the parabolic boundary curves. Where do the curves intersect with the three coordinate axes?
I thought if the surface intersects the three coordinate planes, then the points of intersection must be [itex](0,0,0)[/itex]?
Thanks.
Thanks.
nope, that is not a point on the surface, and so none of the curves pass through that point
the easiest way to work out what i going on is to try & draw a picture, so i hope you'e attempted that. This problem is essentially showing you agood way to draw simple 3D surfaces, by drawing the intersection on each coordinate plane.
you should get 2 parabolas & and a circle
if you think about the shape of the surface and curves, the curve constrained by x = 0, will never intersect the x axis. So each point of intersection with axis will have 2 curves passing through it
due to the symmetry (which can save you some time) there will be one point of intersection on the z axis and 2 each for the x & y...
I have drawn the graph, it's a paraboloid. But I don't understand about the 2 parabolas and a circle.
I understand that the level curves are parabola and circle, but why the intersecting ones are only the specific 2 parabolas and 1 circle that you mentioned?
Thanks.
ok, so what is the equation for each curve...
[itex]z = x^2 - 4[/itex]
[itex]x^2 + y^2 = 4[/itex]
Are these correct?
yep so what do the forms of those equations look like?
The first two are parabolas. The last one is circle.
So are the intersection points
1) [itex](-2,0,0),(2,0,0)[/itex] for the first curve.
2) [itex](0,-2,0),(0,2,0)[/itex] for the second curve.
3) [itex](0,0,-4)[/itex] for the third curve mentioned above?
Thanks.
Thanks.
the points look ok, but they correspond to an axis, not a specific curve, each will have 2 curves passing through it
I am confused. Could you show me the equation for one the curves so I can try to figure what you mean? Didn't I already show the equation of the 3 curves? Are they different from the ones that you just mentioned? Thanks.
you've got it all, so pulling it together from your posts (though check it as i did pretty quick):
curve 1 - yz plane (x=0)
curve 2 - xz plane (y=0)
curve 3 - xy plane (z=0)
axes intersection points
x axis - (-2, 0, 0) and (2,0,0) by curves 2&3,
y axis - (0 ,-2, 0) and (0,2,0) by curves 3&1,
z axis - (0 , 0, 4) by curves 1&2
I see, thanks!
